Hi all, i'm not really very experienced at programming, and have gotten myself well and truly confused, I have in my collection an old railway cab radio set (GSM-R) panel, i've been trying to emulate the proper displays, though trial and error i've been able to figure out most of the binary commands to make characters appear on the screen (which is non standard it doesn't have a R/S pin), currently i don't have any of the inputs connected so i've been using serial commands to control it (i plan to connect a second uno board via serial which will have the keypads),
with the below codeing, i can boot up the radio, run a self test, enter a headcode and register the unit, and deregister it...
what i'm trying to do now is implement the brightness and volume controls
on the real thing the Brightness screen displays
(the first line is not touched)
"Brightness" on the 2nd line and
"" on the 3rd line (where X is either a Block or a space (lcd.write(239)) (lcd.write(255))
operating either the Brightness - Key (Serial command '[') or Brightness + key (serial command ']') should make the brightness display appear, and each subsequent press affects increments/decrements, each block represents 25% brightness and the first block is always present, the lcd commands are 25% - lcd.write(28),29,30,31 - 100%, if no button has been pressed the brightness screen disappears (overwritten by spaces) after 3 seconds,
i have a bit of code that increments/ decrements an int (line 295) when it receives an [/] input but i'm having trouble with the code that makes the screen appear and disappear i've tried a few things but without success, so i rolled back to a version of the code that worked
the volume display is identical but with 5 stages instead of 4
a seperate issue i have is with the Letter entry on the headcode line 606-890 currently these have been implemented as individual inputs, but in reality the keypad is mobile phone style so to get B you'd need to press 2 twice, each subsequent press of the number key cycles through the 3/4 letters assigned to it, and the display should update in realtime, but only register the character and move on when the button has been idle for 2 seconds, or a differnent button has been pressed, all my attempts at this have failed, and i'm not sure what else to try
#include <LiquidCrystal.h>
LiquidCrystal lcd(4, 2, 6, 7, 8, 9, 10, 11, 12, 13);
int GSMRState = '0';
int Stest = 0;
char RHeadcode[4] = { ' ',' ',' ',' '};
int RHeadcodeE = '0';
int IPHeadcode = '0';
int IPHeadcodechar = 1;
int countlet2 = 0;
char key = 0;
char IPHeadcodeENT[7] = {' ',' ',' ',' ',' ',' ',' '};
char IPHeadcodeENT0 = '/0';
char IPHeadcodeENT1 = '/0';
char IPHeadcodeENT2 = '/0';
char IPHeadcodeENT3 = '/0';
char IPHeadcodeENT4 = '/0';
char IPHeadcodeENT5 = '/0';
char IPHeadcodeENT6 = '/0';
char IPHeadcodeENT7 = '/0';
char IPHeadcodeWK = ' ';
unsigned long startTime = 0;
bool timerRunning = false;
int BrightnessScr = '0';
int Brightnesslvl = 3; // Brightness Level 0-25%, 1-50%, 2-75%, 3-100%
//Serial Commands:
// ! - Long Press on Registration Button
// $ - Short Press on Registration Button
// t - T Button
// x - Cancel
// 1 - 1
// 2
// 3
// 4
// 5
// 6
// 7
// 8
// 9
// / tick
// [ Brightness -
// ] Brightness +
lcd.begin(20,4);
lcd.write(20); //Clear Display
delay(50);
lcd.write(14);
delay(50);
//GSMR OFF
if (GSMRState == '0') {
delay(50);
delay(50);
lcd.write(14);
delay(50);
Brightnesslvl = 3;
do {
char key = Serial.read();
if (key == '!' && GSMRState == '0') {
GSMRState = '2';} // check me temporly disables boot up sequence (normally '1')
} while (GSMRState == '0');
//bootup sequence
if (GSMRState == '1') {
delay(250);
delay(50);
lcd.write(14); //NR V3.5 Initializing
delay(50);
