Hello everyone !
I'm the happy owner of an old analog Korg BX3 drawbar organ, and i want to add some digital control over it.
A guy called Michael Wiebusch already did some heavy work on a CX3 (the BX3 is basically two CX3 in one) and managed to put a midi output on his baby. Here is the link for this
What i did understand regarding these scanner ICs is that they act like shift register, storing 61 inputs (each note of the keyboard) and feeding them to the tone generator depending on a timing process that look a bit like SPI.
The clock signal (T), wich trigger one after the other the 65 bits stored into the shift register, has a cycle of 20us, and the beginning of the counting sequence (U, falling edge) happens every 65 cycles (1.3ms).
Here is the code from Michael Wiebusch :
// midi4cx-3
// Add a MIDI output to the most famous compact hammond clone!
// Copyright (C) 2011 Michael Wiebusch
// Visit http://acidbourbon.wordpress.com for more information to this
// and other projects of mine!
// This is free software, licensed under the terms of the GNU General
// Public License as published by the Free Software Foundation.
#define F_CPU 16e6 // use 16 MHz quartz or crystal resonator ONLY, timing is critical!
#include <avr/io.h>
#include <util/delay.h>
#include <avr/interrupt.h>
// defines the input pins for the serial data signals e.g. clock (C), data (D), sync (U)
#define KORG_PORT PORTB
#define KORG_PIN PINB
#define KORG_DDR DDRB
#define KORG_D 3
#define KORG_C 2
#define KORG_U 4
#define KORG_PED 1
// initializes the USART, sets the baudrate compliant with MIDI standard
void init_USART(void)
UCSRB |= (1<<TXEN);
UCSRC |= (3<<UCSZ0); //(1<<URSEL)|
UBRRH = 0;
UBRRL = 31;
// ############################# buffer stuff ##############################
// basic buffer read and write functions
#define SUCCESS 1
#define FAIL 0
#define BUFFER_SIZE 64 // size has to be 2^n (8, 16, 32, 64 ...)
#define BUFFER_MASK (BUFFER_SIZE-1)
struct Buffer {
uint8_t data[BUFFER_SIZE];
uint8_t read;
uint8_t write;
} buffer = {{}, 0, 0};
uint8_t BufferIn(uint8_t byte)
uint8_t next = ((buffer.write + 1) & BUFFER_MASK);
if (buffer.read == next)
return FAIL;
buffer.data[buffer.write] = byte;
// buffer.data[buffer.write & BUFFER_MASK] = byte; // more secure
buffer.write = next;
return SUCCESS;
uint8_t BufferOut(uint8_t *pByte)
if (buffer.read == buffer.write)
return FAIL;
*pByte = buffer.data[buffer.read];
buffer.read = (buffer.read+1) & BUFFER_MASK;
return SUCCESS;
//############################ main #####################################
int main (void) {
// initialize our variables
uint8_t temp,temp_,dummy,counter,kdata, memory, event_flag, idle_flag, note, transpose, i, temp_ped;
uint8_t keys_pressed[9];
// set data direction for the port we use
KORG_DDR &= ~( 1<<KORG_C || 1<<KORG_D || 1<<KORG_U || 1<<KORG_PED ); // all inputs
KORG_PORT &= ~( 1<<KORG_C || 1<<KORG_D || 1<<KORG_U); // data lines no pullup
KORG_PORT |= 1<<KORG_PED; // pedal with pullup
temp = 0;
temp_ = 0;
counter =0;
kdata =0;
event_flag = 0;
keys_pressed[0] = 0;
transpose = 0;
temp_ped = 0xFF;
//activate serial transmitter
init_USART();
_delay_ms(300);
//main loop
while(1)
// read in Messages from Korg-Organ keyboard serial data stream
temp_ = temp;
temp = ~(KORG_PIN); // invert back to revert effect of hardware inverters
// wait for the sync signal, then continue your usual business
//(falling edge of KORG_U marks the beginning of the 65 bit serial data package)
// falling edge comes around every 1.2 ms
if( counter == 0 )
while( temp & (1<<KORG_U) )
temp_ = temp;
temp = ~(KORG_PIN);
counter = 1;
// look for rising edge of clock and then read in state of current key / key no. counter
// rising edge comes around every 20µs
if( ((temp&(temp^temp_))&(1<<KORG_C)) )
// write serial data in storage array to compare with next round
if(counter%8 == 0 || counter ==1)
memory = keys_pressed[counter/8];
keys_pressed[counter/8] = 0;
kdata = ((temp&(1<<KORG_D))>>KORG_D) << (counter%8);
keys_pressed[counter/8] |= kdata ;
// have keys been pressed or released in meantime? ignore the non-key-specific bits in the sequence
if( (kdata ^ memory)& (1<<(counter%8)) && ((counter <=63) && (counter >=1) && ((counter <=31)||(counter>=34)) ) )
// set program flow flags
event_flag = 1;
idle_flag = 0;
// convert counter data to midi note (Korg scan code specific)
/* this is a bit odd here, explaination:
the µC running at 16 MHz is too slow to read and store the status of a single key
in the given 20 µs.
The loop takes a bit longer than 20 µs but in every case less than 40 µs. So
every second clock pulse is skipped, resulting in reading only the even keys.
Due to the sequence being 65 bit long (an odd number), the sync signal is ignored
and now the odd keys are read.
So in short: 2 scan cycles by the KORG equals one "interlaced" scan cycle by the
microcontroller.
if(counter <= 31)
note = transpose + 98 - counter*2;
note = transpose + 101 -(counter-31)*2;
if(kdata)
// event on key on: write MIDI data equivalent to the pressed key into the buffer
BufferIn(0x90); //Note ON
BufferIn(note); //Note
BufferIn(64); //Velocity 0-127
//event on key off: same thing, send "key relesed"-signal to the buffer
BufferIn(0x80); //Note OFF
BufferIn(0x00); //Velocity: 0
else if ( counter == 64 )
if ((temp^temp_ped)&(1<<KORG_PED))
event_flag = 1;
idle_flag = 0;
if (temp&(1<<KORG_PED))
BufferIn(0b10110000); //Control Change
BufferIn(64); //Sustain/Damper Pedal
BufferIn(127); //off
BufferIn(0); //on
temp_ped = temp;
idle_flag = 1;
counter = (counter + 1) % 65;
// Send Midi to USART
// controlled by even_flag and idle_flag: every time that at the current scan position
// no key event has occured, check the midi data buffer for content, and if there is
// something send it via the USART
if(event_flag && idle_flag && counter)
if(UCSRA & (1<<UDRE) )
if( BufferOut(&dummy) )
UDR = dummy;
event_flag=0;
return 0;
He says at the end of his tutorial that there can be sync issue with his code and some newer version of gcc-avr... But I don't know what it is, and if I can use his code like it is now.
And I have still how to figure to do the opposite thing : playing the tone generator from the computer.
Is there some ICs that can store 65 bits messages sent from arduino, and stream these bits depending on a external counter clock ?
Also, i'm using MaxMSP to interface with Arduino via serial port, so raw data can be ok and i don't need midi. I just want arduino as a translater, the core of the processing will be within Max.
Sorry for my empirical knowledge on this subject, and thank you for your help !
