DOIT ESP32 Devkit V1
I have had a heating control sketch running for several years now but recently I have had to have a new home router. I tried to update the new SSID and PASSWORD in my sketch but when I try to compile it I get the error message:
"Sketch uses 1750313 bytes (133%) of program storage space."
I have changed nothing other than a few characters
under File>Preferences set compile "Show verbose output"
copy the compiler and linker output and paste it using code tags </>
could be a problem with Migration from 2.x to 3.0 - - — Arduino ESP32 latest documentation
Thank you horace
Would you know if I can roll back to v2?
FQBN: esp32:esp32:esp32doit-devkit-v1
Using board 'esp32doit-devkit-v1' from platform in folder: C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4
Using core 'esp32' from platform in folder: C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4
cmd /c if exist "E:\Users\Documents\Arduino\NEW_HEATING_CLOCK\partitions.csv" COPY /y "E:\Users\Documents\Arduino\NEW_HEATING_CLOCK\partitions.csv" "C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9\partitions.csv"
cmd /c if not exist "C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9\partitions.csv" if exist "C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\doitESP32devkitV1\partitions.csv" COPY "C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\doitESP32devkitV1\partitions.csv" "C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9\partitions.csv"
cmd /c if not exist "C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9\partitions.csv" COPY "C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\tools\partitions\default.csv" "C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9\partitions.csv"
cmd /c IF EXIST "E:\Users\Documents\Arduino\NEW_HEATING_CLOCK\bootloader.bin" ( COPY /y "E:\Users\Documents\Arduino\NEW_HEATING_CLOCK\bootloader.bin" "C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9\NEW_HEATING_CLOCK.ino.bootloader.bin" ) ELSE ( IF EXIST "C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\doitESP32devkitV1\bootloader.bin" ( COPY "C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\doitESP32devkitV1\bootloader.bin" "C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9\NEW_HEATING_CLOCK.ino.bootloader.bin" ) ELSE ( "C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.6\esptool.exe" --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o "C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9\NEW_HEATING_CLOCK.ino.bootloader.bin" "C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32\bin\bootloader_dio_80m.elf" ) )
esptool.py v4.6
Creating esp32 image...
Merged 1 ELF section
Successfully created esp32 image.
cmd /c if exist "E:\Users\Documents\Arduino\NEW_HEATING_CLOCK\build_opt.h" COPY /y "E:\Users\Documents\Arduino\NEW_HEATING_CLOCK\build_opt.h" "C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9\build_opt.h"
cmd /c if not exist "C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9\build_opt.h" type nul > "C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9\build_opt.h"
cmd /c type nul > "C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9/file_opts"
Detecting libraries used...
C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/cpp_flags -w -Og -g3 -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="doitESP32devkitV1" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32doit-devkit-v1:UploadSpeed=921600,FlashFreq=80,DebugLevel=none,EraseFlash=none" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/defines -IE:\Users\Documents\Arduino\NEW_HEATING_CLOCK -iprefix C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/include/ @C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/includes -IC:\Users\Tony\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/dio_qspi/include -IC:\Users\Tony\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32 -IC:\Users\Tony\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\doitESP32devkitV1 @C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9/build_opt.h @C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9/file_opts C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9\sketch\NEW_HEATING_CLOCK.ino.cpp -o nul
Alternatives for WiFi.h: [WiFi@3.0.4]
ResolveLibrary(WiFi.h)
-> candidates: [WiFi@3.0.4]
C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/cpp_flags -w -Og -g3 -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="doitESP32devkitV1" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32doit-devkit-v1:UploadSpeed=921600,FlashFreq=80,DebugLevel=none,EraseFlash=none" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/defines -IE:\Users\Documents\Arduino\NEW_HEATING_CLOCK -iprefix C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/include/ @C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/includes -IC:\Users\Tony\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/dio_qspi/include -IC:\Users\Tony\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32 -IC:\Users\Tony\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\doitESP32devkitV1 -IC:\Users\Tony\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\WiFi\src @C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9/build_opt.h @C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9/file_opts C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9\sketch\NEW_HEATING_CLOCK.ino.cpp -o nul
Alternatives for Network.h: [Networking@3.0.4]
ResolveLibrary(Network.h)
-> candidates: [Networking@3.0.4]
