Display is not showing the correctly
Hi
I have some issues with my display max7219.
It does not show corretly.
I am trying to build the selfie boks from diy machines: Arduino powered automated party Photo Booth
Video of the issue and the code is here:
https://www.icloud.com/iclouddrive/087Zfm2gZgy2gRjGlIJgSqr8Q#sketch_mar21a-kopi
hi, I see you're having trouble with the max7219, luckily I the same module!
do you have "LedControl.h"?
Hi, @kimx1234
Welcome to the forum.
Can you please post your code in a new post?
I do not want to sign in with Apple, some platforms here do not like off forum links to files.
Thanks.. Tom.. :smiley: :+1: :coffee: :australia:
No I do not have LedControl.h.
How do I get that file and how do I implement it with the other files?
Thank you for welcoming me :slight_smile:
I have three code files
One:
sketch_mar21a.ino
int shutterPin = 12;
int buttonPin = 8;
int buttonVal = 0;  //somewhere to store the button state
int BUTTONLED = 9;
#define NUM_MAX 4
#define ROTATE 270
#define DIN_PIN 11  //
#define CS_PIN  10  //
#define CLK_PIN 13  //
#include "max7219.h"
#include "fonts.h"
Serial.begin(9600); // open the serial port at 9600 bps:
pinMode(shutterPin, OUTPUT);
digitalWrite(shutterPin, HIGH);
pinMode(BUTTONLED, OUTPUT);
digitalWrite(BUTTONLED, HIGH);
pinMode(buttonPin, INPUT);
digitalWrite(buttonPin, HIGH);   //enable internal pull up resistor
initMAX7219();
  sendCmdAll(CMD_SHUTDOWN,1);
  sendCmdAll(CMD_INTENSITY,15);
buttonVal = digitalRead(buttonPin);
Serial.println(buttonVal);
delay(200);
if (buttonVal == LOW) {
  digitalWrite(BUTTONLED, LOW);
  takePhoto();
  printStringWithShift("2 LEFT",0);
  delay(2000);
  takePhoto();
  printStringWithShift("LAST 1",0);
  delay(2000);
  takePhoto();
  printStringWithShift("DONE",0);
  delay(3000);
  printStringWithShift("           ",0);
int showChar(char ch, const uint8_t *data)
  int len = pgm_read_byte(data);
  int i,w = pgm_read_byte(data + 1 + ch * len);
  for (i = 0; i < w; i++)
    scr[NUM_MAX*8 + i] = pgm_read_byte(data + 1 + ch * len + 1 + i);
  scr[NUM_MAX*8 + i] = 0;
  return w;
void printCharWithShift(unsigned char c, int shiftDelay) {
  if (c < ' ' || c > MAX_CHAR) return;
  c -= 32;
  int w = showChar(c, font);
  for (int i=0; i<w+1; i++) {
    delay(shiftDelay);
    scrollLeft();
    refreshAll();
void printStringWithShift(const char* s, int shiftDelay){
  while (*s) {
    printCharWithShift(*s++, shiftDelay);
void takePhoto() {
    printStringWithShift("          10          9           8          7         6         5        4         3        2         1         ",20);
  printStringWithShift("SMILE",0);
  digitalWrite(shutterPin, LOW);    // turn the LED off by making the voltage LOW
two
max7219.h
// MAX7219 functions by Pawel A. Hernik
// MAX7219 commands:
#define CMD_NOOP   0
#define CMD_DIGIT0 1
#define CMD_DIGIT1 2
#define CMD_DIGIT2 3
#define CMD_DIGIT3 4
#define CMD_DIGIT4 5
#define CMD_DIGIT5 6
#define CMD_DIGIT6 7
#define CMD_DIGIT7 8
#define CMD_DECODEMODE  9
#define CMD_INTENSITY   10
#define CMD_SCANLIMIT   11
#define CMD_SHUTDOWN    12
#define CMD_DISPLAYTEST 15
byte scr[NUM_MAX*8 + 8]; // +8 for scrolled char
void sendCmdAll(byte cmd, byte data)
  digitalWrite(CS_PIN, LOW);
  for (int i = NUM_MAX-1; i>=0; i--) {
    shiftOut(DIN_PIN, CLK_PIN, MSBFIRST, cmd);
    shiftOut(DIN_PIN, CLK_PIN, MSBFIRST, data);
  digitalWrite(CS_PIN, HIGH);
void refreshAllRot270()
  byte mask = 0x01;
  for (int c = 0; c < 8; c++) {
    for(int i=NUM_MAX-1; i>=0; i--) {
      byte bt = 0;
      for(int b=0; b<8; b++) {
        bt<<=1;
        if(scr[i * 8 + b] & mask) bt|=0x01;
      shiftOut(DIN_PIN, CLK_PIN, MSBFIRST, CMD_DIGIT0 + c);
      shiftOut(DIN_PIN, CLK_PIN, MSBFIRST, bt);
    mask<<=1;
void refreshAllRot90()
  byte mask = 0x80;
      byte bt = 0;
        bt>>=1;
        if(scr[i * 8 + b] & mask) bt|=0x80;
    mask>>=1;
void refreshAll() {
#if ROTATE==270
  refreshAllRot270();
#elif ROTATE==90
  refreshAllRot90();
#else
      shiftOut(DIN_PIN, CLK_PIN, MSBFIRST, scr[i * 8 + c]);
#endif
void clr()
  for (int i = 0; i < NUM_MAX*8; i++) scr[i] = 0;
void scrollLeft()
  for(int i=0; i < NUM_MAX*8+7; i++) scr[i] = scr[i+1];
void invert()
  for (int i = 0; i < NUM_MAX*8; i++) scr[i] = ~scr[i];
void initMAX7219()
  pinMode(DIN_PIN, OUTPUT);
  pinMode(CLK_PIN, OUTPUT);
  pinMode(CS_PIN, OUTPUT);
  sendCmdAll(CMD_DISPLAYTEST, 0);
  sendCmdAll(CMD_SCANLIMIT, 7);
  sendCmdAll(CMD_DECODEMODE, 0);
  sendCmdAll(CMD_INTENSITY, 1);
  sendCmdAll(CMD_SHUTDOWN, 0);
  clr();
  refreshAll();
three:
fonts.h
#define MAX_CHAR ('~'+26)
const uint8_t font[] PROGMEM = {6,
2, B00000000, B00000000, B00000000, B00000000, B00000000, // space
1, B01011111, B00000000, B00000000, B00000000, B00000000, // !
3, B00000011, B00000000, B00000011, B00000000, B00000000, // "
5, B00010100, B00111110, B00010100, B00111110, B00010100, // #
4, B00100100, B01101010, B00101011, B00010010, B00000000, // $
5, B01100011, B00010011, B00001000, B01100100, B01100011, // %
5, B00110110, B01001001, B01010110, B00100000, B01010000, // &
1, B00000011, B00000000, B00000000, B00000000, B00000000, // '
3, B00011100, B00100010, B01000001, B00000000, B00000000, // (
3, B01000001, B00100010, B00011100, B00000000, B00000000, // )
5, B00101000, B00011000, B00001110, B00011000, B00101000, // *
5, B00001000, B00001000, B00111110, B00001000, B00001000, // +
2, B10110000, B01110000, B00000000, B00000000, B00000000, // ,
4, B00001000, B00001000, B00001000, B00001000, B00000000, // -
1, B01000000, B00000000, B00000000, B00000000, B00000000, // .
3, B01100000, B00011100, B00000011, B00000000, B00000000, // /
4, B00111110, B01000001, B01000001, B00111110, B00000000, // 0
3, B01000010, B01111111, B01000000, B00000000, B00000000, // 1
4, B01100010, B01010001, B01001001, B01000110, B00000000, // 2
4, B00100010, B01000001, B01001001, B00110110, B00000000, // 3
4, B00011000, B00010100, B00010010, B01111111, B00000000, // 4
4, B00100111, B01000101, B01000101, B00111001, B00000000, // 5
4, B00111110, B01001001, B01001001, B00110010, B00000000, // 6
4, B01100001, B00010001, B00001001, B00000111, B00000000, // 7
4, B00110110, B01001001, B01001001, B00110110, B00000000, // 8
4, B00100110, B01001001, B01001001, B00111110, B00000000, // 9
1, B01000100, B00000000, B00000000, B00000000, B00000000, // :
2, B10000000, B01010000, B00000000, B00000000, B00000000, // ;
3, B00010000, B00101000, B01000100, B00000000, B00000000, // <
3, B00010100, B00010100, B00010100, B00000000, B00000000, // =
3, B01000100, B00101000, B00010000, B00000000, B00000000, // >
4, B00000010, B01011001, B00001001, B00000110, B00000000, // ?
