disable a button input unitll another pressed
Hello every one, any suguestions, :slight_smile:
As you may see by my sketch, this has three buttons, foward, stop reverse, when press forward run till count is reached then stops, same when press reverse, one question if moves forward and stops when count reached , how can i prevent from moving forward again, and the only direction allowed to move is reverse.
#include <Button.h>
#include <EEPROM.h> // 23/8/11
Button in = Button(4,PULLUP); // keeps pin 4 high waitng for low to trip
Button halt = Button(5,PULLUP); // keeps pin 5 high waiting for low o trip
Button out = Button(6,PULLUP); // keeps pin 6 high waiting for low to trip
int pulsePin = 3; // hall effetc input pin 3
unsigned long counter = 0;
unsigned long duration = 0;
unsigned long timeout = 1000000; // in microseconds
unsigned long howfar = 400; // how far to travel till stops motor
int value;
void setup(){
EEPROM.write(1,howfar); // 23/8/11 write value of howfar to eeprom loaction 1
value = EEPROM.read(1); // read eeprom address 1 and call it value
pinMode (13,OUTPUT); // new 17/08/11 use led on pcb to warn that calibration about to start
pinMode(11,OUTPUT); // changes direction of motor
pinMode(10,OUTPUT); // turns main relay power on
pinMode(pulsePin, INPUT);
digitalWrite(pulsePin, HIGH); // enable the 20K pull-up resistor to steer the input pin to a HIGH reading.
Serial.begin(9600); // open serial port
void loop(){
if(in.isPressed()){digitalWrite(10,HIGH); // forward switch
digitalWrite(11,LOW) ;}
if(halt.isPressed()){digitalWrite(10,LOW);} // stop switch
if(out.isPressed()){digitalWrite(10,HIGH); // reverse switch
digitalWrite(11,HIGH);}
// calabration start here, eg move motor back till end stop reached, reset counter 2 , move motor till other end
// stop reached, memorise total count, return motor back to start position,
duration = pulseIn(pulsePin, HIGH, timeout);
if (duration == 0) {
Serial.println("");
counter++;
Serial.print(counter); // so i can monitor count pulses etc in serial monitor
Serial.println("");
if (digitalRead(11) == HIGH && (counter>=value)){ // if count reached, checks where relays are
digitalWrite(11,LOW); // reverse polarty for 10ms then turns pwr relay off.
delay(10); // need this to stop 1 pulse ove count to prevet run on
if(digitalRead(11) == LOW && (counter>=value)){ // if count reached checks relays for polarity and switches
digitalWrite(11,HIGH); // them in reverse for 10ms, then turns pwr relay off.
delay(10); // need this to stop over run from count that stops on
digitalWrite(10,LOW);};
if(counter>=value){ //reset counter when distance reached
counter = 0;
Hard to control the device as presented - you mention end stops in the code - they would help you make decisions about which buttons should be usable at any given point. Without them, all you can do is make assumptions that you know where the device is. Keep a state variable telling you whether you're moving in or out and use your counter to tell you how far you've gone. When you get a button press, use counter to tell you whether you're at either end of the travelling range - if you're all the way forward, ignore additional forward pressing, same for back. This'll need your calibration routine to be implemented in setup though so you know your starting point.
When you see something like this:}}} } in a sketch, then it is time to learn about and use the auto-format tool (ctrl-t) in the IDE.
When posting code, please use the "#" icon on the editor's toolbar/
#include <Button.h>
int value;
void setup(){
void loop(){
  if(in.isPressed()){
  }                          // stop switch
    Serial.println("");
  else {
    counter++;
    Serial.println("");
        counter = 0;
What? You are writing 1 byte of a 4 byte variable to EEPROM, then reading that one byte and storing it in a 2 byte variable.
Why are you using EEPROM at all? Why are you switching sizes? Why are you not writing/reading properly?
On second thought, just use counter as a position indicator. Set it in calibration, then increment it on forward ticks of the hall sensor, decrement it when going backwards. On that point, consider using an interrupt to ensure you don't miss anything from the hall.
  1. using eeprom, i have not used before, it is the start of my calibration program, which the plan is to
    a) mover motor in reverse till no pulse detected.
    b) reset couneter
    c) move forward till no pulses detected.
    d) store max pulses in memory.
    e) then return to start position (where counter was reset)
i will add a pot so if pot was at 50% the motor would only move 50%.
