Ds18b20 temperature sensor -127 error
Hi, I am working on a project. I am using ds18b20 temperature sensor and at first it was working well. After I tried it again, it reads only -127 degree celcius. This is my code, the conditions are for relay function. What could be the problem? Thank you.
#include <OneWire.h>
#include <DallasTemperature.h>
#define ONE_WIRE_BUS 3
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
int delayCount = 200;
int printDelay = 5000;
//temperature
float Cs = 0;
float Fr = 0;
float Celsius = 0;
float Fahrenheit = 0;
sensors.begin();
pinMode(3, OUTPUT); //peltier
pinMode(4, OUTPUT); //cooler
compTemp();
//Water Temp Sensor
void compTemp()
Serial.print(Celsius);
Serial.print(" C ");
Serial.print(Fahrenheit);
Serial.println(" F");
// Read Temperature
sensors.requestTemperatures();
Cs = sensors.getTempCByIndex(0);
Fr = sensors.toFahrenheit(Cs);
//Select if Celsius [Cs] or Fahrenheit [Fr]
float temp = Cs;
if (temp > 23)
digitalWrite(3, LOW);
digitalWrite(4, LOW);
delay(delayCount);
else if (temp < 12)
digitalWrite(3, HIGH);
digitalWrite(4, HIGH);
delay(delayCount);
Serial.print("Temp:");
Serial.print(temp, 1);
Serial.print("C");
Since it worked well at first, you can check again whether a cable has come loose or whether you have changed something in the circuit diagram.
@aizhelle
Please read the forum guidelines and isert the code using the code tags.
Celsius or Fahrenheit are always 0.
Do you have a pull-up resistor on the bus?
Are those the pins you are actually using for both the DS18B20 and the peltier cooler?
@david_2018 good catch.
Plenty wrong with the code.
