Hi Guys,
For now, I'm almost done with having my DHT11 being monitored. The serial monitor is doing just fine and I can read values for temperature and humidity. I'm trying to have a LED either to be HIGH or LOW if the right temperature is read. Every time I run my code the LED is either HIGH or LOW but isn't changing when the read values are changing. The first try was to have the LED1 be HIGH if 20 was reached and kept, and be LOW if the temperature is anything between.
the circuit is:
DHT11 connected to 5v, ground and signal to pin5
LED1 connected to Pin2 and ground.
The code is under here.
[code]// DHT Temperature & Humidity Sensor
// Unified Sensor Library Example
// Written by Tony DiCola for Adafruit Industries
// Released under an MIT license.
// REQUIRES the following Arduino libraries:
// - DHT Sensor Library: https://github.com/adafruit/DHT-sensor-library
// - Adafruit Unified Sensor Lib: https://github.com/adafruit/Adafruit_Sensor
#include <Adafruit_Sensor.h>
#include <DHT.h>
#include <DHT_U.h>
#define DHTPIN 3 // Digital pin connected to the DHT sensor
// Feather HUZZAH ESP8266 note: use pins 3, 4, 5, 12, 13 or 14 --
// Pin 15 can work but DHT must be disconnected during program upload.
// Uncomment the type of sensor in use:
#define DHTTYPE DHT11 // DHT 11
// See guide for details on sensor wiring and usage:
// https://learn.adafruit.com/dht/overview
DHT_Unified dht(DHTPIN, DHTTYPE);
uint32_t delayMS;
const int LED1=2;
const int LED2=5;
pinMode (LED1,OUTPUT);
pinMode (LED2,OUTPUT);
digitalWrite (LED1,LOW);
digitalWrite (LED2,LOW);
// Initialize device.
dht.begin();
Serial.println(F("DHTxx Unified Sensor Example"));
// Print temperature sensor details.
sensor_t sensor;
dht.temperature().getSensor(&sensor);
Serial.println(F("------------------------------------"));
Serial.println(F("Temperature Sensor"));
Serial.print (F("Sensor Type: ")); Serial.println(sensor.name);
Serial.print (F("Driver Ver: ")); Serial.println(sensor.version);
Serial.print (F("Unique ID: ")); Serial.println(sensor.sensor_id);
Serial.print (F("Max Value: ")); Serial.print(sensor.max_value); Serial.println(F("°C"));
Serial.print (F("Min Value: ")); Serial.print(sensor.min_value); Serial.println(F("°C"));
Serial.print (F("Resolution: ")); Serial.print(sensor.resolution); Serial.println(F("°C"));
// Print humidity sensor details.
dht.humidity().getSensor(&sensor);
Serial.println(F("Humidity Sensor"));
Serial.print (F("Max Value: ")); Serial.print(sensor.max_value); Serial.println(F("%"));
Serial.print (F("Min Value: ")); Serial.print(sensor.min_value); Serial.println(F("%"));
Serial.print (F("Resolution: ")); Serial.print(sensor.resolution); Serial.println(F("%"));
// Set delay between sensor readings based on sensor details.
delayMS = sensor.min_delay / 1000;
// Delay between measurements.
// Get temperature event and print its value.
sensors_event_t event;
dht.temperature().getEvent(&event);
if (isnan(event.temperature)) {
Serial.println(F("Error reading temperature!"));
else {
Serial.print(F("Temperature: "));
Serial.print(event.temperature);
// Get humidity event and print its value.
dht.humidity().getEvent(&event);
if (isnan(event.relative_humidity)) {
Serial.println(F("Error reading humidity!"));
else {
Serial.print(F("Humidity: "));
Serial.print(event.relative_humidity);
if (event.temperature=21)digitalWrite (LED1, HIGH);
else digitalWrite (LED1, LOW);
[/code]
Oops.. if(event.temperature = 21)....,..
Change it to if( event.temperature >= 20)
Hi Railroader,
thank you for your support and advice! The code still doesn't work. I'm not sure if (event.temperature) is the right command to be read... do you have any other suggestions to what is wrong?
-Frederik Sølver
what is the second { doing after the final else?
put a serial print in your if statement to see if it ever runs
Its up and running now! thanks for the support
next step is to get a CPU-fan running on input from the DHT11.
Fine! What was the cork You unplugged?
Post your working code and an explanation for others to learn from.
Railroader: not sure what you mean?
Pmagowan: where should I post it?
What was the error? What did You change and it started to work?
Right here so the answer is with the question.
Hello world!
I'm trying to connect a CPU fan and make it react to values from my DHT11.
I would like to be able to adjust my fan speed with help from the values read on my DHT11 sensor.
I have a project where I'm able to adjust the fan speed with 0-255 signal with manually added values from 0-100 in the Arduino IDE.
I also have a project where I'm able to serial.moniter/print my values from the DHT11-sensor and the ability to determent if the fan should be high or low to be high/low when specific values were read from the DHT11. I'm trying to combine the to projects now but it doesn't let me adjust the speed on the fan only determent if the fan signal is high/low. the code is posted underneath
the fan is with 4-wire PWM.
Nothing wrong with the wiring, so it must be the code
Best - Frederik Sølver
#include <DHT.h>
#include <DHT_U.h>
uint32_t delayMS;
const byte Fan = 9;
const byte OC1B_PIN = 10;
const word PWM_FREQ_HZ = 20000; //Adjust this value to adjust the frequency
const word TCNT1_TOP = 16000000/(2*PWM_FREQ_HZ);
dht.begin();
sensor_t sensor;
pinMode(Fan, OUTPUT);
// Clear Timer1 control and count registers
TCCR1A = 0;
TCCR1B = 0;
TCNT1 = 0;
// Set Timer1 configuration
// COM1A(1:0) = 0b10 (Output A clear rising/set falling)
// COM1B(1:0) = 0b00 (Output B normal operation)
// WGM(13:10) = 0b1010 (Phase correct PWM)
// ICNC1 = 0b0 (Input capture noise canceler disabled)
// ICES1 = 0b0 (Input capture edge select disabled)
// CS(12:10) = 0b001 (Input clock select = clock/1)
TCCR1A |= (1 << COM1A1) | (1 << WGM11);
TCCR1B |= (1 << WGM13) | (1 << CS10);
ICR1 = TCNT1_TOP;
setPwmDuty(100); //Change this value 0-100 to adjust duty cycle
//digitalWrite (LED1,);
//digitalWrite (LED2,LOW);
delay(5000);
else {
if ( event.temperature >= 23) digitalWrite (Fan,50);
else digitalWrite (Fan, 100);
//Serial.print ("hey");
else {
// setPwmDuty(50);
// delay(20000);
// setPwmDuty(75);
// delay(20000);
// setPwmDuty(100);
// delay(20000);
void setPwmDuty(byte duty) {
OCR1A = (word) (duty*TCNT1_TOP)/100;
AnalogWrite, not digitalWrite.
What a stupid mistake. thank you so much for helping out!
@frederiksolver
TOPIC MERGED.
Please do NOT cross post / duplicate as it wastes peoples time and efforts to have more than one post for a single topic.
Continued cross posting could result in a time out from the forum.
Could you take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
It will help you get the best out of the forum.
Hi Ballscrewbob, sorry for causing these cross-post. I don't know how I ended up doing it. I will try to do it right next time!
