Using DFPlayer - Mini MP3 Player. Issues
Hello,
I've just added the DF player to my project. When I run the sample code it works, when I add it to my project it fails. What have I done wrong?
^^ this is the mini DF player.
The code is designed to move a servo to pat someone on the back every time they pat the sensor. (and play a little MP3 clip that tells them they have done a good job.)
Here is my code which sends up the error message "Connecting to DFPlayer Mini failed!" (which is from the setup)
Thanks!
#include <Servo.h>  // include servo libary
#include "SoftwareSerial.h"
#include "DFRobotDFPlayerMini.h"
// Useing 3 states to have One pat = pat of servo. Good But slow.
static const uint8_t PIN_MP3_TX = 8;   // Connects to module's RX (DFPlayer Mini)
static const uint8_t PIN_MP3_RX = 10;  // Connects to module's TX
SoftwareSerial softwareSerial(PIN_MP3_RX, PIN_MP3_TX);
// Create the DFRobot Player mini object
DFRobotDFPlayerMini player;
const byte PinSensor = A0;
Servo patterServo;
unsigned servoDown = 270;  // number to write to servo for it to be down.
unsigned servoUp = 30;     // number to write to servo for it to be up.
int PatThresh = 90;  // when sensor is triggered
int PatHyst = 20;    // a sort of debouce
bool held;
enum State {
  IDLE,
  PATTED,
  RESET
State state = IDLE;
unsigned long lastChange = 0;
unsigned long lastChangeMusic = 0;
const unsigned long interval = 200;
const unsigned long track_length = 3000;
  // Init serial port for DFPlayer Mini
  softwareSerial.begin(9600);
 // delay(1000);
  // Start communication with DFPlayer Mini
  if (player.begin(softwareSerial)) {
    Serial.println("OK");
    // Set volume to maximum (0 to 30).
    player.volume(30);
    Serial.println("Connecting to DFPlayer Mini failed!");
    patterServo.attach(9);
  held = false;
  unsigned long now = millis();
  int sensorVal = analogRead(PinSensor);
  unsigned long now2 = millis();
  switch (state) {
    case IDLE:
      patterServo.write(servoUp);
      Serial.println("  IDLE");
      Serial.println(sensorVal);
      if (!held && ((PatThresh + PatHyst) < sensorVal)) {  // Move to patted state if pat is sensed (but not if someone is just holding sensor.)
        lastChange = now;
        lastChangeMusic = now2;
        state = PATTED;
      } else if (held && (PatThresh - PatHyst) > sensorVal) {  // this switches it to being un held if someone was just holding the sensor
        held = false;
        Serial.println("   release");
        state = IDLE;
    case PATTED:
      patterServo.write(servoDown);  // in Patted state, move servo down to pat
      Serial.println("  PATTED");
      held = true;
      if (now2 - lastChangeMusic > track_length) {  //track_length is the duration of the audio(1)
        //(2) is the 2rd file in the sd card, the order = the order you copied the file to it
        player.play(1);
      if (now - lastChange >= interval) {  // wait for servo to get there and move to state reset
        state = RESET;
        lastChange = now;
    case RESET:
      patterServo.write(servoUp);  // Move servo back to starting position
      Serial.println("  RESET");
        state = IDLE;
        lastChange = now;
From the wiki:
Add a 1kΩ resistor between Arduino TX and DFPlayer RX for signal conditioning.
DFPlayer Mini operates at ~3.3V while many MCUs use 5V; the resistor helps with level compatibility and reduces noise.
I have done that.
Also - it works when I only run the sample code on its own? So I assume that shows that the wiring it correct.
I followed this wiring (actually has two resistors?) And I changed it a bit as I only have one speaker.
Which Arduino are you using, Uno, Mega, ESP, etc.?
UNO, MEGA?
Also the speaker output is not stereo. You should only connect one speaker between the speaker terminals.
Is this Golam person working with you?
Why do I not see green flag/notification when you print Golam or GolamMostafa? It only comes when you print @GolamMostafa. So in future, please type @GolamMostafa.
Hello,
Its an UNO.
I am only using one speaker. - so not exactly that wire diagram. But I did use two resistors as they did as I assumed that was a good idea.
Also it works perfectly when I use the sample code so I assume its not a wiring issue?
I can't see anything in your code that would cause it to fail.
Servo does have some effect on pins 9 and 10 so you might want to try different pins for RX and TX. Other than that i can't see anything wrong that would cause player.begin(softwareSerial) to fail
Also try disconnecting the servo and see if it works.
I do not believe this is a valid servo "degree." Valid range is 0 to 180. You can send different values, but the result is unknown.
Is this another mouse-whacker?
That wiring is incorrect, which I think was acknowledged by the author later. Wire each speaker between SPK1 and SPK2. (Or if you do want to use two speakers then wire them in series.)
EDIT: Also, echoing others, what Arduino you are using? And please post a schematic showing all connections including power supply details.
Meanwhile, a module vol of 30 is in danger of crashing your circuit due to voltage dropping on audio peaks. I rarely use more than 20.
EDIT: What is your sensor? And what is the sketch action you expect?
@Terrypin @GolamMostafa @jim-p @xfpd
So the arduino is an arduino Uno Rev 3.
I'm working on a project that as you pat a plastic doll, the blanket pats you back on the back.
The sensor I made myself out of conductive fabric and piezoresistive fabric layered up. It is a force sensor. I have not had an issue with the values I've given the servo!
Here is the schematic!
It looks like you have RX/TX swapped.
In your code D8 is TX and you have it connected to DFplayer TX
Exactly - it is correct - in code d8 is tx and df tx is connected to d8? So to me it looks correct?
RX/TX = 8/10 agrees with schematic of post #12.
TX to RX
RX to TX
Like the comments in your code say
Do you see?
Good catch; however, is it going to help in making a wrong connection?
The code is correct but the OP's schematic labels for the module RX /TX are reversed. A high res photo would show the correct wiring.
Oh! I didn’t realise tx was to rx. I must have read it a hundred times and just had a dyslexic moment . I’ll double check how it’s actually wired in real life. Although weird that it runs the sample code!
Maybe in the sample code you have the pins swapped the correct way.