lcd.write(10);
delay(50);
lcd.write(78);
delay(50);
lcd.write(82);
delay(50);
lcd.write(255);
delay(50);
lcd.write(86);
delay(50);
lcd.write(51);
delay(50);
lcd.write(46);
delay(50);
lcd.write(53);
delay(50);
lcd.write(255);
delay(50);
lcd.write(73);
delay(50);
lcd.write(110);
delay(50);
lcd.write(105);
delay(50);
lcd.write(116);
delay(50);
lcd.write(105);
delay(50);
lcd.write(97);
delay(50);
lcd.write(108);
delay(50);
lcd.write(105);
delay(50);
lcd.write(122);
delay(50);
lcd.write(105);
delay(50);
lcd.write(110);
delay(50);
lcd.write(103);
delay(50);
lcd.write(239);
delay(random(150,1000)); //Loading bar
lcd.write(239);
lcd.write(239);
lcd.write(239);
lcd.write(239);
lcd.write(239);
lcd.write(239);
delay(50);
lcd.write(20); //Powering up/testing
delay(50);
lcd.write(14);
delay(50);
lcd.write(10);
delay(50);
lcd.write(80);
delay(50);
lcd.write(111);
delay(50);
lcd.write(119);
delay(50);
lcd.write(101);
delay(50);
lcd.write(114);
delay(50);
lcd.write(105);
delay(50);
lcd.write(110);
delay(50);
lcd.write(103);
delay(50);
lcd.write(255);
delay(50);
lcd.write(117);
delay(50);
lcd.write(112);
delay(50);
lcd.write(47);
delay(50);
lcd.write(84);
delay(50);
lcd.write(101);
delay(50);
lcd.write(115);
delay(50);
lcd.write(116);
delay(50);
lcd.write(105);
delay(50);
lcd.write(110);
delay(50);
lcd.write(103);
delay(2500);
lcd.write(20); //Searching networks
delay(50);
lcd.write(14);
delay(50);
lcd.write(10);
delay(50);
lcd.write(83);
delay(50);
lcd.write(101);
delay(50);
lcd.write(97);
delay(50);
lcd.write(114);
delay(50);
lcd.write(99);
delay(50);
lcd.write(104);
delay(50);
lcd.write(105);
delay(50);
lcd.write(110);
delay(50);
lcd.write(103);
delay(50);
lcd.write(255);
delay(50);
lcd.write(110);
delay(50);
lcd.write(101);
delay(50);
lcd.write(116);
delay(50);
lcd.write(119);
delay(50);
lcd.write(111);
delay(50);
lcd.write(114);
delay(50);
lcd.write(107);
delay(50);
lcd.write(115);
delay(50);
lcd.write(10);
delay(50);
lcd.write(13);
delay(50);
lcd.write(80);
delay(50);
lcd.write(108);
delay(50);
lcd.write(101);
delay(50);
lcd.write(97);
delay(50);
lcd.write(115);
delay(50);
lcd.write(101);
delay(50);
lcd.write(255);
delay(50);
lcd.write(119);
delay(50);
lcd.write(97);
delay(50);
lcd.write(105);
delay(50);
lcd.write(116);
delay(50);
Stest = 1;
delay(random(2500,7000));
GSMRState = '2';
} //end boot up sequence
//GSMR Connected Home Screen Begins here
if (GSMRState == '2') {
delay(250);
delay(250);
lcd.write(14); // turns cursor invisible
delay(50);
lcd.write(71); //prints GSM-R GB
delay(50);
lcd.write(83);
delay(50);
lcd.write(77);
delay(50);
lcd.write(45);
delay(50);
lcd.write(82);
delay(50);
lcd.write(255);
delay(50);
lcd.write(71);
delay(50);
lcd.write(66);
delay(50);
do {
char key = Serial.read(); // scans for button presses
if (key == '!' && GSMRState == '2') { GSMRState = '0'; break;} // long press of registration button turns off GSMR
if (key == 't' && GSMRState == '2' && IPHeadcode == '0') { Stest = 1;} // runs self test
if (key == '$') if (GSMRState == '2' && RHeadcode[3] == ' ' && IPHeadcode == '0') { IPHeadcode = '1'; key = '0';} //Switch to Registration mode
if (key == '$') if (GSMRState == '2' && RHeadcode[3] != ' ' && IPHeadcode == '2') { IPHeadcode = '3'; key = '0';} //switch to deregistration mode
if (key == '[') if (GSMRState == '2' && Brightnesslvl >= 0) { --Brightnesslvl ; key = '0'; Serial.print(Brightnesslvl);} // trial code decrements Brightness level
if (key == ']') if (GSMRState == '2' && Brightnesslvl < 3) { ++Brightnesslvl ; key = '0'; Serial.print(Brightnesslvl);} // increments brightness level
//Set Resgistered Head Code
if (RHeadcodeE == '1' && GSMRState == '2') {
lcd.write(27);
delay(50);
lcd.write(16);
delay(150);
lcd.write(RHeadcode[0]);
