DS18B20 works on UNO but shows -127 on MKR 1010
Hi, may someone please help me understand where my error is connecting the DS18B20 waterproof sensor to the Arduino Opla through the MKR Wifi 1010?
I have correct temperature readings from the sensor using UNO but when I connect it to MKR 1010 and run a modified sketch (originally the Smart Garden project) to also take the DS18B20 input, I can't get the temperature, just reading -127 (the error code?).
The sensor cable is properly connected through a PlugableTerminal to MKR's VCC (3.3V), GND and PIN 6.
I went through many related posts but couldn't pin the issue, also just starting with Arduino IoT, I would really appreciate any suggestions, thank you!
#include <OneWire.h>
#include <DallasTemperature.h>
#include "thingProperties.h"
#include <Arduino_MKRIoTCarrier.h>
MKRIoTCarrier carrier;
#define ONE_WIRE_BUS 6
// Setup a oneWire instance to communicate with any OneWire devices
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature sensor
DallasTemperature sensors(&oneWire);
int moistPin;
String waterPumpState;
String coolingFanState;
String lightState;
uint32_t lightsOn = carrier.leds.Color(82, 118, 115);
uint32_t lightsOff = carrier.leds.Color(0, 0, 0);
  // Initialize serial and wait for port to open:
  // This delay gives the chance to wait for a Serial Monitor without blocking if none is found
  delay(1500);
  sensors.begin();
  sensors.setResolution(12);
  // Defined in thingProperties.h
  initProperties();
  // Connect to Arduino IoT Cloud
  ArduinoCloud.begin(ArduinoIoTPreferredConnection);
  //Get Cloud Info/errors , 0 (only errors) up to 4
  setDebugMessageLevel(2);
  ArduinoCloud.printDebugInfo();
  //Wait to get cloud connection to init the carrier
  while (ArduinoCloud.connected() != 1) {
    ArduinoCloud.update();
  CARRIER_CASE = false;
  carrier.begin();
  moistPin = carrier.getBoardRevision() == 1 ? A5 : A0; //assign A0 or A5 based on HW revision
  carrier.display.setRotation(0);
  delay(1500);
  //Update the Cloud
  sensors.requestTemperatures();
  //read temperature and humidity
  temperature = carrier.Env.readTemperature();
  humidity = carrier.Env.readHumidity();
  water = waterTemperature();
  //read raw moisture value
  int raw_moisture = analogRead(moistPin);
  //map raw moisture to a scale of 0 - 100
  moisture = map(raw_moisture, 0, 1023, 0, 100);
  //read ambient light
  while (!carrier.Light.colorAvailable()) {
    delay(5);
  int none; //We dont need RGB colors
  carrier.Light.readColor(none, none, none, light);
  Serial.print("Celsius temperature: ");
  Serial.print(sensors.getTempCByIndex(0));
  Serial.print(" - Fahrenheit temperature: ");
  Serial.println(sensors.getTempFByIndex(0));
  //water = sensors.getTempCByIndex(0);
  delay(100);
float waterTemperature() {
  float waterTemp = sensors.getTempCByIndex(0);
  return waterTemp;
void onWaterpumpChange() {
  if (waterpump == true) {
    carrier.Relay2.open();
    waterPumpState = "PUMP: ON";
    carrier.Relay2.close();
    waterPumpState = "PUMP: OFF";
  updateScreen();
void onCoolingFanChange() {
  if (cooling_fan == true) {
    carrier.Relay1.open();
    //coolingFanState = "FAN: ON";
    coolingFanState = "TEMP: C";
    carrier.Relay1.close();
    //coolingFanState = "FAN: OFF";
    coolingFanState = "TEMP: F";
  updateScreen();
void onArtificialLightChange() {
  if (artificial_light == true) {
    carrier.leds.fill(lightsOn, 0, 5);
    carrier.leds.show();
    lightState = "BLACK: 100C";
    carrier.leds.fill(lightsOff, 0, 5);
    lightState = "GREEN: 70C";
  updateScreen();
//Update displayed Info
void updateScreen() {
  carrier.display.fillScreen(ST77XX_BLACK);
  carrier.display.setTextColor(ST77XX_WHITE);
  carrier.display.setTextSize(3);
  carrier.display.setCursor(40, 50);
  carrier.display.print(water);
  carrier.display.setCursor(40, 90);
  carrier.display.print(coolingFanState);
  carrier.display.setCursor(40, 130);
  carrier.display.print(lightState);
Here is also the thingProperties.h:
// Code generated by Arduino IoT Cloud, DO NOT EDIT.
#include <ArduinoIoTCloud.h>
#include <Arduino_ConnectionHandler.h>
const char SSID[]     = SECRET_SSID;    // Network SSID (name)
const char PASS[]     = SECRET_OPTIONAL_PASS;    // Network password (use for WPA, or use as key for WEP)
void onArtificialLightChange();
void onCoolingFanChange();
void onWaterpumpChange();
float humidity;
float temperature;
float water;
int light;
int moisture;
bool artificial_light;
bool cooling_fan;
bool waterpump;
void initProperties(){
  ArduinoCloud.addProperty(humidity, READ, ON_CHANGE, NULL);
  ArduinoCloud.addProperty(temperature, READ, ON_CHANGE, NULL);
  ArduinoCloud.addProperty(water, READ, 2 * SECONDS, NULL);
  ArduinoCloud.addProperty(light, READ, ON_CHANGE, NULL);
  ArduinoCloud.addProperty(moisture, READ, ON_CHANGE, NULL);
  ArduinoCloud.addProperty(artificial_light, READWRITE, ON_CHANGE, onArtificialLightChange);
  ArduinoCloud.addProperty(cooling_fan, READWRITE, ON_CHANGE, onCoolingFanChange);
  ArduinoCloud.addProperty(waterpump, READWRITE, ON_CHANGE, onWaterpumpChange);
WiFiConnectionHandler ArduinoIoTPreferredConnection(SSID, PASS);
Hello
Could try the example sketch directly on your Arduino without using IoT just to isolate the problem?
Also, share your schematic pls
You don't mention it, but I assume that you have the pull up resistor present on the DS18B20 DQ line?
I have read that some (fake) Ds18B20 don't work well on 3.3volt power.
You can power the sensor from 5volt on a 3.3volt-logic board, as long as you pull up the data pin to 3.3volt.
Leo..
I also had troubles using the (fake) DS18B20 sensors with my 3.3v MKR boards. Particularly with cable lengths longer than a couple feet.
Heres a few things that helped it work for me.(applies to any dallas network)
#1 Adjust the pull up resistance. I believe 3k3 worked in my case.
#2 Add a 100nF capacitor between Vcc and grd at the sensor.
#3 Add a 100 ohm resistor in series between the arduino input pin and the DS18B20 output.Place it closest to the arduino.
On one project because I had multiple sensors on a long cable( >15 meters )
I had to buy genuine DS18B20's to get it to work reliably.
Dear all, thanks to your helpful suggestions, I disconnected the MKR 1010 from OplĂ  to test my original DS18B30 on pin 6 and it worked with 3.3V. So I looked at the MKR and OplĂ  pinouts (that I should have started with) and it seems pin 6 was taken with all the sensor inputs from OplĂ . I switched to pin 2 and voilĂ ... it reads temperature properly!
