I've seen people using multiple resistors and people using one resistor on the common pin. I need to know witch one is better.
Well, with 7 segments on, and one resistor, the current is shared, usually not equally, between the 7 segments, whereas with only one segment on, that LED gets all the current. Perhaps, there will be noticable intensity differences?
So, for example, a 1 would appear quite differently than an 8.
Yes, each LED in the 7-segment display needs its own current limiting resistor.
Thanks
Each LED need's it's own resistor.
The resistor limits the current so if you have one LED on and then then you turn-on more LEDs the current gets split between the LEDs and they get dimmer.
What happens when you try? Is it a difficult experiment?
Unless of course you are multiplexing by segment instead of by digit. If multiplexing by segment, only one segment of each digit will be on at a time, so the common cathode resistor will limit the current to the same level for all segments.
For shure, your are right.