delay(50);
lcd.write(RHeadcode[1]);
delay(50);
lcd.write(RHeadcode[2]);
delay(50);
lcd.write(RHeadcode[3]);
delay(100);
RHeadcodeE = '0';
//Self Test
if (Stest == 1) {
lcd.write(27);
delay(50);
lcd.write(32);
delay(50);
lcd.write(84);
delay(50);
lcd.write(101);
delay(50);
lcd.write(115);
delay(50);
lcd.write(116);
delay(50);
lcd.write(105);
delay(50);
lcd.write(110);
delay(50);
lcd.write(103);
lcd.write(13);
delay(50);
lcd.write(84);
delay(50);
lcd.write(101);
delay(50);
lcd.write(115);
delay(50);
lcd.write(116);
delay(50);
lcd.write(255);
delay(50);
lcd.write(79);
delay(50);
lcd.write(75);
lcd.write(13);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
Stest = 0;
} //Self Test Complete
//Input Headcode
if (IPHeadcode == '1') { if (Stest == 0) { if (GSMRState == '2'); {
lcd.write(27);
delay(50);
lcd.write(32);
delay(50);
lcd.write(82);
delay(50);
lcd.write(101);
delay(50);
lcd.write(103);
delay(50);
lcd.write(105);
delay(50);
lcd.write(115);
delay(50);
lcd.write(116);
delay(50);
lcd.write(114);
delay(50);
lcd.write(97);
delay(50);
lcd.write(116);
delay(50);
lcd.write(105);
delay(50);
lcd.write(111);
delay(50);
lcd.write(110);
delay(50);
lcd.write(255);
delay(50);
lcd.write(99);
delay(50);
lcd.write(111);
delay(50);
lcd.write(100);
delay(50);
lcd.write(101);
delay(50);
IPHeadcodechar = '1';
if (IPHeadcodechar == '1') { do {
if (key == 'x' && IPHeadcodechar == '1') {
IPHeadcode = '0';
lcd.write(27);
delay(50);
lcd.write(64);
delay(50);
lcd.write(255);
delay(50);
lcd.write(27);
delay(50);
lcd.write(32);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(27);
delay(50);
lcd.write(32);
delay(50);
IPHeadcodechar = '0';
break; }
if (key == '1' && IPHeadcodechar == '1') {
lcd.write(27);
delay(50);
lcd.write(64);
delay(50);
lcd.write('1');
delay(50);
IPHeadcodeENT0 = '1';
delay(50);
IPHeadcodechar = '2';}
if (key == '2' && IPHeadcodechar == '1') {
lcd.write(27);
delay(50);
lcd.write(64);
delay(50);
lcd.write('2');
delay(50);
IPHeadcodeENT0 = '2';
delay(50);
if (key == '3' && IPHeadcodechar == '1') {
lcd.write(27);
delay(50);
lcd.write(64);
delay(50);
lcd.write('3');
delay(50);
IPHeadcodeENT0 = '3';
delay(50);
if (key == '4' && IPHeadcodechar == '1') {
lcd.write(27);
delay(50);
lcd.write(64);
delay(50);
lcd.write('4');
delay(50);
IPHeadcodeENT0 = '4';
delay(50);
if (key == '5' && IPHeadcodechar == '1') {
lcd.write(27);
delay(50);
lcd.write(64);
delay(50);
lcd.write('5');
delay(50);
IPHeadcodeENT0 = '5';
delay(50);
if (key == '6' && IPHeadcodechar == '1') {
lcd.write(27);
delay(50);
lcd.write(64);
delay(50);
lcd.write('6');
delay(50);
IPHeadcodeENT0 = '6';
delay(50);
if (key == '7' && IPHeadcodechar == '1') {
lcd.write(27);
delay(50);
lcd.write(64);
delay(50);
lcd.write('7');
delay(50);
IPHeadcodeENT0 = '7';
delay(50);
if (key == '8' && IPHeadcodechar == '1') {
lcd.write(27);
delay(50);
lcd.write(64);
delay(50);
lcd.write('8');
delay(50);
IPHeadcodeENT0 = '8';
delay(50);
if (key == '9' && IPHeadcodechar == '1') {
lcd.write(27);
delay(50);
lcd.write(64);
delay(50);
lcd.write('9');
delay(50);
IPHeadcodeENT0 = '9';
delay(50);
if (key == '0' && IPHeadcodechar == '1') {
lcd.write(27);
delay(50);
lcd.write(64);
delay(50);
lcd.write('0');
delay(50);
IPHeadcodeENT0 = '0';
delay(50);
if (IPHeadcodechar == '2') {
do {
if (key == 'x' && IPHeadcodechar == '2') {
lcd.write(27);
delay(50);
lcd.write(64);
delay(50);
lcd.write(255);
delay(50);
delay(50);
IPHeadcodechar = '1'; break; }
if (key == 'A' && IPHeadcodechar == '2') {
lcd.write(27);
delay(50);
lcd.write(65);
delay(50);
lcd.write('A');
delay(50);
IPHeadcodeENT1 = 'A';
delay(50);
IPHeadcodechar = '3';}
if (key == 'B' && IPHeadcodechar == '2') {
lcd.write(27);
delay(50);
lcd.write(65);
delay(50);
lcd.write('B');
