hi. whats are the connections for the dht11 on 16x2 lcd screen? how can i connect both of them in breadboard? they both needs 5v and gnd connection. i dont have enough information about arduino so i tought i should learn.
how breadboard works? whats are the connections mean?
Check the datasheets (found on GOOGLE) for each item you have (including the breadboard). They have the correct wiring pinouts.
Check the examples from each library required to see how to code them.
Google is your friend. We cannot install Arduino knowledge 3.2 directly into your head a la The Matrix.
