Hey folks! I have an Arduino Mega 2560, a DS3234 RTC, and an arduino TFT screen (this one: https://www.arduino.cc/en/Guide/TFT). They both work fine independently, but I’m having problems with the RTC when I connect the lcd screen as well. I’m not too familiar with SPI so I was wondering if someone here could help me with this issue.
The pin connections for RTC are:
CLK - 52
MISO - 50
MOSI - 51
SS - 44
for the lcd screen:
MISO - 50
SCK - 52
MOSI - 51
CS-LD - 28
DC-LD - 26
RESET - 24
If I understand correctly, the MISO, MOSI and CLK pins should be the same for both devices, only the chip select pin needs to be different. The devices that I want to communicate with needs to have its CS pin LOW, and the other device needs to have its HIGH.
I wrote a simple program that sets the RTC time, and displays the second. I have set the CS, DC and RESET pins for the display HIGH, but whenever I connect the display to the breadboard, both the minute and second value become 0. It starts working as soon as I remove the display.
Code:
#include <SPI.h>
int chipSelect = 44;
int intFreq = 3;
/*display pins*/
int cs = 28;
int dc = 26;
int rst = 24;
#define WRITE_CONTROL_REG 0x8E
#define READ_CONTROL_REG 0x0E
#define WRITE_TIME_REG 0x80
#define READ_TIME_REG 0x00
typedef struct
uint8_t ss;
uint8_t mm;
uint8_t hh;
uint8_t dy;
uint8_t d;
uint8_t m;
uint8_t y;
}timeParams;
void rtc_init(int chipSelect, int intFreq)
* output frequencies:
* 0: 1hz
* 1: 1.024 kHz
* 2: 4.096 kHz
* 3: 8.192 kHz
* 4: off
/*set up chip select pin*/
pinMode(chipSelect, OUTPUT);
//initialize comm
digitalWrite(chipSelect, LOW);
//Only change bit 2,3,4,6
SPI.transfer(READ_CONTROL_REG);
byte originalConfig = SPI.transfer(0x00);
//end comm
digitalWrite(chipSelect, HIGH);
delay(10);
byte configModifier;
byte newConfig;
//if intFreq is 4, turn square wave off
if(intFreq == 4)
configModifier = 0b10111111;
newConfig = configModifier & originalConfig;
else if (intFreq < 4)
configModifier = (intFreq << 3) | 0b01000000; // bit 6 has to be on
newConfig = configModifier | (originalConfig & 0b11100011); //only change bits 2,3,4,6
SPI.transfer(WRITE_CONTROL_REG);
SPI.transfer(newConfig);
static uint8_t convertValGet(uint8_t value)
uint8_t convertedValue = value - 6 * (value >> 4);
return convertedValue;
static uint8_t convertValSet(uint8_t value)
uint8_t convertedValue = value + 6 * (value / 10);
void setTime(int chipSelect, timeParams *timeVals)
SPI.transfer(WRITE_TIME_REG);
SPI.transfer(convertValSet(timeVals->ss));
SPI.transfer(convertValSet(timeVals->mm));
SPI.transfer(convertValSet(timeVals->hh));
SPI.transfer(convertValSet(timeVals->dy));
SPI.transfer(convertValSet(timeVals->d));
SPI.transfer(convertValSet(timeVals->m));
SPI.transfer(convertValSet(timeVals->y));
delay(10);
void getTime(int chipSelect, timeParams *timeVals)
SPI.transfer(READ_TIME_REG);
timeVals->ss = convertValGet(SPI.transfer(READ_TIME_REG));
timeVals->mm = convertValGet(SPI.transfer(READ_TIME_REG));
timeVals->hh = convertValGet(SPI.transfer(READ_TIME_REG));
timeVals->dy = convertValGet(SPI.transfer(READ_TIME_REG));
timeVals->d = convertValGet(SPI.transfer(READ_TIME_REG));
timeVals->m = convertValGet(SPI.transfer(READ_TIME_REG));
timeVals->y = convertValGet(SPI.transfer(READ_TIME_REG));
delay(10);
timeParams currentTime = {
39,
29,
11,
4,
5,
7,
17
pinMode(cs, OUTPUT);
pinMode(dc, OUTPUT);
pinMode(rst, OUTPUT);
digitalWrite(cs, HIGH);
digitalWrite(dc, HIGH);
digitalWrite(rst, HIGH);
SPI.begin();
SPI.setBitOrder(MSBFIRST);
SPI.setDataMode(SPI_MODE1);
rtc_init(chipSelect, intFreq);
setTime(chipSelect, ¤tTime);
getTime(chipSelect, ¤tTime);
Serial.println(currentTime.ss);
What is it that I’m doing wrong here?
I found out that the RTC keeps count even though the LCD is connected, but displays 0. If I plug in the LCD at second 2, for 3 seconds, and unplug, the count resumes are 5.
Also found out that the problem is with the MISO pin. I tried plugging in each pin of the LCD individually, and found out that the MISO pin causes the time to be 0.
