Sorry...
I just made a copy from the Serial.print bits outputs. I use my own software.
That is working well with the old units and CRC is OK in both cases, so ...
Here is cpp, if you need .h file I can copy it too
Interrupt-free, small memory wasting ds1820 interface (about 1200 bytes)
this is working with any pin who allow digitalRead and digitalWrite.
Interrupt suspend should not be longer than 85 uSec for each written bit and
less than 10uSec for the other occurencys.
2 steps : first converting (could be as long as 750 mSec) then get value.
convertDs(uint8_t pin) returns 1 or error codes (see below)
readDs(uint8_t pin) returns float value between -55 and +125 or error codes (see below)
getDs(uint8_t pin,uint8_t* frameout,uint8_t nbbyteout,uint8_t* framein,uint8_t nbbytein)
return a status (codes below) and fill framein with data provided by Ds in accordance
with the frameout data transmitted to Ds.
(see datasheet)
pin is the Arduino pin number used to connect Ds unit
#include "Arduino.h"
#include "Ds1820.h"
// possible return status for getDs() function
// values between -55 to +125 are valid data
#define TOPRES -100
#define CRC_ERR -101 // CRC check not implemented
#define T_WAIT_PRESENCE 240
Ds1820::Ds1820()
byte calcBitCrc(byte shiftReg, byte data_bit);
static uint8_t maskbit[]={1,2,4,8,16,32,64,128}; // 128,64,32,16,8,4,2,1
void writeDs(uint8_t pin,uint8_t nbbyteout,uint8_t* frameout)
//write command nbbyteout @ nbbit/byte
boolean pinstat=HIGH;
uint8_t i=0,j=0,delaylow,delayhigh;
digitalWrite(pin,HIGH);
pinMode(pin,OUTPUT);
for(i=0;i<nbbyteout;i++){//Serial.print(frameout[i],HEX);
for(j=0;j<8;j++){
delaylow=80;delayhigh=0;pinstat=LOW;if((frameout[i] & maskbit[j])!=0){pinstat=HIGH;delaylow=0;delayhigh=80;}
noInterrupts();
digitalWrite(pin,LOW);
// if bit =1 low state about 2,7 uSec long (UNO)
delayMicroseconds(delaylow);digitalWrite(pin,pinstat);delayMicroseconds(delayhigh);
interrupts();
pinMode(pin,INPUT);
//Serial.println();
int Ds1820::convertDs(uint8_t pin)
uint8_t h[2]={0xCC,0x44},r[2];
return getDs(pin,h,2,r,0);
float Ds1820::readDs(uint8_t pin)
uint8_t cmd[2]={0xCC,0xBE},rep[9];
int v;
float th=0,th0=0;
v=getDs(pin,cmd,2,rep,9);
//Serial.print((int)rep[0]/2);Serial.print(" ");Serial.print(v);Serial.print(" ");Serial.print((int)rep[7]);Serial.print(" ");Serial.print((int)rep[6]);Serial.print(" ");Serial.println((float)(rep[7]-rep[6])/rep[7]);
if(v<-100){return v;}
else{th=(float)((int)(rep[0]/2)-0.25+(float)(rep[7]-rep[6])/rep[7]);}
Serial.print(th);
th0=th*10-(int)(th*10);if(th0>0.5){th+=0.1;}th=(int)(th*10);th=(float)(th/10);
Serial.print(" ");Serial.print(th0);Serial.print(" ");Serial.println(th);
return th;
int Ds1820::getDs(uint8_t pin,uint8_t* frameout,uint8_t nbbyteout,uint8_t* framein,uint8_t nbbytein)
uint8_t crc=0;
uint8_t i=0,j=0,v=0;
long micr=0;
uint8_t delaylow=0,delayhigh=0;
uint8_t buff[128];for(i=0;i<128;i++){buff[i]=0;}
//reset pulse
noInterrupts();
interrupts();
delay(1);
delayMicroseconds(500);
pinMode(pin,INPUT);
delayMicroseconds(65);
//presence detect
micr=micros();
while(1){
if(micros()>(micr+T_WAIT_PRESENCE)){return TOPRES;} // pas de réponse
if(digitalRead(pin)==LOW){delayMicroseconds(400);break;}
// write command
writeDs(pin,nbbyteout,frameout);
//read response nbbytein @ 8 bits/byte
if(nbbytein!=0){
memset(framein,0,nbbytein);
for (i=0;i<nbbytein;i++){
for (j=0;j<8;j++){
v=i*8+j;
noInterrupts();
// delay between low and read about 5,2 uSec (UNO) + delayMicroseconds
// delayMicroseconds is n-1 micros ; pinMode about 3,1 uSec
pinMode(pin,INPUT);delayMicroseconds(0);buff[v]=digitalRead(pin);
interrupts();
if(buff[v]!=0){framein[i]+= maskbit[j];}
delayMicroseconds(50);//Serial.print(buff[v]);
}//Serial.print(" ");
}//Serial.println();
// check CRC
byte shift_reg=0;
for(i=0;i<nbbytein;i++){
for(j=0;j<8;j++){shift_reg=calcBitCrc(shift_reg,buff[i*8+j]);
Serial.print(buff[i*8+j]);
Serial.print(" ");
Serial.print(" CRC ");Serial.println(shift_reg);
if(shift_reg==0){return 1;}else{return CRC_ERR;}
byte Ds1820::calcBitCrc (byte shiftReg, byte data_bit)
byte fb;
fb = (shiftReg & 0x01) ^ data_bit;
/* exclusive or least sig bit of current shift reg with the data bit */
shiftReg = shiftReg >> 1; /* shift one place to the right */
if (fb==1){shiftReg = shiftReg ^ 0x8C;} /* CRC ^ binary 1000 1100 */
return(shiftReg);
