Hello,
I have a portable breadboard that has several components that attach to DHT-22 (AM2302) wired sensors located in different places that have integrated resistors for pullup/pulldown. (see picture below)
I just recently begun to start using the DHT-22 version that has no integrated resistor built in. Since i move the breadboard often enough, i don't like to have to rewire it for each sensor type. What i would like to do is wire the breadboard for both both scenarios so that it is set up like 2 "ports". I don't mind a bit of redundancy in the wiring to get two separate locations on the breadboard to make separate "ports"
Port 1, would be the existing wiring as shown in the picture (DHT-22 with integrated resistor).
Port 2, would be located and attached in the green box with no integrated resistor in the sensor.
The whole point of the exercise, is that i don't make a mistake in forgetting to rewire it. I have read adafruit's instructions on how to wire the "port 2" version, but i am concerned that wiring exactly the same way will interfere with port 1 functionality.
How would Adafruit's instructions be changed to allow for both ports.
Thanks
-Sittingonit
