Dlpf_cfg mpu6050
hello everyone.
i wanted to know how to set the frequency of the imu mpu6050 to 1khz by enabling the DLPF_CFG flag.
thank you all very much!
alberto.
Do you using a library to work with mpu6050?
<Wire.h>
Why don't you use a dedicated libraries for MPU6050:
or
sorry, i have also this library: GitHub - ElectronicCats/mpu6050: MPU6050 Arduino Library
see the table in comments in the MPU6050.cpp file:
/** Get digital low-pass filter configuration.
 * The DLPF_CFG parameter sets the digital low pass filter configuration. It
 * also determines the internal sampling rate used by the device as shown in
 * the table below.
 * Note: The accelerometer output rate is 1kHz. This means that for a Sample
 * Rate greater than 1kHz, the same accelerometer sample may be output to the
 * FIFO, DMP, and sensor registers more than once.
 * <pre>
 *          |   ACCELEROMETER    |           GYROSCOPE
 * DLPF_CFG | Bandwidth | Delay  | Bandwidth | Delay  | Sample Rate
 * 0        | 260Hz     | 0ms    | 256Hz     | 0.98ms | 8kHz
 * 1        | 184Hz     | 2.0ms  | 188Hz     | 1.9ms  | 1kHz
 * 2        | 94Hz      | 3.0ms  | 98Hz      | 2.8ms  | 1kHz
 * 3        | 44Hz      | 4.9ms  | 42Hz      | 4.8ms  | 1kHz
 * 4        | 21Hz      | 8.5ms  | 20Hz      | 8.3ms  | 1kHz
 * 5        | 10Hz      | 13.8ms | 10Hz      | 13.4ms | 1kHz
 * 6        | 5Hz       | 19.0ms | 5Hz       | 18.6ms | 1kHz
 * 7        |   -- Reserved --   |   -- Reserved --   | Reserved
 * </pre>
according to the above, to set a mpu sample rate to 1 kHz you need apply this:
mpu.setDLPFMode(MPU6050_DLPF_BW_188);
my code is this:
#include <Wire.h>
#include <MPU6050.h>
const int MPU = 0x68; // MPU6050 I2C address
float AccX, AccY, AccZ;
float GyroX, GyroY, GyroZ;
float accAngleX, accAngleY, gyroAngleX, gyroAngleY, gyroAngleZ;
float roll, pitch, yaw;
float AccErrorX, AccErrorY, GyroErrorX, GyroErrorY, GyroErrorZ;
float elapsedTime, currentTime, previousTime;
int c = 0;
  Serial.begin(19200);
  Wire.begin();                      // Initialize comunication
  Wire.beginTransmission(MPU);       // Start communication with MPU6050 // MPU=0x68
  Wire.write(0x6B);                  // Talk to the register 6B
  Wire.write(0x00);                  // Make reset - place a 0 into the 6B register
  Wire.endTransmission(true);        //end the transmission
  // Configure Accelerometer Sensitivity - Full Scale Range (default +/- 2g)
  Wire.write(0x1C);                  //Talk to the ACCEL_CONFIG register (1C hex)
  Wire.write(0x10);                  //Set the register bits as 00010000 (+/- 8g full scale range)
  // Configure Gyro Sensitivity - Full Scale Range (default +/- 250deg/s)
  Wire.write(0x1B);                   // Talk to the GYRO_CONFIG register (1B hex)
  Wire.write(0x10);                   // Set the register bits as 00010000 (1000deg/s full scale)
  delay(20);
  // Call this function if you need to get the IMU error values for your module
  calculate_IMU_error();
  delay(20);
  // === Read acceleromter data === //
  Wire.write(0x3B); // Start with register 0x3B (ACCEL_XOUT_H)
  Wire.endTransmission(false);
  Wire.requestFrom(MPU, 6, true); // Read 6 registers total, each axis value is stored in 2 registers
  //For a range of +-2g, we need to divide the raw values by 16384, according to the datasheet
  AccX = (Wire.read() << 8 | Wire.read()) / 16384.0; // X-axis value
  AccY = (Wire.read() << 8 | Wire.read()) / 16384.0; // Y-axis value
  AccZ = (Wire.read() << 8 | Wire.read()) / 16384.0; // Z-axis value
  // Calculating Roll and Pitch from the accelerometer data
