Not sure if this is the right category to post on but I need some help.
So a project I’m creating is basically an inventory robot based on one that we use where I work but a simple version of it for school project. I require a Arduino build on top of an rc car that I can control to slowly go down aisles and count the stock on the shelves, I have 125khz rfid tags. So I just need it to list all the rfid tags it passes. My main issue is distance as a lot online require the tag to contact the reader, distance would be around a metre if not less
I want to know what I need to be able to make this possible electrical wise, so it’ll sit on an rc car and have a custom built casing for it.
I have almost 2/3 of a year so build this and need help
Would that not destroy any of the cards in the region? Would not an inventory system just want to read the cards? Anyway, looks like you are going to have a very long development time ahead of you. Are you able to build and test a series of readers/writers with increasing ranges until you get one that will work properly?
I meant like it’ll write down the ones it passes as in like make a list of the ones it passes, sorry I should of worded it better, and I’m looking for recommendations on rfid readers so I don’t have to spend heaps of money just for one to work
Here is the basic problem with your system design. How will your system ensure there are no RFID devices that that are skipped and not read by your system? That is the primary reason for any RFID device to only be active when a person is right there to ensure it is read or not read or does not produce an error message.
There are NO devices that would reliably do what you are thinking about. And reliability is the key.
Well there are heaps of devices that can do this so why don’t you go for a quick google and of course someone’s going to be there if it’s movement form is an rc car, I never said it will be perfect it is just a school project that I want to attempt to make, I understand that there are some downfalls in the system, no system is perfect but it is possible to do with some right assistance
If tags will be close together, be sure to pick a tag/reader combination with a proven anti-collision feature, and read the specifications very carefully to see if it will actually function in your hypothetical application.
