Driving 24V LED with arduino
Greetings.
I have a question i cannot seem to get an anwser to. So i have 10 24V LEDs. Here is a link:
https://www.aliexpress.com/item/32893389611.html?spm=a2g0o.productlist.0.0.42d543fbL3kCD0&algo_pvid=9c61f9a8-d3c2-4dc2-9771-d15be26700f5&algo_expid=9c61f9a8-d3c2-4dc2-9771-d15be26700f5-34&btsid=0ab50f6215881503645153531e7eb3&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_
I would like to control them (they should be blinking) with a Arduino Mega that i have...but i dont know what a proper circuit would be...MOSFETs would be a good idea but all i see on the internet is people using them for LED strips...I however would like to drive each 24V LED from a different ouptut pit.
Thank you for your help experts!
Have a look at
The closest on there to what you want is Q3, replace the relay with your LEDs and power from 24V.
OPs LEDs.
24V LED Bulb Car Auto Front Lights 1156 22SMD P21W BA15S Brake Lights Lights Turn Lights Parrking Lamp Bulb 12V
Specifications:
  1. Voltage: 24V DC
  2. Socket: BA15S
  3. LED: SMD
  4. Spec: P21W 1156/1157 22SMD
  5. Led Type: 3014 Chips
  6. Wattage: 3W
  7. Angle of light: 180 degree
  8. Color: White Red Yellow Green Blue Pink
  9. Life Time: about 50,000 hours
  10. Top Quality
  11. Easy to Install
  12. Long service life time.
Package:
2 x LED bulb
Tom.. :slight_smile:
Ok so 24V to the positive rail of LED, negative rail from the LED to drain, 220R resistor to the gate and sink to GND should simply do the trick? Should i have a heat sink on the mosfets? The wattage is small though?
Thank you for your help!!
xcg584:
That's about right. You should not need a heatsink.
Thank you very much for the help!!