delay(50);
IPHeadcodeENT1 = 'B';
delay(50);
if (key == 'C' && IPHeadcodechar == '2') {
lcd.write(27);
delay(50);
lcd.write(65);
delay(50);
lcd.write('C');
delay(50);
IPHeadcodeENT1 = 'C';
delay(50);
if (key == 'D' && IPHeadcodechar == '2') {
lcd.write(27);
delay(50);
lcd.write(65);
delay(50);
lcd.write('D');
delay(50);
IPHeadcodeENT1 = 'D';
delay(50);
if (key == 'E' && IPHeadcodechar == '2') {
lcd.write(27);
delay(50);
lcd.write(65);
delay(50);
lcd.write('E');
delay(50);
IPHeadcodeENT1 = 'E';
delay(50);
if (key == 'F' && IPHeadcodechar == '2') {
lcd.write(27);
delay(50);
lcd.write(65);
delay(50);
lcd.write('F');
delay(50);
IPHeadcodeENT1 = 'F';
delay(50);
if (key == 'G' && IPHeadcodechar == '2') {
lcd.write(27);
delay(50);
lcd.write(65);
delay(50);
lcd.write('G');
delay(50);
IPHeadcodeENT1 = 'G';
delay(50);
if (key == 'H' && IPHeadcodechar == '2') {
lcd.write(27);
delay(50);
lcd.write(65);
delay(50);
lcd.write('H');
delay(50);
IPHeadcodeENT1 = 'H';
delay(50);
if (key == 'I' && IPHeadcodechar == '2') {
lcd.write(27);
delay(50);
lcd.write(65);
delay(50);
lcd.write('I');
delay(50);
IPHeadcodeENT1 = 'I';
delay(50);
if (key == 'J' && IPHeadcodechar == '2') {
lcd.write(27);
delay(50);
lcd.write(65);
delay(50);
lcd.write('J');
delay(50);
IPHeadcodeENT1 = 'J';
delay(50);
if (key == 'K' && IPHeadcodechar == '2') {
lcd.write(27);
delay(50);
lcd.write(65);
delay(50);
lcd.write('K');
delay(50);
IPHeadcodeENT1 = 'K';
delay(50);
if (key == 'L' && IPHeadcodechar == '2') {
lcd.write(27);
delay(50);
lcd.write(65);
delay(50);
lcd.write('L');
delay(50);
IPHeadcodeENT1 = 'L';
delay(50);
if (key == 'M' && IPHeadcodechar == '2') {
lcd.write(27);
delay(50);
lcd.write(65);
delay(50);
lcd.write('M');
delay(50);
IPHeadcodeENT1 = 'M';
delay(50);
if (key == 'N' && IPHeadcodechar == '2') {
lcd.write(27);
delay(50);
lcd.write(65);
delay(50);
lcd.write('N');
delay(50);
IPHeadcodeENT1 = 'N';
delay(50);
if (key == 'O' && IPHeadcodechar == '2') {
lcd.write(27);
delay(50);
lcd.write(65);
delay(50);
lcd.write('O');
delay(50);
IPHeadcodeENT1 = 'O';
delay(50);
if (key == 'P' && IPHeadcodechar == '2') {
lcd.write(27);
delay(50);
lcd.write(65);
delay(50);
lcd.write('P');
delay(50);
IPHeadcodeENT1 = 'P';
delay(50);
if (key == 'Q' && IPHeadcodechar == '2') {
lcd.write(27);
delay(50);
lcd.write(65);
delay(50);
lcd.write('Q');
delay(50);
IPHeadcodeENT1 = 'Q';
delay(50);
if (key == 'R' && IPHeadcodechar == '2') {
lcd.write(27);
delay(50);
lcd.write(65);
delay(50);
lcd.write('R');
delay(50);
IPHeadcodeENT1 = 'R';
delay(50);
if (key == 'S' && IPHeadcodechar == '2') {
lcd.write(27);
delay(50);
lcd.write(65);
delay(50);
lcd.write('S');
delay(50);
IPHeadcodeENT1 = 'S';
delay(50);
if (key == 'T' && IPHeadcodechar == '2') {
lcd.write(27);
delay(50);
lcd.write(65);
delay(50);
lcd.write('T');
delay(50);
IPHeadcodeENT1 = 'T';
delay(50);
if (key == 'U' && IPHeadcodechar == '2') {
lcd.write(27);
delay(50);
lcd.write(65);
delay(50);
lcd.write('U');
delay(50);
IPHeadcodeENT1 = 'U';
delay(50);
if (key == 'V' && IPHeadcodechar == '2') {
lcd.write(27);
delay(50);
lcd.write(65);
delay(50);
lcd.write('V');
delay(50);
IPHeadcodeENT1 = 'V';
delay(50);
if (key == 'W' && IPHeadcodechar == '2') {
lcd.write(27);
delay(50);
lcd.write(65);
delay(50);
lcd.write('W');
delay(50);
IPHeadcodeENT1 = 'W';
delay(50);
if (key == 'X' && IPHeadcodechar == '2') {
lcd.write(27);
delay(50);
lcd.write(65);
delay(50);
lcd.write('X');
delay(50);
IPHeadcodeENT1 = 'X';
delay(50);
if (key == 'Y' && IPHeadcodechar == '2') {
lcd.write(27);
delay(50);
lcd.write(65);
delay(50);
lcd.write('Y');
delay(50);
IPHeadcodeENT1 = 'Y';
delay(50);
if (key == 'Z' && IPHeadcodechar == '2') {
lcd.write(27);
delay(50);
lcd.write(65);
delay(50);
lcd.write('Z');
delay(50);
