I have a musical instrument that needs 5Volt to work. It draws about 200MaH. It normally gets that from a USB input.
I am now adding a 5V power pack, in order to go wireless. Can I leave both 5V sources connected at the same time or will this cause overheating when USB power is plugged in?
Thanks for asking for a diagram - in doing that I have just answered my own question: it seems that I was unwittingly considering connecting the powerbank directly to the USB port on the laptop - maybe not such a good idea
Power supplies are not designed to be operated that way... It would probably be OK, but if the USB power is coming from your computer I wouldn't take risk because even though the odds of frying your computer are slim, one fried computer would ruin your whole day.
It won't hurt your Arduino.
You can put a diode in series with each supply and that will prevent current from flowing backwards into one supply or the other, but you'll get a ~0.7V drop with a regular silicon diode and a ~0.2V drop with a Schottky diode.
Don't ever let two regulated supplies fight it out by connecting them to the same load,
the worst case if everything gets fried (seen it happen) - voltage regulators are
at heart high current high gain amplifiers and are designed to be stable only into
a dissipative load, not another regulator's output.
You can power an Arduino via the DC jack or Vin pin (7V or above) while USB power
is applied as there is a switching circuit on the board especially to enabled this.
You can share supplies via diodes at a pinch, which protects against instability but
loses about 0.7V and generally only takes power from one of them depending on
relative voltages.
