I'm developing a board for an automotive application and desire to use the ATmega32M1. Having not found any Arduino bootloader or accompanying files on the internet for the ATmega32M1, I tried to write my own files for the ATmega32M1, but I seem to be missing something. Therefore I thought I'd ask if there was anyone here who has or knows where I can get the files to run Arduino on an ATmega32M1.
Thank you, CrossRoads, for the link. I will check it out and see if I can use the information there.
I find the ATmega32M1 attractive for its CAN capability and it's small size (7mm x 7mm)! I've been using the AT90CAN128 which has been great, but I want this board to fit easily inside some heat-shrink tubing, so the smaller form of the ATmega32M1 is better suited.
Okay, I've tried coping the core folders and files as suggested at avr-developers.com. I then updated the board.txt file, pins_arduino.h, avrdude.conf, etc. for the ATmega32M1.
Riva, thanks for the inquiry. I've tried my own code, but something isn't quite right. I cannot get an LED to blink! That side of the attempt can be found in this thread: http://forum.arduino.cc/index.php?topic=265078.0. That is why I was asking if anyone else out there had the code already written.
RaMansell:
As the LED is not blinking that makes me think the core is not correct and either not setting system up correctly on power one or crashing/ locking up.
The site Crossroads linked to does not seem to have a core to support your 32M1 so maybe someone who knows how (not me BTW) will be able to change/write a core. Another option might be to use a different development environment to Arduino and port code/libraries to suit it.