IPHeadcodeENT1 = 'Z';
delay(50);
//mode 2 clear code
if (IPHeadcodechar == '3') {
do {
if (key == 'x' && IPHeadcodechar == '3') {
lcd.write(27);
delay(50);
lcd.write(65);
delay(50);
lcd.write(255);
delay(50);
delay(50);
IPHeadcodeENT1 = '/0'; }
if (key == '1' && IPHeadcodechar == '3') {
lcd.write(27);
delay(50);
lcd.write(66);
delay(50);
lcd.write('1');
delay(50);
IPHeadcodeENT2 = '1';
delay(50);
IPHeadcodechar = '4';}
if (key == '2' && IPHeadcodechar == '3') {
lcd.write(27);
delay(50);
lcd.write(66);
delay(50);
lcd.write('2');
delay(50);
IPHeadcodeENT2 = '2';
delay(50);
if (key == '3' && IPHeadcodechar == '3') {
lcd.write(27);
delay(50);
lcd.write(66);
delay(50);
lcd.write('3');
delay(50);
IPHeadcodeENT2 = '3';
delay(50);
if (key == '4' && IPHeadcodechar == '3') {
lcd.write(27);
delay(50);
lcd.write(66);
delay(50);
lcd.write('4');
delay(50);
IPHeadcodeENT2 = '4';
delay(50);
if (key == '5' && IPHeadcodechar == '3') {
lcd.write(27);
delay(50);
lcd.write(66);
delay(50);
lcd.write('5');
delay(50);
IPHeadcodeENT2 = '5';
delay(50);
if (key == '6' && IPHeadcodechar == '3') {
lcd.write(27);
delay(50);
lcd.write(66);
delay(50);
lcd.write('6');
delay(50);
IPHeadcodeENT2 = '6';
delay(50);
if (key == '7' && IPHeadcodechar == '3') {
lcd.write(27);
delay(50);
lcd.write(66);
delay(50);
lcd.write('7');
delay(50);
IPHeadcodeENT2 = '7';
delay(50);
if (key == '8' && IPHeadcodechar == '3') {
lcd.write(27);
delay(50);
lcd.write(66);
delay(50);
lcd.write('8');
delay(50);
IPHeadcodeENT2 = '8';
delay(50);
if (key == '9' && IPHeadcodechar == '3') {
lcd.write(27);
delay(50);
lcd.write(66);
delay(50);
lcd.write('9');
delay(50);
IPHeadcodeENT2 = '9';
delay(50);
if (key == '0' && IPHeadcodechar == '3') {
lcd.write(27);
delay(50);
lcd.write(66);
delay(50);
lcd.write('0');
delay(50);
IPHeadcodeENT2 = '0';
delay(50);
if (IPHeadcodechar == '4') {
do {
if (key == 'x' && IPHeadcodechar == '4') {
lcd.write(27);
delay(50);
lcd.write(66);
delay(50);
lcd.write(255);
delay(50);
delay(50);
IPHeadcodechar = '3'; break; }
if (key == '1' && IPHeadcodechar == '4') {
lcd.write(27);
delay(50);
lcd.write(67);
delay(50);
lcd.write('1');
delay(50);
IPHeadcodeENT3 = '1';
delay(50);
IPHeadcodechar = '5';}
if (key == '2' && IPHeadcodechar == '4') {
lcd.write(27);
delay(50);
lcd.write(67);
delay(50);
lcd.write('2');
delay(50);
IPHeadcodeENT3 = '2';
delay(50);
if (key == '3' && IPHeadcodechar == '4') {
lcd.write(27);
delay(50);
lcd.write(67);
delay(50);
lcd.write('3');
delay(50);
IPHeadcodeENT3 = '3';
delay(50);
if (key == '4' && IPHeadcodechar == '4') {
lcd.write(27);
delay(50);
lcd.write(67);
delay(50);
lcd.write('4');
delay(50);
IPHeadcodeENT3 = '4';
delay(50);
if (key == '5' && IPHeadcodechar == '4') {
lcd.write(27);
delay(50);
lcd.write(67);
delay(50);
lcd.write('5');
delay(50);
IPHeadcodeENT3 = '5';
delay(50);
if (key == '6' && IPHeadcodechar == '4') {
lcd.write(27);
delay(50);
lcd.write(67);
delay(50);
lcd.write('6');
delay(50);
IPHeadcodeENT3 = '6';
delay(50);
if (key == '7' && IPHeadcodechar == '4') {
lcd.write(27);
delay(50);
lcd.write(67);
delay(50);
lcd.write('7');
delay(50);
IPHeadcodeENT3 = '7';
delay(50);
if (key == '8' && IPHeadcodechar == '4') {
lcd.write(27);
delay(50);
lcd.write(67);
delay(50);
lcd.write('8');
delay(50);
IPHeadcodeENT3 = '8';
delay(50);
if (key == '9' && IPHeadcodechar == '4') {
lcd.write(27);
delay(50);
lcd.write(67);
delay(50);
lcd.write('9');
delay(50);
IPHeadcodeENT3 = '9';
delay(50);
if (key == '0' && IPHeadcodechar == '4') {
lcd.write(27);
delay(50);
lcd.write(67);
delay(50);
lcd.write('0');
delay(50);
IPHeadcodeENT3 = '0';
delay(50);
if (IPHeadcodechar == '5') {
do {
if (key == 'x' && IPHeadcodechar == '5') {
lcd.write(27);
delay(50);
lcd.write(67);
delay(50);
