Draguino Lora Shield on MEGA 2560
Hi there.
I used a Draguino Lora Shield with the LoRa.h library.
https://wiki.dragino.com/index.php?title=Lora_Shield
I combined it wit ha RTC SD Card module with the DS1307RTC.h library.
Micro SD Datenlogger Modul mit RTC - Bastelgarage Elektronik Online Shop?
CS => Pin: 10
MOSI => Pin: 11
MISO => Pin: 12
SCK => Pin: 13
SCL => Pin: A5
SDA => Pin: A4
GND => Pin: GND
5V =>Pin: 5V
As the CSPin on the Draguino is fixed to 10, I changed it for the SD Module to 4.
As I use a Atmega 2560, I had an Error by initializing the SD Card, Even when I forced the Pin 10 to HIGH. As I changed to a UNO with the same Pin connection it worked (also without PIN 10 high).
Although it works like that for me, I really would like to understand why?
Has anybody an idea?
Here is the code:
#include <SPI.h>
#include <SD.h>
#include <Wire.h>
#include <TimeLib.h>
#include <DS1307RTC.h>
#include <LoRa.h>
    //digitalWrite(10, HIGH);
    while (!Serial);
    Serial.println("LoRa Receiver");
    if (!LoRa.begin(915E6)) {
        Serial.println("Starting LoRa failed!");
        while (1);
    Serial.print("Initializing SD card...");
    // see if the card is present and can be initialized:
    if (!SD.begin(4)) {
        Serial.println("Card failed, or not present");
        // don't do anything more:
        while (1);
    Serial.println("card initialized.");
    // try to parse packet
    int packetSize = LoRa.parsePacket();
    if (packetSize) {
        // received a packet
        Serial.print("Received packet '");
        // read packet
        while (LoRa.available()) {
            Serial.print((char)LoRa.read());
        // print RSSI of packet
        Serial.print("' with RSSI ");
        Serial.println(LoRa.packetRssi());
Thanks in advance. :slight_smile:
Pascal
Those are not the SPI and I2C pins on a Mega 2560.
Ah... So true
But the Draguino LoRa shield worked on Atmega 2560 because ist goes over ICSP and not over D11,12,13 :open_mouth:
Now it's clear.
Thanks :wink:
