DIY USB to CV Interface Project
Here's a project that I've been working on - finally nearing completion. It's an OSC-receiving USB to CV generator. It uses Teensy, but I think there might be some interest here too.
http://gregsurges.com/circuitry/usb-octomod/
http://gregsurges.com/programming/osc-processing-microcontroller-connect-maxmsp-dac-ic/
At this point, I would appreciate any and all feedback on the project. I'm also considering doing a small run of PCBs and kits in a week or so, if there's any interest.
Thanks,
  • G
Okay, and here's a modified version which uses Arduino.
This allows a Duemilanove to replace the Teensy 2.0. It won't fit on the PCB, but I bet people can find good ways to incorporate it. Works for me, test it out!
http://gregsurges.com/wp-content/uploads/2010/08/USB-Octomoduino_9122010.zip
SRC for Arduino and Processing, and a PDF describing pin connections.
  • Greg
Very interesting. If you could shrink it to fit on a shield type form-factor, it might be very successful. You should consider using SMD construction.
Wondering how much interest there would be in a small run of shields, either pcbs or kits?
I've also updated the info page at: http://www.gregsurges.com/circuitry/usb-octomod/
and am planning on having a MIDI implementation within a few days.
  • Greg
