DOT Correction code using arduino
TLC5941 COMMUNICATIONS FIRMWARE
;Scot Lester
;Texas Instruments Incorporated
;February 2008
;This firmware was written for the MSP430F427
;The hardware is configured to have one general
;purpose I/O port (GPIO) configured as all bits being
;outputs. For this example, 6 bits of port one are used to
;drive the TLC5941. Each of the six used GPIO pins of the MSP430
;are connected as follows:
; PIN NAME TLC5941 FUNCTION
; P1.0 BLANK
; P1.1 GSCLK=2MHz
; P1.2 SCLK
; P1.3 XLATCH
; P1.4 MODE
; P1.5 SIN
; P1.6 not used
; P1.7 not used
#include "msp430x42x.h"
; Definition of named constants
#define BLANK (0x01)
#define SCLK (0x04)
#define XLAT (0x08)
#define MODE (0x10)
#define SIN (0x20)
;P1OUT is equal to the memory address of output port.
; RESERVED RAM MEMORY FOR VARIABLES
; Dot Correction values are stored sequentially in 8 bit bytes.
; The TLC5941 only needs 6 bits of dot correction data so the
; dot correction data is stored left justified in the 8 bit byte
; the two least significant bits of each 8 bit byte are set
; to zero in this example but the firmware ignores these
; two bits so they can be any value.
; For example, a binary dot correction value of 101010b = 0x2A
; is stored as 10101000b = 0xA8
ORG 0200h ; Start of RAM
EVEN ; Align data on even boundary
Dot
DB 0xFC ;CH0
DB 0xFC ;CH1
DB 0xF4 ;CH2
DB 0xF8 ;CH3
DB 0xF8 ;CH4
DB 0xFC ;CH5
DB 0xF4 ;CH6
DB 0xF0 ;CH7
DB 0xF4 ;CH8
DB 0xFC ;CH9
DB 0xFC ;CH10
DB 0xFC ;CH11
DB 0xF8 ;CH12
DB 0xF4 ;CH13
DB 0xF4 ;CH14
DB 0xF8 ;CH15
; Grayscale values are stored sequentially in 16 bit words.
; The TLC5941 only needs 12 bits of grayscale so the
; grayscale data is stored left justified in the 16 bit word
; the four least significant bits of each 16 bit word are set
; four bits so they can be any value.
; For example, a hex grayscale value of 0xFFF
; is stored as 0xFFF0
Grayscale
DW 0xAFF0 ;CH0
DW 0xF000 ;CH1
DW 0xF000 ;CH2
DW 0xC000 ;CH3
DW 0xD400 ;CH4
DW 0xE000 ;CH5
DW 0xB000 ;CH6
DW 0xF000 ;CH7
DW 0xFFF0 ;CH8
DW 0x0000 ;CH9
DW 0x0000 ;CH10
DW 0x13F0 ;CH11
DW 0x2380 ;CH12
DW 0xE980 ;CH13
DW 0x0450 ;CH14
DW 0xBA30 ;CH15
ORG 0C000h ; Starting Address of Program Space
RESET ;reset jump vector jumps to here to start execution.
;Program execution begins here after power up and reset
;Typical start up routines should be located here.
;Routines to initialize the stack pointer, watch dog timers, parallel I/O
;ports etc. etc.
;the General Purpose I/O port (P1) needs to be configured with bits 0:5
;set to outputs. At initialization, all output bits should be cleared to zero.
;this is not shown since it is processor specific.
;Bit P1.1 has a special configuration. The output bit is driven by the
;MSP’s internal oscillator which is set to 2MHz. This drives the
;grayscale clock of the TLC5941. Since the output signal is simply the
;system clock, there is no need for the firmware to manipulate this bit.
;The grayscale clock will run continuously.
MOV.W #600h,SP ;Initialize stack pointer to location 600 hex
MOV.W #WDTPW+WDTHOLD,&WDTCTL ; Stop Watchdog Timer
BIS.B #0xFF,&P1DIR ;make all port one GPIO pins outputs
BIS.B #0x02,&P1SEL ;p1.1 = peripheral module output for GSCLK signal.
MOV.B #0x00,&P1OUT ;Initialize all outputs to zero
BIC #GIE,SR ;Turn all interrupts off
;The following commands configure several clocks that are specific to the
;MSP430F427. These commands configure an internal phase locked loop (PLL)
;to generate a 2MHz stem clock from a 32.768KHz external crystal.
MOV.B #63,&SCFQCTL ;set MCLK=64*ACLK or 2MHz
MOV.B #FN_2,&SCFI0 ;set DCO range
BIS.B #02,&FLL_CTL1 ;set ACLK/4
BIC.B #01,&FLL_CTL1 ;set ACLK/4
BIS.B #XCAP18PF,&FLL_CTL0 ;Set load capacitance for xtal
;The following is a delay loop. This delay is needed to wait until the
;crystal oscillator is stable before continuing to execute code. This
;step is MSP430 specific.
MOV.W #10000,R15 ;Initial value for a delay loop
Xtal_Wait
DEC R15 ;Delay for 32 kHz crystal to
JNZ Xtal_Wait ;stabilize
;SET UP TIMER TO MAKE BLANK SIGNAL
;This section sets up a 16 bit timer with interrupt capability. The timer
;is configured to count up to the decimal number 4097. The timer clock signal
;is supplied by the system clock which is also the GSCLK. The timer will count 4097
;GSCLKS and then initiate an interrupt. The timer automatically clears to zero
;then starts to count again to 4097.
;The interrupt routine simply toggles the
;Parallel I/O pin that is connected to the BLANK signal of the TLC5941.
;The TLC5941 will receive 4096 GSCLKS and then get a pulse on the BLANK
;pin to reset the internal counters of the TLC5941
MOV.W #OUTMOD_3+CCIE,&CCTL0 ;CCR1 toggle/set
MOV.W #4097,&CCR0 ;load timer value
MOV.W #TASSEL_2+MC_1,&TACTL ;SMCLK, up mode
BIS.W #GIE,SR ;enable timer interrupt for BLANK signal
;since the grayscale clock run continuously, this timer is used to automatically
;send out BLANK signals to start new display frames.
;This method makes the grayscale clocking transparent to the rest of the
;firmware.
;SEND DC AND GS DATA TO TLC5941
CALL #DCOUT ;call routine to move dot correction
;data to TLC5941
CALL #GSOUT ;call routine to move grayscale
;data to TLC5941
mainloop
NOP
JMP mainloop ;infinite loop when done
; SUBROUTINES
;SEND GRAYSCALE DATA TO TLC5941
;shift out Grayscale data stored in RAM to TLC5941
;clocks out as MSB of channel 15 first then works down through bytes in memory
;shifts of 12 bits per channel for a total of 192 bits.
GSOUT
MOV.W #16,R12 ;Register 12 is a loop counter.
;Loop through 16 LEDs.
MOV.W #Grayscale,R13 ;load register 13 with the starting address of the
;grayscale data stored in RAM. R13 will point to the
;byte to shift out.
ADD.W #32,R13 ;Add 32 to the pointer so that R13 points to the byte after
;the last byte in the grayscale table. The first instruction
;in the following loop is a decrement instruction that will
;make R13 point at the last byte in the table.
ltagsdt
DEC.W R13 ;decrease the address pointer by one byte
MOV.B #08,R9 ;Load register R9 with the number of bits to shift out
;this value will be passed to the SHIFTOUT subroutine
;R13 points to the MSB first in memory so there are 8
;bits to shift out.
MOV.W R13,R8 ;Copy address pointer to R8.The SHIFTOUT
;routine uses R8 to point to the byte to shift out.
CALL #SHIFTOUT ;call subroutine to shift out data
DEC.W R13 ;decrement pointer one byte to point to LSB byte
MOV.B #0x04,R9 ;load R9 with the number of bits in the second byte
;to shift out. Only four bits remain to be shifted
MOV.W R13,R8 ;Copy address pointer to R8. The SHIFTOUT
DEC.W R12 ;decrement loop counter by one
JNZ ltadcdt ;jump if not zero to continue looping
BIS.B #XLAT,&P1OUT ;set the I/O pin for XLATCH high to latch
;serial data into the TLC5941
BIC.B #XLAT,&P1OUT ;set XLATCH back to zero
BIS.B #SCLK,&P1OUT ;set the I/O pin for SLCK high to
;give SCLK one extra pulse after XLATCH
;this is only required if the previous dat sent
;to the TLC5941 was dot correction information
BIS.B #SCLK,&P1OUT ;set I/O pin for SCLK back to zero
RET ;return from subroutine
;SEND DOT CORRECTION DATA TO TLC5941
;shift out dot correction data stored in ram to TLC5941
;shifts 6 bits per LED channel or 96 bits total.
