I am trying to run my DTH11 on my Arduino, but I keep getting this error:
Arduino: 1.8.13 (Windows 10), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
In file included from C:\Users\llama\OneDrive\Documents\Arduino\libraries\DHT_sensor_library-1.4.2\DHT_U.cpp:15:0:
C:\Users\llama\OneDrive\Documents\Arduino\libraries\DHT_sensor_library-1.4.2\DHT_U.h:36:10: fatal error: Adafruit_Sensor.h: No such file or directory
#include <Adafruit_Sensor.h>
compilation terminated.
exit status 1
Error compiling for board Arduino Mega or Mega 2560.
option enabled in File -> Preferences.
Here is my code:
#include <DHT.h>
#define Type DHT11
int sensePn = 2;
DHT HT(sensePn, Type);
float humidity;
float tempC;
float tempF;
int dt 500;
HT.begin();
delay(dt); //This is if you're using an unfimiliar library. It gives to to make sure everything is set up.
humidity = HT.readHumidity();
tempC = HT.readTemperature();
tempF = HT.readTemperature(true);
Serial.print("Humidity: " + humidity);
Serial.println("hey")
Google search for "Adafruit_Sensor.h" and find out where you can download it from.
Paul
@llamabro4, your topic has been moved to a more suitable location on the forum.
Please take some time to read How to get the best out of this forum and next apply what you've learned / read about code tags to the code in your post.
Thank you so much Paul! Can you explain to me why that worked?
It's not a standard library. So you have to download it. And most (or maybe all) Adafruit libraries rely on other Adafruit libraries (it's a bit of a pain); this assumes that the DHT library is an Adafruit library.