lcd.write(255);
delay(50);
delay(50);
IPHeadcodechar = '4'; break; }
if (key == '1' && IPHeadcodechar == '5') {
lcd.write(27);
delay(50);
lcd.write(69);
delay(50);
lcd.write('1');
delay(50);
IPHeadcodeENT4 = '1';
delay(50);
IPHeadcodechar = '6';}
if (key == '2' && IPHeadcodechar == '5') {
lcd.write(27);
delay(50);
lcd.write(69);
delay(50);
lcd.write('2');
delay(50);
IPHeadcodeENT4 = '2';
delay(50);
if (key == '3' && IPHeadcodechar == '5') {
lcd.write(27);
delay(50);
lcd.write(69);
delay(50);
lcd.write('3');
delay(50);
IPHeadcodeENT4 = '3';
delay(50);
if (key == '4' && IPHeadcodechar == '5') {
lcd.write(27);
delay(50);
lcd.write(69);
delay(50);
lcd.write('4');
delay(50);
IPHeadcodeENT4 = '4';
delay(50);
if (key == '5' && IPHeadcodechar == '5') {
lcd.write(27);
delay(50);
lcd.write(69);
delay(50);
lcd.write('5');
delay(50);
IPHeadcodeENT4 = '5';
delay(50);
if (key == '6' && IPHeadcodechar == '5') {
lcd.write(27);
delay(50);
lcd.write(69);
delay(50);
lcd.write('6');
delay(50);
IPHeadcodeENT4 = '6';
delay(50);
if (key == '7' && IPHeadcodechar == '5') {
lcd.write(27);
delay(50);
lcd.write(69);
delay(50);
lcd.write('7');
delay(50);
IPHeadcodeENT4 = '7';
delay(50);
if (key == '8' && IPHeadcodechar == '5') {
lcd.write(27);
delay(50);
lcd.write(69);
delay(50);
lcd.write('8');
delay(50);
IPHeadcodeENT4 = '8';
delay(50);
if (key == '9' && IPHeadcodechar == '5') {
lcd.write(27);
delay(50);
lcd.write(69);
delay(50);
lcd.write('9');
delay(50);
IPHeadcodeENT4 = '9';
delay(50);
if (key == '0' && IPHeadcodechar == '5') {
lcd.write(27);
delay(50);
lcd.write(69);
delay(50);
lcd.write('0');
delay(50);
IPHeadcodeENT4 = '0';
delay(50);
if (IPHeadcodechar == '6') {
do {
if (key == 'x' && IPHeadcodechar == '6') {
lcd.write(27);
delay(50);
lcd.write(69);
delay(50);
lcd.write(255);
delay(50);
delay(50);
IPHeadcodechar = '5'; break; }
if (key == '1' && IPHeadcodechar == '6') {
lcd.write(27);
delay(50);
lcd.write(70);
delay(50);
lcd.write('1');
delay(50);
IPHeadcodeENT5 = '1';
delay(50);
IPHeadcodechar = '7';}
if (key == '2' && IPHeadcodechar == '6') {
lcd.write(27);
delay(50);
lcd.write(70);
delay(50);
lcd.write('2');
delay(50);
IPHeadcodeENT5 = '2';
delay(50);
if (key == '3' && IPHeadcodechar == '6') {
lcd.write(27);
delay(50);
lcd.write(70);
delay(50);
lcd.write('3');
delay(50);
IPHeadcodeENT5 = '3';
delay(50);
if (key == '4' && IPHeadcodechar == '6') {
lcd.write(27);
delay(50);
lcd.write(70);
delay(50);
lcd.write('4');
delay(50);
IPHeadcodeENT5 = '4';
delay(50);
if (key == '5' && IPHeadcodechar == '6') {
lcd.write(27);
delay(50);
lcd.write(70);
delay(50);
lcd.write('5');
delay(50);
IPHeadcodeENT5 = '5';
delay(50);
if (key == '6' && IPHeadcodechar == '6') {
lcd.write(27);
delay(50);
lcd.write(70);
delay(50);
lcd.write('6');
delay(50);
IPHeadcodeENT5 = '6';
delay(50);
if (key == '7' && IPHeadcodechar == '6') {
lcd.write(27);
delay(50);
lcd.write(70);
delay(50);
lcd.write('7');
delay(50);
IPHeadcodeENT5 = '7';
delay(50);
if (key == '8' && IPHeadcodechar == '6') {
lcd.write(27);
delay(50);
lcd.write(70);
delay(50);
lcd.write('8');
delay(50);
IPHeadcodeENT5 = '8';
delay(50);
if (key == '9' && IPHeadcodechar == '6') {
lcd.write(27);
delay(50);
lcd.write(70);
delay(50);
lcd.write('9');
delay(50);
IPHeadcodeENT5 = '9';
delay(50);
if (key == '0' && IPHeadcodechar == '6') {
lcd.write(27);
delay(50);
lcd.write(70);
delay(50);
lcd.write('0');
delay(50);
IPHeadcodeENT5 = '0';
delay(50);
if (IPHeadcodechar == '7') {
do {
if (key == 'x' && IPHeadcodechar == '7') {
lcd.write(27);
delay(50);
lcd.write(70);
delay(50);
lcd.write(255);
delay(50);
delay(50);
IPHeadcodechar = '6'; break; }
if (key == '1' && IPHeadcodechar == '7') {
lcd.write(27);
delay(50);
lcd.write(71);
delay(50);
lcd.write('1');
delay(50);