;This routine is very similar to the Grayscale routine. The DCOUT and GSOUT
;routines could be combined together for some memory space savings by
;using some flags and conditional statements.
DCOUT
BIS.B #MODE,&P1OUT ;set I/O line that is tied to the MODE pin of
;the TLC5941 pin to one to enter DC mode
MOV.W #16,R12 ;Register 12 is a loop counter. Loop through 16 LEDs. MOV.W
#Dot,R13
;dot correction data stored in RAM. R13 will point to the
;byte to shift out
ADD.W #16,R13 ;Add 16 to the pointer so that R13 points to the byte after
;the last byte in the dot correction table. The first
;instruction in the following loop is a decrement instruction
;that will make R13 point at the last byte in the table.
ltadcdt
MOV.B #06,R9 ;Load register R9 with the number of bits to shift out
;there are 6 bits to shift out
BIC.B #10h,&P1OUT ;set the I/O line that is tied to the MODE pin of
;the TLC5941 pin to zero to set back to
;grayscale mode
; SHIFT DATA OUT ROUTINE
;clock variable number of bits to TLC5941.
;clocks out as most significant bit first then works down through byte
;r8 = address of byte containing data to shift (word length)
;r9 = number of bits 1-8 to shift out (byte length)
;r10 used for temporary storage for shifting
;This routine shifts out a variable number of bits from a byte
;stored in the location pointed to by R8. The data to be sent
;is stored left aligned to the most significant bit.
;For example, a 6 bit value of 0x3F would be stored as 0xFC
;with the two least significant bits set to zero.
;Registers R8 and R9 are used to pass parameters to this routine.
;Prior to calling this routine, R8 should contain the address of the
;byte of data to be shifted out. R9 should contain the number of bits
;that need to be shifted out.
;R9 will be used as a loop counter in this routine. The contents of R9
;will not be preserved when returning form this routine.
MOV.B @r8,r10 ;move the byte stored in the memory location
;pointed to by register 8 into register 10
ctbit
BIC.B #SIN,&P1OUT ;clear the bit controlling SIN to zero
BIT.B #80h,R10 ;test state of the most significant bit
;of the data remaining to be shifted out
;since we shift the MSB first, the software
;looks at the MSB of R10 to decide what data
;to shift out.
JZ sdateq0 ;if the bit to shift out is a zero then skip ahead
;because SIN was previously set to zero
BIS.B #SIN,&P1OUT ;The data to shift out is a one so set the bit
;controlling SIN to a one
sdateq0
BIS.B #SCLK,&P1OUT ;set the bit controlling SCLK to a one
BIC.B #SCLK,&P1OUT ;clear the bit controlling SCLK to a zero
;the last two commands pulse the SCLK
;signal which latches the data on SIN into
;the shift register of the TLC5941
RLA.B R10 ;shift the data stored in register 10
;one bit left.The LSB of R10 will have a zero
;shifted in.
DEC.B R9 ;decrement number of bits to send
JNZ ctbit ;jump if not zero. continue until all bits are sent
; INTERRUPT ROUTINES
;ISR: Interrupt Service Routine for Timer
;timer interrupt routine
;when the timer count reaches 4097 it will issue an
;interrupt. The processor jumps to here to service the interrupt.
;This interrupt routine toggles the bit controlling the BLANK
;pin of the TLC5941. When the BLANK line of the TLC5941,
;it resets the internal grayscale counter and starts a new
;grayscale frame.
BIS.B #BLANK,&P1OUT ;Toggle bit controlling BLANK
BIC.B #BLANK,&P1OUT ;signal. First high then low.
RETI ;Return from ISR
; Interrupt Vectors
;this segment is used to define the interrupt vectors in memory
ORG 0FFFEh ; RESET Vector
DW RESET ;
ORG 0FFECh ; Timer Interrupt Vector
DW ISR ;
END
what's the question?
I'm writing a code for 16 channel LED driver with DOT Correction, so I have a doubt's please clarify any one.
  1. What is the abbreviation for DOT in DOT Correction.
  2. Any one Can check modifications in this code because this is my first project.
Can any one help me to write a code for 16 Channel LED Driver using DOT Correction
Post your sketch, well formated, with comments and in so called code tags "</>" and schematic to see how we can help.
what is "DOT Correction"?
