DMX lighting control
Hi all,
I was thinking of using the Arduino with the DMX shield which allows me the receive the DMX signal and then using PWM output to drive several LEDs.
I have been searching online but have not been getting much useful information.. Can someone give me some example projects/guidiance? I will be very much appreciated.
Thanks!
Maybe start here for details on how to drive a RGB strip using Arduino or buy one of the several RGB modules like this or this.
Once you have your RGB strip controller designed/selected then adding/building a DMX shield and programming it will be quick and easy.
Hi Riva,
Thanks for your reply.
I do not need to control a RGB strip... I only need to light up several RGB/near infrared LEDs via PWM.
I am more interested in selecting a DMX shield, how to receive DMX signal and output as PWM to the LEDs.
Thanks
engineer_abc:
How is that different? "lighting up" in a way you specify == controlling! :wink:
And there are multiple DMX libraries you can use. First Google hit. But don't expect to make something without at least learning the basics of programming :slight_smile:
engineer_abc:
Will all the RGB LED's be set to the same levels or will they all have different levels?
How many LED's are you talking about?
Are the IR LED's also RGB?
engineer_abc:
Depending on your skill levels and what DMX equipment your connecting too you could either build your own with opto isolation or buy a cheap (non isolated) RS485 to USART converter or go for a shield (something like this)
From there it's just a case of picking one of the many DMX libraries for your Arduino and writing a bit of code that you may find several examples of on the net already or ask here for help.
Hi Riva,
All the LEDs will be changing at the same level at the same time. They are all infrared LEDs and should be at least 30 of them.
Thank you for the information you have provided above. I will look into those to try to get on.
I could not make the connection on how RS485 to USART converter be used in this situation... Would you mind expanding it a little bit further?
Cheers
So how are you going to see them?
Check out Mats Hertels' DMXSerial library. He's got a whole host of info about DMX, DMX shields, RS-485, and his example code controls LEDs via pwm through DMX. Google 'DMX Shield with isolation' and then go to the page that comes up on Mats Hertels website. It will tell you lots of great stuff.
Thanks for the reply.
I will be able to see them through a infrared scope.
Sure, I will look into Mats Hertels' library now.
Cheers
