DMD.h libray error p10 panel
#include <SPI.h>
#include <DMD.h>
//#include <DMD2.h>
#include <TimerOne.h>
//#include "Arial_black_16.h"
//#include "Arial_Black_16_ISO_8859_1.h"
//#include "Arial14.h"
#include "SystemFont5x7.h"
#include <TrFonts/Arial_Black_16TR.h>
#include <SoftwareSerial.h>
// #include <SoftwareSerial.h>
SoftwareSerial am(4, 3); // RX | TX
#define DISPLAYS_ACROSS 3 //-> Number of P10 panels used, side to side.
#define DISPLAYS_DOWN 2
DMD dmd(DISPLAYS_ACROSS, DISPLAYS_DOWN);
char *Text = "murad";
char *Text1 = "cesur";
char a='q';
void ScanDMD() {
  dmd.scanDisplayBySPI();
void setup(void) {
  Timer1.initialize(1000);
  Timer1.attachInterrupt(ScanDMD);
  dmd.clearScreen(true);
  am.begin(9600);
 // Serial.begin(115200);
void loop(void)
if(a =='q') {a='a';}
  if(am.available())
   a=am.read();
  if(a=='a')
  blink();
// arrow();
  if(a=='s')
    ciftsatirkayar();  //yol calismasi
   if(a=='d')
    ciftsatirkayar1(); //ib istac as
   if(a=='f')
    ciftsatirkayar2();
   if(a=='g')
    leftarrow();
  if(a=='h')
    rightarrow();
   if(a=='j')
    sabit();
    a='t';
void blink()
      dmd.selectFont(Arial_Black_16TR);
      dmd.drawString(18,0, "DIKKAT", 6, GRAPHICS_NORMAL);
      dmd.drawString(20,14, "YAVAS", 5, GRAPHICS_NORMAL);
      //dmd.drawChar(20,14,'Ş',GRAPHICS_NORMAL);
//-----------------------------------------------------------------Non Scrolling Text
void sagtosol()
  // dmd.selectFont(Arial_Black_16_ISO_8859_1);  32*DISPLAYS_ACROSS)
  //dmd.selectFont(Arial_Black_16TR);
  //dmd.selectFont(Arial_14);
  dmd.selectFont(SystemFont5x7);
  //-----------------------------------------------------------By using "millis()"
  Text = "< < < < < < < < < < <";
  dmd.drawMarquee(Text,strlen(Text),96,10);
  long start=millis();
  long timer=start;
  boolean ret=false;
  int interval=10;
  while(!ret){
    if ((timer+interval) < millis()) {
      ret=dmd.stepMarquee(-1,0);
      timer=millis();
    //  Serial.println(ret);
void soltosag()
 // dmd.selectFont(SystemFont5x7);
     Text = "> > > > > > > > > > > > ";  //> > > > > > > > > > > >
     dmd.drawMarquee(Text,strlen(Text),-45,10);
     long timer=start;
     boolean ret=false;
     int interval=10;
     while(!ret){
        ret=dmd.stepMarquee(1,0);
        timer=millis();
void sabit()
      dmd.drawString(18,4, "DIKKAT", 6, GRAPHICS_NORMAL);
      dmd.drawString(20,18, "YAVAS", 5, GRAPHICS_NORMAL);
void ciftsatirkayar()
     for(int i=96; i>-85; i--)
      dmd.drawString(i+25,4, "YOL", 3, GRAPHICS_NORMAL);
      dmd.drawString(i-1,18, "CALISMASI", 9, GRAPHICS_NORMAL);
      delay(5);
void ciftsatirkayar1()
     for(int i=96; i>-80; i--)
      dmd.drawString(i+23,1, "IBB", 3, GRAPHICS_NORMAL);
      dmd.drawString(i-1,18, "ISTAC.AS", 8, GRAPHICS_NORMAL);
      delay(5);
void ciftsatirkayar2()
  dmd.drawString(0,1,"30AGUSTOS",10,GRAPHICS_NORMAL); // stationary text
  dmd.drawMarquee("ZAFER BAYRAMINIZ KUTLU OLSUN",28,96,16); // set up the marquee
     long timer=start;
     boolean ret=false;
     int interval=20;
     while(!ret){
        ret=dmd.stepSplitMarquee(14,31);
        timer=millis();
void rightarrow()
  for(int i=0; i<96; i++)
    dmd.drawLine(i, 0, i+ 14, 14, GRAPHICS_NORMAL);
    dmd.drawLine(i+16,15,  i, 31, GRAPHICS_NORMAL);
    dmd.drawLine(i+15, 0, i+ 29, 14, GRAPHICS_NORMAL);