C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/cpp_flags -w -Og -g3 -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="doitESP32devkitV1" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32doit-devkit-v1:UploadSpeed=921600,FlashFreq=80,DebugLevel=none,EraseFlash=none" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/defines -IE:\Users\Documents\Arduino\NEW_HEATING_CLOCK -iprefix C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/include/ @C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/includes -IC:\Users\Tony\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/dio_qspi/include -IC:\Users\Tony\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32 -IC:\Users\Tony\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\doitESP32devkitV1 -IC:\Users\Tony\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\WiFi\src -IC:\Users\Tony\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\Network\src @C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9/build_opt.h @C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9/file_opts C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9\sketch\NEW_HEATING_CLOCK.ino.cpp -o nul
Alternatives for OneWire.h: [OneWire@2.3.8]
ResolveLibrary(OneWire.h)
-> candidates: [OneWire@2.3.8]
C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/cpp_flags -w -Og -g3 -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="doitESP32devkitV1" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32doit-devkit-v1:UploadSpeed=921600,FlashFreq=80,DebugLevel=none,EraseFlash=none" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/defines -IE:\Users\Documents\Arduino\NEW_HEATING_CLOCK -iprefix C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/include/ @C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/includes -IC:\Users\Tony\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/dio_qspi/include -IC:\Users\Tony\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32 -IC:\Users\Tony\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\doitESP32devkitV1 -IC:\Users\Tony\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\WiFi\src -IC:\Users\Tony\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\Network\src -Ie:\Users\Documents\Arduino\libraries\OneWire @C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9/build_opt.h @C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9/file_opts C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9\sketch\NEW_HEATING_CLOCK.ino.cpp -o nul
Alternatives for DallasTemperature.h: [DallasTemperature@3.9.0]
ResolveLibrary(DallasTemperature.h)
-> candidates: [DallasTemperature@3.9.0]
C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/cpp_flags -w -Og -g3 -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="doitESP32devkitV1" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32doit-devkit-v1:UploadSpeed=921600,FlashFreq=80,DebugLevel=none,EraseFlash=none" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/defines -IE:\Users\Documents\Arduino\NEW_HEATING_CLOCK -iprefix C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/include/ @C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/includes -IC:\Users\Tony\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/dio_qspi/include -IC:\Users\Tony\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32 -IC:\Users\Tony\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\doitESP32devkitV1 -IC:\Users\Tony\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\WiFi\src -IC:\Users\Tony\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\Network\src -Ie:\Users\Documents\Arduino\libraries\OneWire -Ie:\Users\Documents\Arduino\libraries\DallasTemperature @C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9/build_opt.h @C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9/file_opts C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9\sketch\NEW_HEATING_CLOCK.ino.cpp -o nul
Using cached library dependencies for file: C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\WiFi\src\AP.cpp
Using cached library dependencies for file: C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\WiFi\src\STA.cpp
Using cached library dependencies for file: C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\WiFi\src\WiFi.cpp
Using cached library dependencies for file: C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\WiFi\src\WiFiAP.cpp
Using cached library dependencies for file: C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\WiFi\src\WiFiGeneric.cpp
Using cached library dependencies for file: C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\WiFi\src\WiFiMulti.cpp
Using cached library dependencies for file: C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\WiFi\src\WiFiSTA.cpp
Using cached library dependencies for file: C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\WiFi\src\WiFiScan.cpp
Using cached library dependencies for file: C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\Network\src\NetworkClient.cpp
Using cached library dependencies for file: C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\Network\src\NetworkEvents.cpp
Using cached library dependencies for file: C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\Network\src\NetworkInterface.cpp
Using cached library dependencies for file: C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\Network\src\NetworkManager.cpp
Using cached library dependencies for file: C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\Network\src\NetworkServer.cpp
Using cached library dependencies for file: C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\Network\src\NetworkUdp.cpp
Using cached library dependencies for file: e:\Users\Documents\Arduino\libraries\OneWire\OneWire.cpp
Using cached library dependencies for file: e:\Users\Documents\Arduino\libraries\DallasTemperature\DallasTemperature.cpp
Generating function prototypes...
