Every time I try an example I always get message like " not working with your controller' or your controller may be a fake.
What do I select for the controller for any of these controllers as I own them all:
Mini Nano V3.0 ATmega328P Microcontroller Board
KeeYees Development Board 2.4 GHz Dual Core WLAN WiFi + Bluetooth 2-in-1 Microcontroller ESP-WROOM-32 Chip CP2102 for ESP32 for Arduino (2PCS)
AITRIP D1 Mini WiFi Dev Board,Mini NodeMcu Lua 4M Bytes WLAN WiFi Internet Development Board Base on ESP8266 ESP-12F for Arduino, 100% Compatible with WeMos D1 Mini (Pack of 6)
This board is not supported by Arduino IoT Cloud. IoT applications tend to require quite a bit of memory resources, even more so if you want them to be secure. The ATmega328P is an excellent microcontroller, but it is limited in resources, so it's not really a good candidate for IoT anyway. However, this is an excellent board to use for other project.
These are the boards you can use with the Arduino IoT Cloud:
However, your ATmega328P-based Nano board can be used in Arduino Web Editor if you like:
Arduino IoT Cloud's support for ESP32 boards is currently in the experimental state. So you should be able to use this board with Arduino IoT Cloud, but you should understand that you are using it in more of a beta tester role, which can be an opportunity to make a valuable contribution to the Arduino project.
The ESP8266 should be fully supported by Arduino IoT Cloud.
This board should be fully supported by Arduino IoT Cloud.
So I think you have some very nice boards and should be able to make some cool things with Arduino IoT Cloud. Please post here the full and exact text of any error or warning messages you are getting and we'll see if we can help you out.