IPHeadcodeENT6 = '1';
delay(50);
IPHeadcodechar = '8';}
if (key == '2' && IPHeadcodechar == '7') {
lcd.write(27);
delay(50);
lcd.write(71);
delay(50);
lcd.write('2');
delay(50);
IPHeadcodeENT6 = '2';
delay(50);
if (key == '3' && IPHeadcodechar == '7') {
lcd.write(27);
delay(50);
lcd.write(71);
delay(50);
lcd.write('3');
delay(50);
IPHeadcodeENT6 = '3';
delay(50);
if (key == '4' && IPHeadcodechar == '7') {
lcd.write(27);
delay(50);
lcd.write(71);
delay(50);
lcd.write('4');
delay(50);
IPHeadcodeENT6 = '4';
delay(50);
if (key == '5' && IPHeadcodechar == '7') {
lcd.write(27);
delay(50);
lcd.write(71);
delay(50);
lcd.write('5');
delay(50);
IPHeadcodeENT6 = '5';
delay(50);
if (key == '6' && IPHeadcodechar == '7') {
lcd.write(27);
delay(50);
lcd.write(71);
delay(50);
lcd.write('6');
delay(50);
IPHeadcodeENT6 = '6';
delay(50);
if (key == '7' && IPHeadcodechar == '7') {
lcd.write(27);
delay(50);
lcd.write(71);
delay(50);
lcd.write('7');
delay(50);
IPHeadcodeENT6 = '7';
delay(50);
if (key == '8' && IPHeadcodechar == '7') {
lcd.write(27);
delay(50);
lcd.write(71);
delay(50);
lcd.write('8');
delay(50);
IPHeadcodeENT6 = '8';
delay(50);
if (key == '9' && IPHeadcodechar == '7') {
lcd.write(27);
delay(50);
lcd.write(71);
delay(50);
lcd.write('9');
delay(50);
IPHeadcodeENT6 = '9';
delay(50);
if (key == '0' && IPHeadcodechar == '7') {
lcd.write(27);
delay(50);
lcd.write(71);
delay(50);
lcd.write('0');
delay(50);
IPHeadcodeENT6 = '0';
delay(50);
if (IPHeadcodechar == '8') {
do {
if (key == 'x' && IPHeadcodechar == '8') {
lcd.write(27);
delay(50);
lcd.write(71);
delay(50);
lcd.write(255);
delay(50);
delay(50);
IPHeadcodechar = '7'; break; }
if (key == '/' && IPHeadcodechar == '8') { // Begin Registration
lcd.write(27);
delay(50);
lcd.write(32);
delay(50);
lcd.write(82);
delay(50);
lcd.write(101);
delay(50);
lcd.write(103);
delay(50);
lcd.write(105);
delay(50);
lcd.write(115);
delay(50);
lcd.write(116);
delay(50);
lcd.write(101);
delay(50);
lcd.write(110);
delay(50);
lcd.write(103);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(27);
delay(50);
lcd.write(73);
delay(50);
lcd.write(76);
delay(50);
lcd.write(101);
delay(50);
lcd.write(97);
delay(50);
lcd.write(100);
delay(50);
lcd.write(255);
delay(50);
lcd.write(68);
delay(50);
lcd.write(114);
delay(50);
lcd.write(105);
delay(50);
lcd.write(118);
delay(50);
lcd.write(101);
delay(50);
lcd.write(114);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(2000);
lcd.write(27);
delay(50);
lcd.write(32);
delay(50);
lcd.write(87);
delay(50);
lcd.write(97);
delay(50);
lcd.write(105);
delay(50);
lcd.write(116);
delay(50);
lcd.write(47);
delay(50);
lcd.write(99);
delay(50);
lcd.write(104);
delay(50);
lcd.write(101);
delay(50);
lcd.write(99);
delay(50);
lcd.write(107);
delay(50);
lcd.write(255);
delay(50);
lcd.write(104);
delay(50);
lcd.write(101);
delay(50);
lcd.write(97);
delay(50);
lcd.write(100);
delay(50);
lcd.write(255);
delay(50);
lcd.write(99);
delay(50);
lcd.write(111);
delay(50);
lcd.write(100);
delay(50);
lcd.write(101);
delay(50);
Serial.print("Driver of "); // request registration
Serial.print(IPHeadcodeENT0);
Serial.print(IPHeadcodeENT1);
Serial.print(IPHeadcodeENT2);
Serial.print(IPHeadcodeENT3);
Serial.print(" is attempting to register at signal ");
Serial.print(IPHeadcodeENT4);
Serial.print(IPHeadcodeENT5);
Serial.print(IPHeadcodeENT6);
Serial.print(" Accept Y/N? ");
IPHeadcodechar = '9'; }
if (IPHeadcodechar == '9') {
do { //look for conformation
if (key == 'Y' && IPHeadcodechar == '9') { // registration granted
delay(2000);
lcd.write(27);
delay(50);
lcd.write(64);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(27);
delay(50);
lcd.write(32);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
