I am working on a project in which I need two arduinos to communicate with one another and I also need to communicate with the arduinos through an iphone app.
I have done some research and keep coming across the same Bluetooth devices. What are the differences between the Bluesmirf, HC-05, and Rfduino? Which would work best for my project? Any help will be appreciated. Thank you!
In that event you can definitely scratch the HC-05 as it is incompatible with IOS. and perhaps the Bluesmirf too. I understand Rfduino is kosher but you need to check that. If it is BLE - Bluetooth Low Energy" it should be OK.
know i'm working on hc05 to connect mindwave mobile but it is not connecting so anyone is by hc05 we can connect mindwave mobile or not
if it's not y because by bluesmirf we can connect mindwave mobile
what extra feature it has like it can connect to mindwave mobile
