I'm using Arduino uno with a display and DHT11 sensor. With the USB power supply it works all good but with external power supply (ACDC adapter 9 V / 1 A) the sensor was burnt.
Please explain what you did, and how it was connected.
Did you use the Arduino 5V pin for the DHT11, and hopefully not the Vin pin ?
Did you use the external power supply only for the Arduino, not directy to the DHT11 I assume ?
It should not be possible to damage the DHT11 sensor. As far as I can tell, you did everything right.
Does your board have a fault ? Can you measure the 5V pin ?
Peter_n:
I assume that my board works properly, because with other projects i don't have any problems.
However I'll try to measure the 5V pin and then I'll tell u the result
Perhaps you accidently touched the DHT11 with a higher voltage, or the DHT11 just broke down and using external voltage was just coincidentally.
Buy a new one and you will be okay 8)
post a photo of your circuit. The DH1-11 Vcc is pin-1, and GND is pin-4. If you plugged the sensor in the other way it would be connected backwards and possibly damage it. What do you base your conclusion that the sensor is "burnt" ? Did you see a puff of smoke at some point ? How do you know it is damaged ?