5, B00111110, B01001001, B01010101, B01011101, B00001110, // @
4, B01111110, B00010001, B00010001, B01111110, B00000000, // A
4, B01111111, B01001001, B01001001, B00110110, B00000000, // B
4, B00111110, B01000001, B01000001, B00100010, B00000000, // C
4, B01111111, B01000001, B01000001, B00111110, B00000000, // D
4, B01111111, B01001001, B01001001, B01000001, B00000000, // E
4, B01111111, B00001001, B00001001, B00000001, B00000000, // F
4, B00111110, B01000001, B01001001, B01111010, B00000000, // G
4, B01111111, B00001000, B00001000, B01111111, B00000000, // H
3, B01000001, B01111111, B01000001, B00000000, B00000000, // I
4, B00110000, B01000000, B01000001, B00111111, B00000000, // J
4, B01111111, B00001000, B00010100, B01100011, B00000000, // K
4, B01111111, B01000000, B01000000, B01000000, B00000000, // L
5, B01111111, B00000010, B00001100, B00000010, B01111111, // M
5, B01111111, B00000100, B00001000, B00010000, B01111111, // N
4, B00111110, B01000001, B01000001, B00111110, B00000000, // O
4, B01111111, B00001001, B00001001, B00000110, B00000000, // P
4, B00111110, B01000001, B01000001, B10111110, B00000000, // Q
4, B01111111, B00001001, B00001001, B01110110, B00000000, // R
4, B00100110, B01001001, B01001001, B00110010, B00000000, // S
5, B00000001, B00000001, B01111111, B00000001, B00000001, // T
4, B00111111, B01000000, B01000000, B00111111, B00000000, // U
5, B00001111, B00110000, B01000000, B00110000, B00001111, // V
5, B00111111, B01000000, B00111000, B01000000, B00111111, // W
5, B01100011, B00010100, B00001000, B00010100, B01100011, // X
5, B00000111, B00001000, B01110000, B00001000, B00000111, // Y
4, B01100001, B01010001, B01001001, B01000111, B00000000, // Z
2, B01111111, B01000001, B00000000, B00000000, B00000000, // [
4, B00000001, B00000110, B00011000, B01100000, B00000000, // \ backslash
2, B01000001, B01111111, B00000000, B00000000, B00000000, // ]
3, B00000010, B00000001, B00000010, B00000000, B00000000, // hat
4, B01000000, B01000000, B01000000, B01000000, B00000000, // _
2, B00000001, B00000010, B00000000, B00000000, B00000000, // `
4, B00100000, B01010100, B01010100, B01111000, B00000000, // a
4, B01111111, B01000100, B01000100, B00111000, B00000000, // b
4, B00111000, B01000100, B01000100, B00101000, B00000000, // c
4, B00111000, B01000100, B01000100, B01111111, B00000000, // d
4, B00111000, B01010100, B01010100, B00011000, B00000000, // e
3, B00000100, B01111110, B00000101, B00000000, B00000000, // f
4, B10011000, B10100100, B10100100, B01111000, B00000000, // g
4, B01111111, B00000100, B00000100, B01111000, B00000000, // h
3, B01000100, B01111101, B01000000, B00000000, B00000000, // i
4, B01000000, B10000000, B10000100, B01111101, B00000000, // j
4, B01111111, B00010000, B00101000, B01000100, B00000000, // k
3, B01000001, B01111111, B01000000, B00000000, B00000000, // l
5, B01111100, B00000100, B01111100, B00000100, B01111000, // m
4, B01111100, B00000100, B00000100, B01111000, B00000000, // n
4, B00111000, B01000100, B01000100, B00111000, B00000000, // o
4, B11111100, B00100100, B00100100, B00011000, B00000000, // p
4, B00011000, B00100100, B00100100, B11111100, B00000000, // q
4, B01111100, B00001000, B00000100, B00000100, B00000000, // r
4, B01001000, B01010100, B01010100, B00100100, B00000000, // s
3, B00000100, B00111111, B01000100, B00000000, B00000000, // t
