Well, if you insist on the code, here goes:
//SD///////
#include <SPI.h>
#include <SD.h>
//LORA
#include <LoRa.h>
//TEMPERATURE N HUMIDITY//////////////
#include <SparkFunHTU21D.h>
//BMP180////////////////////////////////////////
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BMP085_U.h>
//GPS STUFF////////////////
#include <SoftwareSerial.h>
SoftwareSerial GPS(3, 5);
byte gps_set_sucess = 0 ;
char gpssentence[66];
//BMP180//////////
Adafruit_BMP085_Unified bmp = Adafruit_BMP085_Unified(10085);
float pressure;
float inTemp;
//Ozone//////////////
int OZval;
//UV/////
float uvIntensity;
/////Temp +Hum///////
HTU21D myHumidity;
float humidity;
float temp;
//SD//////
const int chipSelect = 4;
pinMode(A0, INPUT);
//GPS STUF/////////////////////////
GPS.begin(9600);
// START OUR SERIAL DEBUG PORT
Serial.println(F("GPS Level Convertor Board Test Script"));
Serial.println(F("03/06/2012 2E0UPU"));
Serial.println(F("Initialising...."));
// THE FOLLOWING COMMAND SWITCHES MODULE TO 4800 BAUD
// THEN SWITCHES THE SOFTWARE SERIAL TO 4,800 BAUD
GPS.print(F("$PUBX,41,1,0007,0003,4800,0*13\r\n"));
GPS.begin(4800);
GPS.flush();
// THIS COMMAND SETS FLIGHT MODE AND CONFIRMS IT
Serial.println(F("Setting uBlox nav mode: "));
uint8_t setNav[] = {
0xB5, 0x62, 0x06, 0x24, 0x24, 0x00, 0xFF, 0xFF, 0x06, 0x03, 0x00, 0x00, 0x00, 0x00, 0x10, 0x27, 0x00, 0x00,
0x05, 0x00, 0xFA, 0x00, 0xFA, 0x00, 0x64, 0x00, 0x2C, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x16, 0xDC };
while(!gps_set_sucess)
sendUBX(setNav, sizeof(setNav)/sizeof(uint8_t));
gps_set_sucess=getUBX_ACK(setNav);
gps_set_sucess=0;
GPS.println(F("$PUBX,40,GLL,0,0,0,0*5C"));
GPS.println(F("$PUBX,40,GGA,0,0,0,0*5A"));
GPS.println(F("$PUBX,40,GSA,0,0,0,0*4E"));
GPS.println(F("$PUBX,40,RMC,0,0,0,0*47"));
GPS.println(F("$PUBX,40,GSV,0,0,0,0*59"));
GPS.println(F("$PUBX,40,VTG,0,0,0,0*5E"));
if(!bmp.begin())
/* There was a problem detecting the BMP085 ... check your connections */
Serial.print(F("Ooops, no BMP085 detected ... Check your wiring or I2C ADDR!"));
while(1);
//Temp + Humidity///////
myHumidity.begin();
//SD////////
Serial.print(F("Initializing SD card..."));
// see if the card is present and can be initialized:
if (!SD.begin(chipSelect)) {
Serial.println(F("Card failed, or not present"));
// don't do anything more:
return;
Serial.println(F("card initialized."));
Serial.println("$PUBX, ID, Time, Lattitude, N, Longtitude, E, Altitude, SatFix, Hacc, Vacc, Rest, pressure, InTemp, OZ, UV, outTemp, Humidity");
File logdataE = SD.open("TheData.txt", FILE_WRITE);
if (logdataE) {
logdataE.println("$PUBX, ID, Time, Lattitude, N, Longtitude, E, Altitude, SatFix, Hacc, Vacc, Rest, pressure, InTemp, OZ, UV, outTemp, Humidity");
logdataE.close();
else {
//Datei kann nicht geöffnet werden
Serial.println("Error");
//LORA
if (!LoRa.begin(433E6)) {
Serial.println("Starting LoRa failed!");
while (1);
getgps();
readsensors();
logdata();
senddata();
unsigned long previousMillis = millis();
while (currentMillis - previousMillis <= 3000) {
// save the last time you blinked the LED
void getgps(){
