Hey,
I have a football table game. I want to have an automatic digital score board on it.
I am using a break beam at each goal (one at each end of the field).
I am also using an Arduino. And digit display.
I have the parts but I don't know how to wire them up to the Arduino and I don't know how to program the Arduino.
I know there is a similar topic on here, but it is using different parts.
So I am a beginner. I know I can do this, but I just need some help from the pro's please.
Here are the parts I have already.
Go to this link wokwi-74hc595 Reference | Wokwi Docs to familiarize yourself with the 74HC595 shift register. It's a simulator so there's no need for breadboard and jumper wires.
There are also lots of 74HC595 libraries so you can offload some of the nitty gritty parts of coding.
Thank you. They are very helpful. There is one video I haven’t watched yet.
I am also hoping to get some step by step for dummies. Like Step 1. 5 volt power connects to 5 volt Arduino for example.
Thank you again
Question. Why has he used resistors in the circuit in the video please?
Also with the Arduino. Where do I put the break beam sensor wire. I assume it goes into the digital pwm. But which one, for example some are 2, others are ~3 what is this symbol ~ can I use it, or don’t use. Thank you
I think dot matrix will be better because with seven segment displays, you can show numbers only. If you use dot matrix display, you'll be able to show other info like the names of the teams, names of the players who are playing, who score goals etc.
Should I get Arduino Uno Rev 3 SMD ATmega328P, 14 digital input/output pins
or Arduino UNO Rev 4 Minima Development Board 48MHz Arm Cortex-M4 microprocessor with FPU RTC - MPU - DAC - 256 kB Flash Memory - 32 kB SRAM - 8 kB EEPROM
One is a development board. Somebody recommended the Minima one. I don't know why.
Thanks
I would suggest a clone of the ATmega328P version of the NANO. It has the same functions as the UNO R3 but with (in my opinion) an easier to use form factor. It has enough capability to do what you want.
Are the 2 board terminals next to the component Vcc and GND?
If so, it may not be too much of a problem. That component looks like a bypass capacitor and will be connected across Vcc and GND tracks. So if you accidentally make solder bridges between the cap and the board terminals, no problem. Just don't make a solder bridge across the cap's terminals, or you will get a short circuit!