4, B00111100, B01000000, B01000000, B01111100, B00000000, // u
5, B00011100, B00100000, B01000000, B00100000, B00011100, // v
5, B00111100, B01000000, B00111100, B01000000, B00111100, // w
5, B01000100, B00101000, B00010000, B00101000, B01000100, // x
4, B10011100, B10100000, B10100000, B01111100, B00000000, // y
3, B01100100, B01010100, B01001100, B00000000, B00000000, // z
3, B00001000, B00110110, B01000001, B00000000, B00000000, // {
1, B01111111, B00000000, B00000000, B00000000, B00000000, // |
3, B01000001, B00110110, B00001000, B00000000, B00000000, // }
4, B00001000, B00000100, B00001000, B00000100, B00000000, // ~
5, B00100000, B01010100, B01010100, B11111000, B10000000, // a
4, B00111000, B01000100, B01000110, B00101001, B00000000, // c
4, B00111000, B01010100, B11010100, B10011000, B00000000, // e
3, B01010001, B01111111, B01000100, B00000000, B00000000, // l
4, B01111100, B00000100, B00000110, B01111001, B00000000, // n
4, B00111000, B01000100, B01000110, B00111001, B00000000, // o
4, B01001000, B01010100, B01010110, B00100101, B00000000, // s
3, B01100100, B01010110, B01001101, B00000000, B00000000, // z
3, B01100100, B01010101, B01001100, B00000000, B00000000, // z
5, B01111110, B00010001, B00010001, B11111110, B10000000, // A
4, B00111100, B01000010, B01000011, B00100101, B00000000, // C
5, B01111111, B01001001, B01001001, B11000001, B10000000, // E
4, B01111111, B01001000, B01000100, B01000000, B00000000, // L
5, B01111110, B00000100, B00001010, B00010001, B01111110, // N
4, B00111100, B01000110, B01000011, B00111100, B00000000, // O
4, B00100100, B01001010, B01001011, B00110000, B00000000, // S
4, B01100010, B01010110, B01001011, B01000110, B00000000, // Z
4, B01101001, B01011001, B01001101, B01001011, B00000000, // Z
5, B00111110, B01010101, B01100001, B01010101, B00111110, // :)
5, B00111110, B01100101, B01010001, B01100101, B00111110, // :(
5, B00111110, B01000101, B01010001, B01000101, B00111110, // :o
5, 0x06, 0x1F, 0x7E, 0x1F, 0x06,   // heart
5, 0x04, 0x02, 0x7F, 0x02, 0x04,   // arrow up
5, 0x10, 0x20, 0x7F, 0x20, 0x10,   // arrow down
3, B00000010, B00000101, B00000010, B00000000, B00000000, // deg
5, B00001000, B00001000, B00101010, B00001000, B00001000, // -
here's an example of how you should make characters.
byte A[5]={
B01111110,
B10001000,
B10001000,
B10001000,
B01111110};
byte r[5]={
B00010000,
B00100000,
B00100000,
B00010000,
B00111110};
byte d[5]={
B11111110,
B00010010,
B00100010,
B00100010,
B00011100};
byte u[5]={
B00111110,
B00000100,
B00000010,
B00000010,
B00111100};
byte i[5]={
B00000000,
B00000010,
B10111110,
B00100010,
B00000000};
byte n[5]={
B00011110,
B00100000,
B00100000,
B00010000,
B00111110};
byte o[5]={
B00011100,
B00100010,
B00100010,
B00100010,
B00011100};
you might notice a pattern in the bitmaps, the bits for character you want to represent line up with the character but flipped to the left.
you might want to test:
byte A[5]={
B01111110,
B10001000,
B10001000,
B10001000,
B01111110};
to see if it works you by displaying "A".
"rotated 90 degrees left"... but your characters are rotated 90 right.
OP's characters are rotated right... as your characters are.
for example, OP's bitmap for "A" is rotated 90° to the right, it should be rotated 90° to the left, else it'll display "∀".
Thank you for your help and time!
I will test is out in the weekend
