Hi Arduino Humans
I recently purchased a DMX Shield (CTC-DRA-10-1) from Conceptinetics for and Arduino Uno (user manual attached). I installed the "Conceptinetics_RDM_alpha3_2.zip" libraries and ran the example project "DMX_Master.ino"(Ino file attached). Upon uploading the code I received the error:
Arduino: 1.8.13 (Mac OS X), Board: "Arduino Uno"
Sketch uses 932 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
I removed the shield and ran a Blink to check connectivity which worked fine. Upon reattaching the shield and running the same Blink I got a similar error message.
I am an early user of Arduino so my trouble shooting capacity is limited. Any advice would be greatly appreciated.
Many Thanks
not-skynet
DMX Shield User manual.pdf (370 KB)
DMX_Master.ino (2.37 KB)
