Hi everyone I've got an IR LED which I'm using for a project to control air conditioning, but the Range is terrible. I've read that the Arduino can only put out 30 Ma from a digital pin, and thus a transistor is needed for higher applications. I have never use a transistor before but I have used mofets and I assume the process is the same ?
Can someone draw me the most basic way I can connect a resistor and transistor to a pwm pin on my Arduino to get around 100 Ma please. Or at least a recommended transistor and a description of what connectshe to what.
You can also consider getting an IR led with a narrow "viewing angle" so the beam is more strongly focused and is, therefore, likely to have a better performance.
Farnell stock a range from 3 degrees to over 150 degrees. Look for IR emitters.
I'd consider 10 degrees or below for such an application where you require some range, and are able to direct the beam towards the receiver with reasonable accuracy.
