Digital input with a pushbutton
I am not sure what you are trying to say
Upload this sketch
    for (int p = 2; p < 13; p++)
        pinMode(p, INPUT_PULLUP);
        Serial.print("pin : ");
        Serial.print(p);
        Serial.print("\t\t");
        Serial.println(digitalRead(p) == HIGH ? "HIGH" : "LOW");
Remove everything connected to the Uno and open the Serial monitor and set it to 115200 baud. You should see HIGH reported for pins 2 to 12
Use a jumper to connect each pin 2 to 12 in turn to GND. For the pin connected to GND you should see LOW reported
It shows LOW for every pin
If it shows LOW for every pin when nothing is connected to any of them then your Uno is broken
What happens when you upload the Blink sketch to it ?