C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/cpp_flags -w -Og -g3 -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="doitESP32devkitV1" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32doit-devkit-v1:UploadSpeed=921600,FlashFreq=80,DebugLevel=none,EraseFlash=none" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/defines -IE:\Users\Documents\Arduino\NEW_HEATING_CLOCK -iprefix C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/include/ @C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/includes -IC:\Users\Tony\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/dio_qspi/include -IC:\Users\Tony\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32 -IC:\Users\Tony\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\doitESP32devkitV1 -IC:\Users\Tony\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\WiFi\src -IC:\Users\Tony\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\Network\src -Ie:\Users\Documents\Arduino\libraries\OneWire -Ie:\Users\Documents\Arduino\libraries\DallasTemperature @C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9/build_opt.h @C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9/file_opts C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9\sketch\NEW_HEATING_CLOCK.ino.cpp -o C:\Users\Tony\AppData\Local\Temp\2937156157\sketch_merged.cpp
C:\Users\Tony\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\Tony\AppData\Local\Temp\2937156157\sketch_merged.cpp
Compiling sketch...
"C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/cpp_flags" -w -Og -g3 -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="doitESP32devkitV1"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS="windows"" "-DARDUINO_FQBN="esp32:esp32:esp32doit-devkit-v1:UploadSpeed=921600,FlashFreq=80,DebugLevel=none,EraseFlash=none"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/defines" "-IE:\Users\Documents\Arduino\NEW_HEATING_CLOCK" -iprefix "C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/include/" "@C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/includes" "-IC:\Users\Tony\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/dio_qspi/include" "-IC:\Users\Tony\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32" "-IC:\Users\Tony\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\doitESP32devkitV1" "-IC:\Users\Tony\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\WiFi\src" "-IC:\Users\Tony\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\Network\src" "-Ie:\Users\Documents\Arduino\libraries\OneWire" "-Ie:\Users\Documents\Arduino\libraries\DallasTemperature" "@C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9/build_opt.h" "@C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9/file_opts" "C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9\sketch\NEW_HEATING_CLOCK.ino.cpp" -o "C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9\sketch\NEW_HEATING_CLOCK.ino.cpp.o"
Compiling libraries...
Compiling library "WiFi"
Using previously compiled file: C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9\libraries\WiFi\AP.cpp.o
Using previously compiled file: C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9\libraries\WiFi\WiFiMulti.cpp.o
Using previously compiled file: C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9\libraries\WiFi\WiFiScan.cpp.o
Using previously compiled file: C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9\libraries\WiFi\STA.cpp.o
Using previously compiled file: C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9\libraries\WiFi\WiFi.cpp.o
Using previously compiled file: C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9\libraries\WiFi\WiFiGeneric.cpp.o
Using previously compiled file: C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9\libraries\WiFi\WiFiAP.cpp.o
Using previously compiled file: C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9\libraries\WiFi\WiFiSTA.cpp.o
Compiling library "Networking"
Using previously compiled file: C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9\libraries\Network\NetworkEvents.cpp.o
Using previously compiled file: C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9\libraries\Network\NetworkClient.cpp.o
Using previously compiled file: C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9\libraries\Network\NetworkInterface.cpp.o
Using previously compiled file: C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9\libraries\Network\NetworkServer.cpp.o
Using previously compiled file: C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9\libraries\Network\NetworkUdp.cpp.o
Using previously compiled file: C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9\libraries\Network\NetworkManager.cpp.o
Compiling library "OneWire"
Using previously compiled file: C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9\libraries\OneWire\OneWire.cpp.o
Compiling library "DallasTemperature"
Using previously compiled file: C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9\libraries\DallasTemperature\DallasTemperature.cpp.o
Compiling core...
cmd /c echo -DARDUINO_CORE_BUILD > "C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9/file_opts"
Using precompiled core: C:\Users\Tony\AppData\Local\Temp\arduino\cores\00a063cb6a24241da4960b2986efa123\core.a
Linking everything together...
