I have an RTC module like this, but I am struggling to find a drawing about its dimensions.
If anyone here has it please share.
thanks,
Istvan
thanks,
Istvan
Istvanb:
Hi,I have an RTC module like this, but I am struggling to find a drawing about its dimensions.
thanks,
Istvan
If you have the module there, can't you simply measure it?
Legit question... I dont have a caliper though. As the main pins are soldered with L shaped pins, I cant just use another 4 pin header and insert the module to a breadboard. Just by look I have the feeling that the connectors at the side of the boards are not lined up.
Istvanb:
I doubt very much if you'll find a diagram with full dimensions including distance betweens pins on the two headers.
How do you plan to mount it? You could always remove the right-angle header, flip the board over, then dry test the board in a plug-in breadboard with a pair of straight headers.
The pin spacing will be 0.1" / 2.54mm, thats the standard size for that kind of connector, they do not make other really odd sizes.
Any Reason you why you cannot just plug it into the breadboard vertically, my RTC modules do.
Great idea... I just did it and it was fairly easy to design the footprint of the module. I have attached the result if anybody else will be interested in the future. The grid size is 100mil x 100mil
Thanks for the tip!
Istvanb:
Great idea... I just did it and it was fairly easy to design the footprint of the module. I have attached the result if anybody else will be interested in the future. The grid size is 100mil x 100milThanks for the tip!
No problem. (I thought it looked like the 4-pin header would line up with the middle 4 pins of the 6-pin header.)
