Build options changed, rebuilding all
C:\Users\sls90_000\Desktop\FTP\FTP.ino:37:0: warning: "PINK" redefined
#define PINK 0xF81F
In file included from c:\program files (x86)\arduino\hardware\tools\avr\avr\include\avr\iom2560.h:38:0,
from c:\program files (x86)\arduino\hardware\tools\avr\avr\include\avr\io.h:174,
from c:\program files (x86)\arduino\hardware\tools\avr\avr\include\avr\pgmspace.h:90,
from C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:28,
from sketch\FTP.ino.cpp:1:
c:\program files (x86)\arduino\hardware\tools\avr\avr\include\avr\iomxx0_1.h:1149:0: note: this is the location of the previous definition
define PINK _SFR_MEM8(0x106)
C:\Users\sls90_000\Desktop\FTP\FTP.ino: In function 'void lcd_setup()':
C:\Users\sls90_000\Desktop\FTP\FTP.ino:225:43: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
drawBMP("untitled.bmp", 90, 20, BU_BMP); //Change untitled to any bitmap image name you wish to use
C:\Users\sls90_000\Desktop\FTP\FTP.ino: In function 'void wifi_setup()':
C:\Users\sls90_000\Desktop\FTP\FTP.ino:299:30: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
if(Serial2.find("CONNECTED"))
C:\Users\sls90_000\Desktop\FTP\FTP.ino:314:30: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
C:\Users\sls90_000\Desktop\FTP\bitmap_functions.ino: In function 'void drawRAW(char*, int16_t, int16_t, int16_t, int16_t)':
C:\Users\sls90_000\Desktop\FTP\bitmap_functions.ino:24:40: warning: converting to non-pointer type 'int' from NULL [-Wconversion-null]
if ((rawFile = SD.open(filename)) == NULL) {
C:\Users\sls90_000\Desktop\FTP\bitmap_functions.ino: In function 'void drawBMP(char*, int, int, boolean)':
C:\Users\sls90_000\Desktop\FTP\bitmap_functions.ino:91:40: warning: converting to non-pointer type 'int' from NULL [-Wconversion-null]
if ((bmpFile = SD.open(filename)) == NULL) {
Sketch uses 48508 bytes (19%) of program storage space. Maximum is 253952 bytes.
Global variables use 2020 bytes (24%) of dynamic memory, leaving 6172 bytes for local variables. Maximum is 8192 bytes.
