Does this need to be soldered?
I bought an I2C LCD from amazon:
And I have a problem, only the backlight turns on.
The screen flickers too and I've started to ask myself if it needs to be soldered.
I tried to adjust the contrast, but still, no result.
This is my code:
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 16, 2);
  lcd.init();
  lcd.backlight();
  lcd.clear();
  lcd.setCursor(0, 1);
  lcd.print("Hello World");
Photo:
Not just needs, but absolutely must be soldered!
You must solder.
You can solder a female header on the LCD display then you can plug the backpack into this header.
when you say backpack, do you mean the i2c adapter?
Yes
oh, then i can't xD
coz i don't have a soldering machine or smth like that
can't I connect it to a breadboard?
Yes you can.
But then you need to solder a male header to the LCD display.
Yes.
how so?
See post 8.
Buy a soldering iron and 63/37 or 60/40 solder.
Get one premade. https://www.ebay.com/itm/383273086356?hash=item593cdb2d94:g:Q6YAAOSwSK9d0u0Y&amdata=enc%3AAQAHAAAA4BAaVHFZkycSpdFOuRmS1L%2FU5yoRYuEff3RqBNEnXArCRuGKLG%2BVN6D7yMEgYm%2BxIYzleuap0afoYT96GrEmeIwiFjjgrpcMiTzwIMziHvGWetSXS7UdbRmdE6kC2kXyISMrGuUEpxzxByq5H4eFZaDypyrAJjTrp9yXziZApqijj927mEQkVQcNfgQYzG4IponRWWg8w3T%2FvpfkXsA0TuWH8WYKMokoZhVly%2FsdaTcDryydBBa33AtCA1L74Z8jDV04%2FbtB2SELFD9twS%2Fg6SyvamephTb8dx8p3O4DMOrI|tkp%3ABFBMxr6_7ZBh
say, one header or several headers?
Looks like you need a 1X16 female header to match your backpack male header.
Make sure the backpack is plugged into the new female header the right way around.
can you make me a sort of drawing because I don't understand where to plug them in
oh wait nvm i understand now
This is how the soldered female header should appear.
Then buy one, or give up electronics and find something else to do.
Yes.
You can get one pre-soldered. Search Amazon for "LCD i2c"
And that's exactly what i did xD