  accAngleX = (atan(AccY / sqrt(pow(AccX, 2) + pow(AccZ, 2))) * 180 / PI) - 0.58; // AccErrorX ~(0.58) See the calculate_IMU_error()custom function for more details
  accAngleY = (atan(-1 * AccX / sqrt(pow(AccY, 2) + pow(AccZ, 2))) * 180 / PI) + 1.58; // AccErrorY ~(-1.58)
  // === Read gyroscope data === //
  previousTime = currentTime;        // Previous time is stored before the actual time read
  currentTime = millis();            // Current time actual time read
  elapsedTime = (currentTime - previousTime) / 1000; // Divide by 1000 to get seconds
  Wire.write(0x43); // Gyro data first register address 0x43
  Wire.requestFrom(MPU, 6, true); // Read 4 registers total, each axis value is stored in 2 registers
  GyroX = (Wire.read() << 8 | Wire.read()) / 131.0; // For a 250deg/s range we have to divide first the raw value by 131.0, according to the datasheet
  GyroY = (Wire.read() << 8 | Wire.read()) / 131.0;
  GyroZ = (Wire.read() << 8 | Wire.read()) / 131.0;
  // Correct the outputs with the calculated error values
  GyroX = GyroX + 0.56; // GyroErrorX ~(-0.56)
  GyroY = GyroY - 2; // GyroErrorY ~(2)
  GyroZ = GyroZ + 0.79; // GyroErrorZ ~ (-0.8)
  // Currently the raw values are in degrees per seconds, deg/s, so we need to multiply by sendonds (s) to get the angle in degrees
  gyroAngleX = gyroAngleX + GyroX * elapsedTime; // deg/s * s = deg
  gyroAngleY = gyroAngleY + GyroY * elapsedTime;
  yaw =  yaw + GyroZ * elapsedTime;
  // Complementary filter - combine acceleromter and gyro angle values
  roll = 0.96 * gyroAngleX + 0.04 * accAngleX;
  pitch = 0.96 * gyroAngleY + 0.04 * accAngleY;
  // Print the values on the serial monitor
  /*Serial.print(roll);
  Serial.print("/");
  Serial.print(pitch);
  Serial.print("/");
  Serial.println(yaw);*/
do I write your instruction in the setup?
Why did you touch the MPU6050 through I2c directly, if you have a high-level MPU6050 library???
I found an example code done this way and I was happy with it... I am not very familiar with arduino.
can i activate the DLPF_CFG flag with my code?
if you find a suitable example
I have not found anything so far.
this instruction you told me 'mpu.setDLPFMode(MPU6050_DLPF_BW_188);'
can't I do it in my code?
Try to add a library support to your sketch:
First define mpu object
MPU6050 mpu;
Than call initialize from setup:
mpu.initialize();
and after that you can call the
method
OK thank you very much, now I have a small commitment.
later i'll try to do as you advised and let you know, thank you very much!!!
#include <Wire.h>
int c = 0;
MPU6050 mpu;
  mpu.initialize();
  delay(20);
  delay(20);
I added the things you told me... it gives me this error 'MPU6050_DLPF_BW_188' was not declared in this scope'.
try this
mpu.setDLPFMode(MPU6050_IMU::MPU6050_DLPF_BW_188);
ok perfect, now the error is gone! thanks!
one question: does the gyro write the values at 1KHz ?
because I have to save the gyroscope values (and accelerometer, which already goes at 1KHz) to a .csv file
Sorry, i can't tell, I haven't worked with the 6050 in real project
hello everyone!
i am new to arduino so i apologise if the questions are not precise.
I am working with MPU6050 and am having difficulties with the sample rate...
I wanted to know how is it possible to set the sample rate of the IMU MPU6050 to 1Khz?
The IMU is connected with I2C
thanks a lot everyone!
alberto.
The gyro output data rate can take on a number of values between 4 Hz and 8 kHz, as described in the device data sheet.
How you set that depends on the library you have chosen, which may not even offer the option.
I used these two libraries in my code:
#include <Wire.h>
#include <MPU6050.h>.
