I cant get this code to work at all any help, making a alarm clock with rtc module and using arduino uno
#include <LiquidCrystal_I2C.h >
#include <Ds1302.h>
#include <time.h> //instead of parenthesis () put angle bracket as YouTube description does not allow angle bracket
// Set the LCD address to 0x27 for a 16 chars and 2 line display
LiquidCrystal_I2C lcd(0x3F, 16, 2);
#include <Ds1302.h>
int Hour;
int Min;
int pset = 8; // pushbutton for setting alarm
int phour = 9; // pushbutton for hour
int pmin = 10; // pushbutton for minutes
int pexit = 11; // pushbutton for exit of set alarm
int buzzer = 6;
int h;
int m;
int buttonforset = 0; // pushbutton state for setting alarm
int buttonforhour = 0; // pushbutton state for hour
int buttonformin = 0;// pushbutton state for minutes
int buttonforexit = 0; // pushbutton state for exit of set alarm
int activate=0;
time t;
// Init the DS1302
Ds1302 rtc(2, 3, 4);
pinMode(pset, INPUT);
pinMode(phour, INPUT);
pinMode(pmin, INPUT);
pinMode(pexit, INPUT);
// Set the clock to run-mode, and disable the write protection
rtc.halt(false);
rtc.writeProtect(false);
// Setup LCD to 16x2 characters
lcd.begin();
// The following lines can be commented out to use the values already stored in the DS1302
//rtc.setDOW(SATURDAY); // Set Day-of-Week to FRIDAY
//rtc.setTime(10, 0, 0); // Set the time to 12:00:00 (24hr format)
//rtc.setDate(11, 11, 2017); // Set the date to August 6th, 2010
if (activate == 0) {
// Display time on the right conrner upper line
lcd.setCursor(0, 0);
lcd.print("Time: ");
lcd.setCursor(6, 0);
lcd.print(rtc.getTimeStr());
// Display abbreviated Day-of-Week in the lower left corner
//lcd.setCursor(0, 1);
//lcd.print(rtc.getDOWStr(FORMAT_SHORT));
// Display date in the lower right corner
lcd.print("Date: ");
lcd.setCursor(6, 1);
lcd.print(rtc.getDateStr());
t = rtc.getTime();
Hour = t.hour;
Min = t.min;
buttonforset = digitalRead(pset);
} // setting button pressed
if (buttonforset == HIGH) {
activate =1;
lcd.clear(); }
while(activate== 1){
lcd.setCursor(0,0);
lcd.print("Set Alarm");
lcd.setCursor(0,1);
lcd.print("Hour= ");
lcd.setCursor(9,1);
lcd.print("Min= ");
buttonforhour = digitalRead(phour); // set hour for alarm
if (buttonforhour == HIGH){
h++;
lcd.setCursor(5,1);
lcd.print(h);
if (h)23){
h=0;
lcd.clear(); }
delay(100);
buttonformin = digitalRead(pmin); // set minutes for alarm
if (buttonformin == HIGH){
m++;
lcd.setCursor(13,1);
lcd.print(m);
if (m)59){
m=0;
lcd.clear();}
delay(100);
lcd.setCursor(5,1);
lcd.print(h);
lcd.print(m);
buttonforexit = digitalRead(pexit); // exit from set alarm mode
if (buttonforexit == HIGH){
activate = 0;
lcd.clear();
if (Hour== h && Min== m) {
tone(6,400,300);}
delay (500);