"C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++" "@C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/ld_flags" "@C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/ld_scripts" "-Wl,--Map=C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9/NEW_HEATING_CLOCK.ino.map" "-LC:\Users\Tony\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/lib" "-LC:\Users\Tony\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/ld" "-LC:\Users\Tony\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/dio_qspi" -Wl,--wrap=esp_panic_handler -Wl,--start-group "C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9\sketch\NEW_HEATING_CLOCK.ino.cpp.o" "C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9\libraries\WiFi\AP.cpp.o" "C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9\libraries\WiFi\STA.cpp.o" "C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9\libraries\WiFi\WiFi.cpp.o" "C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9\libraries\WiFi\WiFiAP.cpp.o" "C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9\libraries\WiFi\WiFiGeneric.cpp.o" "C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9\libraries\WiFi\WiFiMulti.cpp.o" "C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9\libraries\WiFi\WiFiSTA.cpp.o" "C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9\libraries\WiFi\WiFiScan.cpp.o" "C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9\libraries\Network\NetworkClient.cpp.o" "C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9\libraries\Network\NetworkEvents.cpp.o" "C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9\libraries\Network\NetworkInterface.cpp.o" "C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9\libraries\Network\NetworkManager.cpp.o" "C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9\libraries\Network\NetworkServer.cpp.o" "C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9\libraries\Network\NetworkUdp.cpp.o" "C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9\libraries\OneWire\OneWire.cpp.o" "C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9\libraries\DallasTemperature\DallasTemperature.cpp.o" "C:\Users\Tony\AppData\Local\Temp\arduino\cores\00a063cb6a24241da4960b2986efa123\core.a" "@C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/ld_libs" -Wl,--end-group -Wl,-EL -o "C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9/NEW_HEATING_CLOCK.ino.elf"
"C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.6/esptool.exe" --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB --elf-sha256-offset 0xb0 -o "C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9/NEW_HEATING_CLOCK.ino.bin" "C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9/NEW_HEATING_CLOCK.ino.elf"
esptool.py v4.6
Merged 27 ELF sections
"C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\tools\gen_esp32part.exe" -q "C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9/partitions.csv" "C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9/NEW_HEATING_CLOCK.ino.partitions.bin"
cmd /c if exist "C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9\libraries\Insights" "C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\tools\gen_insights_package.exe" "C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9" NEW_HEATING_CLOCK.ino "E:\Users\Documents\Arduino\NEW_HEATING_CLOCK"
cmd /c if exist "C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9\libraries\ESP_SR" if exist "C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32\esp_sr\srmodels.bin" COPY /y "C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32\esp_sr\srmodels.bin" "C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9\srmodels.bin"
"C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.6/esptool.exe" --chip esp32 merge_bin -o "C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9/NEW_HEATING_CLOCK.ino.merged.bin" --fill-flash-size 4MB --flash_mode keep --flash_freq keep --flash_size keep 0x1000 "C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9/NEW_HEATING_CLOCK.ino.bootloader.bin" 0x8000 "C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9/NEW_HEATING_CLOCK.ino.partitions.bin" 0xe000 "C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4/tools/partitions/boot_app0.bin" 0x10000 "C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9/NEW_HEATING_CLOCK.ino.bin"
esptool.py v4.6
Wrote 0x400000 bytes to file C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9/NEW_HEATING_CLOCK.ino.merged.bin, ready to flash to offset 0x0
Using library WiFi at version 3.0.4 in folder: C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\WiFi
Using library Networking at version 3.0.4 in folder: C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\Network
Using library OneWire at version 2.3.8 in folder: E:\Users\Documents\Arduino\libraries\OneWire
Using library DallasTemperature at version 3.9.0 in folder: E:\Users\Documents\Arduino\libraries\DallasTemperature
"C:\Users\Tony\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-size" -A "C:\Users\Tony\AppData\Local\Temp\arduino\sketches\9899D2D4AEB5ADED2A2166C74525A8F9/NEW_HEATING_CLOCK.ino.elf"
Sketch uses 930465 bytes (70%) of program storage space. Maximum is 1310720 bytes.
Global variables use 45204 bytes (13%) of dynamic memory, leaving 282476 bytes for local variables. Maximum is 327680 bytes.
select Tools>Board>Board Manager then enter ESP32 and select the version you require
alternatively change the partition size to Hugh App
This reduced the sketch to 59% from 133% when compiling :slightly_smiling_face:
I now have a compiling error saying :
"Multiple libraries were found for "xxxx.h""
That is not an error but a warning. It will tell you which one has been used. If you have a sketch size, compile was clearly successful.
I only got it to compile once.
I had 'rolled back' a lot of my libraries to see if that was causing my original problem. After updating the libraries back to the latest versions I cannot compile. I just get compilation failures
Having more than one version of a library installed can be a serious problem. Best practice is to uninstall the whole library and make sure all files are removed from the sketch/libraries folder, before you install the version you intend to use. The multiple library found warning usually shows up when there is a compilation error, but it is not unusual for more than 1 library to be found, and normally speaking the compiler will pick the correct version.
Thank you Deva_Rishi, I have done that and now everything is compiling as normal. :+1:
Also many thanks to horace for pointing me in the right direction to enable me to compile the sketch to fit on my ESP32 as it always did before :slightly_smiling_face:
