Hi I have situation when I start arduino it run setup message twice, this message shows in serial monitor:
"Set coeficents "
"Set coeficents "
After that I go to main loop and wait for serial input of 24 float numbers(see functon in code: void modArr). Here when I enter 24 numbers it take them but after that he puts 24 zeros again. When I send 48 numbers the he store them in array by name: static float coef[24];
Full code:
#include <TinyGPS++.h>
#include <AltSoftSerial.h>
#include <EEPROM.h>
static const uint32_t GPSBaud = 38400;
// = {5.5, 3.75, 4.0, 3.95, 4.0, 4.1, 4.17, 4.22, 4.21, 4.13, 4.2, 4.23, 4.22, 4.19, 4.17, 4.17, 4.21, 4.21, 4.18, 4.16, 4.13, 4.16, 4.2, 4.23 };
static float kmh[24] = {10, 20, 25, 38, 50, 61, 72, 83, 95, 109, 119, 130, 142, 155,168, 180, 190, 202, 215, 220, 230, 241, 250, 260};
int spd=0;
float spdCoef;
int imp;
TinyGPSPlus gps;
AltSoftSerial ss;
int phrase[3];
String stack="";
bool start = false;
Serial.begin(38400);
ss.begin(GPSBaud);
Serial.println("Set coeficents");
if(start==false){
if(Serial.available()>0){
modArr(coef, 24);
start = true;
if(start==true){
Serial.print(F("Brzina = "));
printFloat(gps.speed.kmph(), gps.speed.isValid(), 6, 2);
Serial.println(F("Km/h"));
smartDelay(100);
spd = gps.speed.kmph();
spdCoef = spdGps(spd);
Serial.println(spdCoef);
imp = spd * spdCoef;
Serial.println(imp);
Serial.println(coef[5]);
Serial.println(kmh[5]);
if (millis() > 5000 && gps.charsProcessed() < 10)
Serial.println(F("No GPS data received: check wiring"));
static void smartDelay(unsigned long ms)
unsigned long start = millis();
do
while (ss.available())
gps.encode(ss.read());
} while (millis() - start < ms);
static void printFloat(float val, bool valid, int len, int prec)
if (!valid)
while (len-- > 1)
Serial.print('*');
Serial.print(' ');
Serial.print(val, prec);
int vi = abs((int)val);
int flen = prec + (val < 0.0 ? 2 : 1); // . and -
flen += vi >= 1000 ? 4 : vi >= 100 ? 3 : vi >= 10 ? 2 : 1;
for (int i=flen; i<len; ++i)
Serial.print(' ');
smartDelay(0);
int spdGps(int spdVal){
for(int i=0;i<sizeof(kmh);i++){
if (spd>kmh[i] && kmh[i+1]>spd) {
int y = map(spdVal, kmh[i], kmh[i+1], coef[i], coef[i+1]);
return y;
void modArr(float arr[], int sizeArr){
while (Serial.available() > 0){
for (int i=0; i<sizeArr; i++)
arr[i] = Serial.parseFloat();
Serial.println(arr[i]);
Serial.println(i);