    dmd.drawLine(i+31,15,  i+15, 31, GRAPHICS_NORMAL);
    dmd.drawLine(i+30, 0, i+ 44, 14, GRAPHICS_NORMAL);
    dmd.drawLine(i+46,15,  i+30, 31, GRAPHICS_NORMAL);
    delay(10);
void leftarrow()
  for(int i=96;i>0;i--){
  dmd.drawLine(i, 0,  i-15, 15, GRAPHICS_NORMAL);
  dmd.drawLine(i,31,  i-16, 15, GRAPHICS_NORMAL);
   dmd.drawLine(i-15, 0,  i-30, 15, GRAPHICS_NORMAL);
  dmd.drawLine(i-15,31,  i-31, 15, GRAPHICS_NORMAL);
  dmd.drawLine(i-30, 0,  i-45, 15, GRAPHICS_NORMAL);
  dmd.drawLine(i-30,31,  i-46, 15, GRAPHICS_NORMAL);
 delay(10);
// void uptodown()
//   // dmd.selectFont(Arial_Black_16_ISO_8859_1);  32*DISPLAYS_ACROSS)
//   dmd.selectFont(Arial_Black_16TR);
//   //dmd.selectFont(Arial_14);
//  // dmd.selectFont(SystemFont5x7);
//   //-----------------------------------------------------------By using "millis()"
//   Text = "30 KM/S";
//   dmd.drawMarquee(Text,strlen(Text),30,-15);
//   long start=millis();
//   long timer=start;
//   boolean ret=false;
//   int interval=35;
//   while(!ret){
//     if ((timer+interval) < millis()) {
//       ret=dmd.stepMarquee(0,1);
//       timer=millis();
//     //  Serial.println(ret);
// void downtoup()
//   Text = "";
//   dmd.drawMarquee(Text,strlen(Text),30,32);
//   int interval=10;
//   while(!ret){
//       ret=dmd.stepMarquee(0,-1);
//       timer=millis();
i am using turksih library but i cant see turkish char on the screen. even serial monitor. when i add turkish char on p10 panel it was not shown. code skip tp
Hello, do yourself a favour and please read How to get the best out of this forum and modify your post accordingly (including code tags and necessary documentation for your ask).
There is no :drawString() method in the DMD library v1
This method is from DMD2 library
@Murad1998
If you need a non-latin letters - you can try this library
thank u fo r your answer. i need to library one of the non latin letter one of the turksih character. i just make research.in githap says just chane type of char from const char to const unsigined char. i did but it did not work.
Text = "";
// int interval=10;
// while(!ret){
// timer=millis();
if i do lie this randomly show some char even turkish one. but when i write word with turkish letter is`nt work. what is suggestion. thanks for your attetion
What is a library do you use? Do you have a Turkish font for the tests?
What is that you don't understand when you are being asked to use code tags when posting code ??
please take the time to correct all your posts and add the code tags.
yes sir i am using this library #include <TrFonts/Arial_Black_16TR.h>
What is "this" library?? Please name it!
still no code tags... the clock is ticking.... please fix this.
Arial_Black_16TR.h
Sorry
Do you read what I write? I asked you what library are you using
If you don't understand English, use google translator
thank for attention can u see code now?
i am using dmd library, spi library Timerone library software serial and arial_plack_16TR library. i am using this form first time so sorry about my fault. i cooect my post now i think u can see posted code.
As far I know, DMD.h library does not supports the using of national fonts.
Try this library
i used it before dmd.h. but this lbrahsy has some problem. about scrolling. it is not working properly. as i want