RHeadcode[0] = IPHeadcodeENT0;
delay(50);
RHeadcode[1] = IPHeadcodeENT1;
delay(50);
RHeadcode[2] = IPHeadcodeENT2;
delay(50);
RHeadcode[3] = IPHeadcodeENT3;
delay(50);
key = '#';
RHeadcodeE = '1';
IPHeadcode = '2';
if (key == 'N' && IPHeadcodechar == '9') { // registration denined
delay(2000);
lcd.write(27);
delay(50);
lcd.write(32);
delay(50);
lcd.write(82);
delay(50);
lcd.write(101);
delay(50);
lcd.write(103);
delay(50);
lcd.write(105);
delay(50);
lcd.write(115);
delay(50);
lcd.write(116);
delay(50);
lcd.write(114);
delay(50);
lcd.write(97);
delay(50);
lcd.write(116);
delay(50);
lcd.write(105);
delay(50);
lcd.write(111);
delay(50);
lcd.write(110);
delay(50);
lcd.write(255);
delay(50);
lcd.write(102);
delay(50);
lcd.write(97);
delay(50);
lcd.write(105);
delay(50);
lcd.write(108);
delay(50);
lcd.write(101);
delay(50);
lcd.write(100);
delay(50);
lcd.write(255);
delay(50);
IPHeadcodechar = 'X';
do {
if (key == 'x' && IPHeadcodechar == 'X') { // return
key = '#';
lcd.write(27);
delay(50);
lcd.write(32);
delay(50);
lcd.write(82);
delay(50);
lcd.write(101);
delay(50);
lcd.write(103);
delay(50);
lcd.write(105);
delay(50);
lcd.write(115);
delay(50);
lcd.write(116);
delay(50);
lcd.write(114);
delay(50);
lcd.write(97);
delay(50);
lcd.write(116);
delay(50);
lcd.write(105);
delay(50);
lcd.write(111);
delay(50);
lcd.write(110);
delay(50);
lcd.write(255);
delay(50);
lcd.write(99);
delay(50);
lcd.write(111);
delay(50);
lcd.write(100);
delay(50);
lcd.write(101);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(27);
delay(50);
lcd.write(64);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
break; }
} while (IPHeadcodechar == 'X'); }
} while (IPHeadcodechar == '9'); }
} while (IPHeadcodechar == '8'); }
} while (IPHeadcodechar == '7'); }
} while (IPHeadcodechar == '6'); }
} while (IPHeadcodechar == '5'); }
} while (IPHeadcodechar == '4'); }
} while (IPHeadcodechar == '3'); }
} while (IPHeadcodechar == '2'); }
} while (IPHeadcodechar == '1'); }
// end of Headcode entry
if (GSMRState == '2' && IPHeadcode == '3' && RHeadcode[3] != ' ') { // deregistration
lcd.write(27);
delay(50);
lcd.write(32);
delay(50);
lcd.write(67);
delay(50);
lcd.write(111);
delay(50);
lcd.write(110);
delay(50);
lcd.write(102);
delay(50);
lcd.write(105);
delay(50);
lcd.write(114);
delay(50);
lcd.write(109);
delay(50);
lcd.write(255);
delay(50);
lcd.write(100);
delay(50);
lcd.write(101);
delay(50);
lcd.write(114);
delay(50);
lcd.write(101);
delay(50);
lcd.write(103);
delay(50);
lcd.write(105);
delay(50);
lcd.write(115);
delay(50);
lcd.write(116);
delay(50);
lcd.write(101);
delay(50);
lcd.write(114);
delay(50);
lcd.write(63);
delay(50);
do {
if (key == '/' && IPHeadcode == '3' && RHeadcode[3] !=' ') { //confirm deregistration
lcd.write(27);
delay(50);
lcd.write(32);
delay(50);
lcd.write(68);
delay(50);
lcd.write(101);
delay(50);
lcd.write(114);
delay(50);
lcd.write(105);
delay(50);
lcd.write(103);
delay(50);
lcd.write(105);
delay(50);
lcd.write(115);
delay(50);
lcd.write(116);
delay(50);
lcd.write(101);
delay(50);
lcd.write(114);
delay(50);
lcd.write(105);
delay(50);
lcd.write(110);
delay(50);
lcd.write(103);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(2000);
IPHeadcode = '0';
RHeadcode[0] = ' ';
RHeadcode[1] = ' ';
RHeadcode[2] = ' ';
RHeadcode[3] = ' ';
RHeadcodeE = '1';
lcd.write(27);
delay(50);
lcd.write(32);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50); key = '#'; break; }
if (key == 'x' && IPHeadcode == '3' && RHeadcode[3] !=' ') { //cancel deregistration
lcd.write(27);
delay(50);
lcd.write(32);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255);
delay(50);
lcd.write(255); key = '#';
IPHeadcode = '2';
break; }
} while (IPHeadcode = '3');
} while (GSMRState == '2'); //home screen
