Ds18b20 and thing speak
Hi, everybody, I hope I'm in the right place, otherwise I apologize to the moderators.
I need help for a sketch that should send the data of a ds18b20 to ThingSpeak.
Can somebody help me? Thank you.
#include <Ethernet.h>
//Include libraries
#include <OneWire.h>
#include <DallasTemperature.h>
// Data wire pin 5
#define ONE_WIRE_BUS 5
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
EthernetClient client;
String postStr;
const char* server = "api.thingspeak.com";
String apiKey = "XXXXXXXX"; // (metti il codice che ti dà thingspeak)
String TUA_VARIABILE;
void setup(void) {
  Serial.begin(9600); //Begin serial communication
  sensors.begin();
void loop(void)
  // legge il sensore
  sensors.requestTemperatures();
  Serial.print("Temperature is: ");
  //Serial.println(sensors.getTempCByIndex(0));
  TUA_VARIABILE = (sensors.getTempCByIndex(0));
  Serial.println (TUA_VARIABILE);
  //Scrive su thingspeak
  if (client.connect(server, 80))
    String postStr = apiKey; // è la chiave che hai definito sopra
    postStr +="&field1="; // dice che devi scrivere sul campo uno
    postStr +=String(TUA_VARIABILE); // qui inserisci il tuo campo che vuoi scrivere.
    postStr +="\r\n\r\n"; //conclude la stringa se non ricordo male
    Serial.println(postStr);
    client.print("POST /update HTTP/1.1\n");
    client.print("Host: api.thingspeak.com\n");
    client.print("Connection: close\n");
    client.print("X-THINGSPEAKAPIKEY: " + apiKey + "\n");
    client.print("Content-Type: application/x-www-form-urlencoded\n");
    client.print("Content-Length:");
    client.print(postStr.length());
    client.print("\n\n");
    client.print(postStr);
    //client.stop();
    delay(20000);
No, because you've yet to tell us what the problem is.
Ah! Sorry, I missed a bit of the text (copy and paste error from deepl).
The problem is that no value is sent to the thingspeak channel.
The variable TUA_VARIABLE assumes correctly the value read by the sensor but then I can't send it to the channel.
Thank you very much
pylon:
Hi, I've been looking around and I came up with this:
//Include libraries
#include <ThingSpeak.h>
// Data wire pin 5
String postStr;
const char* server ="api.thingspeak.com";
String apiKey = "XxxxxxxXXXXXxx"; // (metti il codice che ti dà thingspeak)
float TUA_VARIABILE;
void setup(void) {
  sensors.begin();
void loop(void)
  // legge il sensore
  Serial.println (TUA_VARIABILE); //  questa istruzione l'ho messa per essere sicuro che la variabile prendesse il valore letto dal sensore
    postStr +=float(TUA_VARIABILE); // qui inserisci il tuo campo che vuoi scrivere.
    //client.stop();
    delay(20000);
What I figured out is that you don't execute the part of the code after the bracket on the instruction.
if (client.connect(server, 80)) as the instruction Serial.println(postStr); never appears on the serial monitor.
But I don't understand why it doesn't connect.
Thank you
Last year I constructed a sniffer box: a weather station that sends data collected by a DS18B20 and a DHT11 to a (private) channel on Thingspeak.
Here is a link to the detailed description of the sniffer box. You can download a sketch there.
Thanks but link is incorrect.
If you point with your mouse arrow on the link and do a right-click there is an option copy link-adress
http://www.zonnepanelen.wouterlood.com/30-sniffer-box-portable-weather-station-with-esp8266-wifi/http://
can you see where the error is?
Just delete the wrongly added letters and try again
best regards Stefan
This error
StefanL38:
best regards Stefan
Thanks!
OOPS!
The correct link is: sniffer-box
There is much more Arduino stuff here
Success!
Many thanks!