GPS.println(F("$PUBX,00*33"));
while (GPS.available())
for (int i=0; i <66 ; i++)
gpssentence[i] = GPS.read();
void readsensors(){
getBarTemp();
getOZ();
getUV();
getTempHum();
void logdata(){
File dataFile = SD.open("theData.txt", FILE_WRITE);
// if the file is available, write to it:
if (dataFile) {
dataFile.print(gpssentence[i]);
dataFile.print(F(", "));
dataFile.print(pressure);
dataFile.print(inTemp);
dataFile.print(OZval);
dataFile.print(uvIntensity);
dataFile.print(temp);
dataFile.println(humidity);
dataFile.close();
Serial.print(gpssentence[i]);
Serial.print(F(", "));
Serial.print(pressure);
Serial.print(inTemp);
Serial.print(OZval);
Serial.print(uvIntensity);
Serial.print(temp);
Serial.println(humidity);
// if the file isn't open, pop up an error:
else {
Serial.println(F("error opening datalog.txt"));
void getBarTemp(){
/* Get a new sensor event */
sensors_event_t event;
bmp.getEvent(&event);
if (event.pressure)
pressure = event.pressure;
bmp.getTemperature(&inTemp);
Serial.println(F("Sensor error"));
void getOZ(){
OZval = analogRead(1);
void getUV(){
int uvLevel = averageAnalogRead(A0);
float outputVoltage = uvLevel * (5.0 / 1023.0);
uvIntensity = mapfloat(outputVoltage, 0.99, 2.8, 0.0, 15.0);
void getTempHum(){
humidity = myHumidity.readHumidity();
temp = myHumidity.readTemperature();
void senddata(){
LoRa.beginPacket();
LoRa.print(gpssentence[i]);
LoRa.print(F(", "));
LoRa.print(pressure);
LoRa.print(inTemp);
LoRa.print(OZval);
LoRa.print(uvIntensity);
LoRa.print(temp);
LoRa.println(humidity);
LoRa.endPacket();
// Send a byte array of UBX protocol to the GPS
void sendUBX(uint8_t *MSG, uint8_t len) {
for(int i=0; i<len; i++) {
GPS.write(MSG[i]);
Serial.print(MSG[i], HEX);
GPS.println();
// Calculate expected UBX ACK packet and parse UBX response from GPS
boolean getUBX_ACK(uint8_t *MSG) {
uint8_t b;
uint8_t ackByteID = 0;
uint8_t ackPacket[10];
unsigned long startTime = millis();
Serial.print(F(" * Reading ACK response: "));
// Construct the expected ACK packet
ackPacket[0] = 0xB5; // header
ackPacket[1] = 0x62; // header
ackPacket[2] = 0x05; // class
ackPacket[3] = 0x01; // id
ackPacket[4] = 0x02; // length
ackPacket[5] = 0x00;
ackPacket[6] = MSG[2]; // ACK class
ackPacket[7] = MSG[3]; // ACK id
ackPacket[8] = 0; // CK_A
ackPacket[9] = 0; // CK_B
// Calculate the checksums
for (uint8_t i=2; i<8; i++) {
ackPacket[8] = ackPacket[8] + ackPacket[i];
ackPacket[9] = ackPacket[9] + ackPacket[8];
while (1) {
// Test for success
if (ackByteID > 9) {
// All packets in order!
Serial.println(F(" (SUCCESS!)"));
return true;
// Timeout if no valid response in 3 seconds
if (millis() - startTime > 3000) {
Serial.println(F(" (FAILED!)"));
return false;
// Make sure data is available to read
if (GPS.available()) {
b = GPS.read();
// Check that bytes arrive in sequence as per expected ACK packet
if (b == ackPacket[ackByteID]) {
ackByteID++;
Serial.print(b, HEX);
else {
ackByteID = 0; // Reset and look again, invalid order
Have fun reading it all
So you reckon it might work if I add this line after I'm done with the SD?
SPI.transfer(0XFF);
