OK. Went and looked it up again. This is the working version. No dimming, but I changed the delay times.
it's set up to take simulated input from monitor. I'm still trying to convert from BASIC so some things are still a little odd.
//lightbar LED tach fo VW
//pin 2-5 group
//pins 6-10 bulb
//pin 13 RPM input
//v3 re-work timers
unsigned long
MemTime,
PulseTHi,
PulseTLo;
//slightly simpler code, poss. mixed pin order
int Neg[ 21 ] = { 0,2,2,2,2,2,3,3,3,3,3,4,4,4,4,4,5,5,5,5,5 } ;
int Pos[ 21 ] = { 0,6,7,8,9,10,6,7,8,9,10,6,7,8,9,10,6,7,8,9,10};
int
ReadNowTimer = 0,
HiRangeTimer = 0,
MemTimer = 0,
intPeak,
intHold,
intMem,
intPower; //not yet used
bool
ReadNowFlag = true,
HiRangeFlag = false,
MemFlag = false,
BlinkFlag=false,
DimFlag=false;//not yet used
const int SignalPin =13, DimmerPin = 12;
for (int i=1;i<=5;i++){ //see v2 dfor old loop
if (i<5){
pinMode(Neg[i*5], OUTPUT);
digitalWrite(Neg[i*5], HIGH);
pinMode(Pos[i], OUTPUT);
digitalWrite(Pos[i], LOW);
//LED test
for (int j = 1;j<75;j++){
for (int i=1;i<21;i++){
digitalWrite(Neg[i], LOW);
digitalWrite(Pos[i], HIGH);
delay(1);
digitalWrite(Neg[i], HIGH);
// ----- configure Timer 2 to generate a compare-match interrupt every 1mS
noInterrupts(); // disable interrupts
TCCR2A = 0; // clear control registers
TCCR2B = 0;
TCCR2B |= (1 << CS22) | // 16MHz/128=8uS
(1 << CS20) ;
TCNT2 = 0; // clear counter
OCR2A = 125 - 1; // 8uS*125=1mS (allow for clock propagation)
TIMSK2 |= (1 << OCIE2A); // enable output compare interrupt
interrupts(); // enable interrupts
// prep monitor REM it out
Serial.println ("input value in hz 0-165 (+ enter)");
Serial.setTimeout(10);
if (ReadNowFlag) {intPeak = ReadSpeed();}
if (intPeak==0) {StandBy();}
do{ // see v2 for old loop
if (BlinkFlag==false){
for(int Cnt=1;Cnt<=intPeak;Cnt++){
digitalWrite(Neg[Cnt], LOW);
digitalWrite(Pos[Cnt], HIGH); //this was delay(1), changed totry dimming.
delayMicroseconds(700); //700&100 w 200us delay?
digitalWrite(Neg[Cnt], HIGH);
digitalWrite(Pos[Cnt], LOW);
delayMicroseconds(200);
if (MemFlag){ //flash mem light
//int Neg=(intHold-1)/5+GroupStart; //-1)/4+1;
//int Pos=(intHold-1)%5+BulbStart; //1)%4+6;
digitalWrite(Neg[intHold], LOW);
digitalWrite(Pos[intHold], HIGH);
delay(1);
digitalWrite(Neg[intHold], HIGH);
digitalWrite(Pos[intHold], LOW);
if (HiRangeFlag){ //lite last LED if Hi range
digitalWrite(Neg[20], LOW);
digitalWrite(Pos[20], HIGH);
delay(1);
digitalWrite(Neg[20], HIGH);
digitalWrite(Pos[20], LOW);
}while (ReadNowFlag==false); //read every 1/4 sec
int ReadSpeed(){
int x;
static int intOldInput;
1000RPM=500*4=2000 pulse/min=33.33pulse/sec (hz)
new lay-out oo0oooo0oooo0oooo0oo
1k 1.5 2k 2.5
1k 2 3 4
Lo 1-2.5k, ea LED=100 RPM =3.33hz: start 800 rpm, 27hz
Hi 1-4k, ea LED=200 RPM =6.67hz: start 600 RPM, 53hz // Hi 2-5k, ea LED=200 RPM =6.67hz: start 1600 RPM, 53hz overlap 1600-2700
//PulseTHi=pulseIn(13,HIGH,100000); //rem'd for test
//PulseTLo=pulseIn(13,LOW,100000);
//x=1080000/(PulseTHi+PulseTLo);//in hz
// fix, 999 RPM truncates to lower rather than round up
//temp for test
if (Serial.available() > 0) {
x = Serial.parseInt();
intOldInput=x;
Serial.print("new input ");
Serial.println(x);
else {
x=intOldInput;
Serial.print("a ");
Serial.println(x);
if (x !=0) {
x=(x/3.3)+.5; // hz>100rpm (+.5 to rnd up) //x=x/4-1; //in LEDs
//Serial.print("aa ");
//Serial.println(x);
if (x>27|| HiRangeFlag) { // if is or was HI
if (x>27) { // if still Hi re-set timer
HiRangeTimer=0;
HiRangeFlag=true;
x=x/2-2; //re-scale, RPM>LEDs (-2, LEDs start @600, <------------------------ ****change here to go 2000-5000 scale**** --------------------------
else {
x=x-7; //LEDs start @800
if (HiRangeFlag) {
intMem=intMem/2;//-.5; //re-scale if down scaled
if (x<1) {x=1; BlinkFlag = !BlinkFlag;} // always have at least 1 lit, bink if off scale //toggling flag gives 1/2" blink
else if (x>20) {x=20; BlinkFlag = !BlinkFlag;}
else {
BlinkFlag=false;
if (x<intMem-2){ //2 LEDs less
MemFlag=true;
intHold=intMem;
intMem=x;
ReadNowFlag=false;
//Serial.print("c ");
return x;
void StandBy(){
//EndlessLoop: //cylon effect
while (intPeak==0){
for(int Cnt=2;Cnt<=20;Cnt++){ //2,19: skip first/last for better effect
digitalWrite(Neg[Cnt], LOW); //see v2 dfor old loops
delay(50); //delay ok here as prog isn't doing anything.
for(int Cnt=19;Cnt>=1;Cnt--){
delay(50);
intPeak=ReadSpeed();
//goto EndlessLoop;
// return;
// task scheduler (1mS interrupt)
ISR(TIMER2_COMPA_vect)
// ----- timers
Each timer counts the number of milliseconds since its associated task was
last performed. Each additional task requires another timer and flag.
ReadNowTimer++;
if (HiRangeFlag){HiRangeTimer++;}
if (MemFlag){MemTimer++;}
// ----- task1
if (ReadNowTimer > 125 - 1) { // read @ 1/8 sec. (was 250ms
ReadNowTimer = 0;
ReadNowFlag = true;
// ----- task2
if (HiRangeTimer > 5000 - 1) { // change range
HiRangeTimer = 0;
HiRangeFlag = false;
// ----- task3
if (MemTimer > 1500 - 1) { // Mem lite
MemTimer = 0;
MemFlag = false;
intHold=0;
intMem=0;
/*RPM HZ leds
500 17 0 1700 57 10 3000 100 22
600 20 1800 60 11 3200 107 23
700 23 1900 63 12 3400 113 24
800 27 1 2000 67 13* 3600 120 25
900 30 2 2100 70 14 3800 127 26
1000 33 3* 2200 73 15 4000 133 24
1100 37 4 2300 77 16 4200 140
1200 40 5 2400 80 17 4400 147
1300 43 6 2500 83 18* 4600 153
1400 47 7 2600 87 19 4800 160
1500 50 8* 2700 90 20 5000 167
1600 53 9 2800 93 21
old lay-out o o 0 o o o 0 o o o 0 o o o 0 o o o 0 o
1000 1250 1500 1750 2000
1000 2000 3000 4000 5000
Hi 5k, ea LED=250RPM =8.3hz: start 750 RPM, 25hz
Lo 2k, ea LED=62.5RPM =2.08hz:start 875(1) or 940(2)
or 500-2500rpm (halve it?
Med(?) 3k led=125RPM = 4.17hz: start 750(1) or 875(2)
