I have this sketch which refuses to compile. can anybody point me towards my mistake?
the error is 'manualAdvance' does not name a type.
const byte numChars = 32;
char receivedChars[numChars];
boolean newData = false;
int relayPin = 8;
int syncPin = 9;
int testPin = 10;
const int retardPin = 2;
const int advancePin = 3;
int retardState = 0;
int advanceState = 0;
//char summerTime = bitRead(receivedChars[12],1);
byte summerTime = bitRead(receivedChars[12], 1); //will intialize as 0 winterTime
boolean relayRunning = false;
unsigned long relayStartTime = 0;
unsigned long lastRelayStartTime = 0;
byte missedCount = 0;
boolean summerAdvance = false;
boolean winterRetard = false;
boolean missedPulseAdvance = false;
boolean manualAdvance = false;
byte seconds = 0;
Serial.println("Arduino is ready --");
pinMode(relayPin, OUTPUT);
pinMode(syncPin, OUTPUT);
pinMode(testPin, OUTPUT);
pinMode(retardPin, INPUT_PULLUP);
pinMode(advancePin, INPUT_PULLUP);
//bitRead(receivedChars[12],1); not useful here before message arrives
recvWithStartEndMarkers();
retardState = digitalRead(retardPin);
advanceState = digitalRead(advancePin);
if (newData == true)
processNewData();
if (relayRunning == true && summerAdvance == false && winterRetard == false && missedPulseAdvance == false && manualAdvance == false)
runRelayCycle();
if bitRead(receivedChars[12], 1==1)
digitalWrite (testPin, HIGH);
else digitalWrite (testPin, LOW);
if bitRead(receivedChars[12], 2==1)
digitalWrite (syncPin, HIGH);
else digitalWrite (syncPin, LOW);
if (summerAdvance == true)
advanceClock(124); // 1 hour each pulse advances slave 30 seconds
if (winterRetard == true)
retardClock(1); //11 hours advance = 1 hour back
if (manualAdvance == true)
manualAdvanceClock;
//if (missedPulseAdvance == true)
// advanceClock(missedCount);
void recvWithStartEndMarkers() {
static boolean recvInProgress = false;
static byte ndx = 0;
char startMarker = 0x02;
char endMarker = 0x03;
char rc;
if (Serial.available() > 0) {
rc = Serial.read();
if (recvInProgress == true) {
if (rc != endMarker) {
receivedChars[ndx] = rc;
ndx++;
if (ndx >= numChars) {
ndx = numChars - 1;
else {
receivedChars[ndx] = '\0'; // terminate the string
ndx = 0;
newData = true;
else if (rc == startMarker) {
recvInProgress = true;
void processNewData()
//if (newData == true)
checkStatusBit();
if ((receivedChars[1] == '3' && receivedChars[0] == '0') || (receivedChars[1] == '0' &&
receivedChars[0] == '0'))
if (relayRunning == true)//set true during fast advance
missedCount++;
Serial.print("missedCount = ");
Serial.println(missedCount);
if (relayRunning == false) //back to normal from fast advance
relayStartTime = millis();
if((relayStartTime - lastRelayStartTime >= 14000)&&(retardState == HIGH)) //some lock out period
digitalWrite (relayPin, HIGH);
relayRunning = true;
lastRelayStartTime = relayStartTime;
//if (missedCount > 0)
//missedPulseAdvance = true; //make up pulses next loop pass
//digitalWrite (relayPin, HIGH);
//relayRunning = true;
//relayStartTime = millis();
Serial.println("on");
Serial.print("Time Now ... ");
Serial.print(bitRead(receivedChars[12], 1));
Serial.print(bitRead(receivedChars[12], 2));
Serial.print(receivedChars[5]);
Serial.print(receivedChars[4]);
Serial.print(receivedChars[3]);
Serial.print(receivedChars[2]);
Serial.print(receivedChars[1]);
Serial.println(receivedChars[0]);
newData = false;
void runRelayCycle()
const unsigned long relayInterval = 400;
//if (relayRunning == true && millis() - relayStartTime >= relayInterval)
if (millis() - relayStartTime >= relayInterval)
digitalWrite(relayPin, LOW);
void advanceClock(unsigned int numberOfPulses)
const unsigned long intervalOn = 400; //adjust these numbers for fastest reliable advance
const unsigned long intervalOff = 600;
static byte relayState = LOW;//initial state starts off
static unsigned long interval = intervalOff;
static unsigned long previousMillis = millis();
static unsigned int fastCount = 0;
relayRunning = true;//blocks regular 30 second pulses
//interval switchs between intervalOn and intervalOff
if (currentMillis - previousMillis >= interval)
if (relayState == LOW)
relayState = HIGH;
digitalWrite(relayPin, relayState);
interval = intervalOn; //switch interval
else //relay was HIGH
relayState = LOW;
fastCount++; //count at end of pulse
Serial.println(fastCount);
if (fastCount >= numberOfPulses)
fastCount = 0;
missedCount = 0;
void retardClock(unsigned int numberOfPulses)
const unsigned long intervalOn = 0; //adjust these numbers for fastest reliable advance
const unsigned long intervalOff = 3600000;
relayState = HIGH;
relayState = LOW;
fastCount = 0;
missedCount = 0;
//Serial.println("relayRunning = false");
void manualAdvanceClock(unsigned int numberOfPulses)
relayState = HIGH;
relayState = LOW;
void checkStatusBit()
static byte lastSummerTime = 0; //initialize for winterTime
if (summerTime == 1 && lastSummerTime == 0)//state change
summerAdvance = true;
lastSummerTime = summerTime; //set to 1
if (summerTime == 0 && lastSummerTime == 1)//state change
winterRetard = true;
lastSummerTime = summerTime; //set to 0
void checkAdvancePin()
if (advanceState == HIGH);
manualAdvance = true;
