Hallo,
ich komme nicht weiter
Da ein 16x2 LCD Display aus größerer Entfernung kaum noch zu lesen ist, habe ich mich für gute alte 7-Segment LED Anzeigen entschieden. Die Hardware ist auch nicht das Problem. Der Beispielsketch für den SAA1064 funktioniert auch.
Example 39.1 - NXP SAA1064 I2C LED Driver IC Demo I
Demonstrating display of digits
http://tronixstuff.com/tutorials > chapter 39
John Boxall July 2011 | CC by-sa-nc
#include "Wire.h" // enable I2C bus
byte saa1064 = 0x70 >> 1; // define the I2C bus address for our SAA1064 (pin 1 to GND) ****
int digits[16]={63, 6, 91, 79, 102, 109, 125,7, 127, 111, 119, 124, 57, 94, 121, 113};
// these are the byte representations of pins required to display each digit 0~9 then A~F
Wire.begin(); // start up I2C bus
initDisplay();
void initDisplay()
// turns on dynamic mode and adjusts segment current to 12mA
Wire.beginTransmission(saa1064);
Wire.write(B00000000); // this is the instruction byte. Zero means the next byte is the control byte
Wire.write(B01110111); // control byte (dynamic mode on, digits 1+3 on, digits 2+4 on, 12mA segment current
Wire.endTransmission();
void displayDigits()
// show all digits 0~9, A~F on all digits of display
for (int z=0; z<16; z++)
Wire.write(1); // instruction byte - first digit to control is 1 (right hand side)
Wire.write(digits[z]); // digit 1 (RHS)
Wire.write(digits[z]); // digit 2
Wire.write(digits[z]); // digit 3
Wire.write(digits[z]); // digit 4 (LHS)
// now repeat but with decimal point
Wire.write(digits[z]+128); // digit 1 (RHS)
Wire.write(digits[z]+128); // digit 2
Wire.write(digits[z]+128); // digit 3
Wire.write(digits[z]+128); // digit 4 (LHS)
void clearDisplay()
// clears all digits
Wire.write(0); // digit 1 (RHS)
Wire.write(0); // digit 2
Wire.write(0); // digit 3
Wire.write(0); // digit 4 (LHS)
displayDigits();
clearDisplay();
/* **** We bitshift the address as the SAA1064 doesn't have the address 0x70 (ADR pin
to GND) but 0x38 and Arduino uses 7-bit addresses- so 8-bit addresses have to
be shifted to the right one bit. Thanks to Malcolm Cox */
Den Segmentstrom habe ich schon auf das Maximum von 21 mA hochgedreht mit Wire.write(B01110111)
Die linke Stelle habe ich kopfstehend montiert, da sie °C zeigen soll. Wenn ich bei int digits 143 hinterlege, erscheint auch das stilisierte °C
Nur was ich nicht gebacken kriege, wie ich vom Temperatursensor aus den 12 Bits Binär auf meine einzelnen Stellen komme. Ach ja, das Minus bei negativer Temperatur würde ich mit 64 angezeigt bekommen. In der zweiten Stelle von links müßte ich dann noch den dezimalpunkt ansteuern, also 128 addieren...
Nur wie die beiden Codeschnipsel verwurstet werden müssen, habe ich keinen Plan.
Von einem normalen LCD auf ein I2C-LCD "umzustricken", habe ich hin bekommen. Nur hat der SAA1064 nicht so viel Eigenintelligenz, wie ein 16x2 LCD kopfkratz
Google habe ich auch schon bemüht... Beides für sich ist problemlos zu finden, aber beides in Kombination - Bilder ja, Code nein =(
Gruß Gerald
