DIY sensor counter to count times a rubber ball hits a wall
Hello Everyone!
I would like to ask for some guidance for my first DIY arduino Project! I love to play all sports and often throw my lacrosse ball against the wall and catch it. My goal is to be able to use some sort of sensor to track how many times the ball hits the wall. I have been learning about all the different types of sensors I should use and I am going to be honest it is a little overwhelming.
At first, I thought I could just use a PIR sensor at the base of the wall and stand it strait up. However, this obviously didn't work because of the lack of temp difference.
So now I have taken a step back and am trying to figure out which path I should go down. These are the paths I have in mind:
Use an ultrasonic sensor or maybe a microwave sensor
use a piezo to track the vibration on the wall when the ball hits
use microphone to hear the thud of the wall when hit
or maybe even use a camera (although trying to keep costs low)
Any help is much appreciated!!
I would not use a microwave sensor; it doesn't reset fast enough. Not sure how ultrasonic would work, but try it. Piezo sounds interesting as long as you can drill into the wall and leave it there. Mic might work but will require filtering to eliminate background and focusing. Camera is not a good choice.
What material is the wall (target) made of? What is the area of the wall that the ball might hit (square meters or feet)? How big is the space (room) where the target wall is located?
Right now the wall is just a brick wall in my basement. However, I'd like to be able to move my design and have it work on multiple types of walls. The area of the wall the the ball hits it roughly a 9ftx5ft square.
There are many topics on this forum concerning a projectile and a target. Here are two (hockey puck was interesting):
Well, a brick wall eliminates vibration sensing. A microphone approach with the ball "thump" signal attenuated so random noise is not counted and filtered to catch only fast rising sound spikes might work.
Another vote for acoustic sensing. It doesn't need to be installed on the wall and it's easier/cheaper than optical sensing.
Going down the acoustic route. Is there a way to track the (thump) of the ball if sensor is moved to a different wall? Or would it have to been toned to one specific wall?
Did you ever get anywhere on this? I am wanting to do the same thing with a wooden wall but have no idea where to start.
See post #5.
I seen post 5 but what I am looking for is nothing more than a counter of everytime the ball "knocks" on the wall. I was thinking of a Piezo counter or something like that, that would just tell me how many times a ball bounced off of the wall.
Some sensors register sound (adjustable threshold) and some sensors register vibration (knock, tilt). A counter would be a program waiting for the registered sounds or vibrations.
If you use Amazon.com as a parts-search, try: arduino knock sensor, you will see a few types of knock/vibration sensors, for example:
For sound sensor (on amazon) you might see these:
