Hello I have been playing around with my new 4D systems touch screen and ive been running into some issues sending the time and date to my touch screen. The touch screens using the arduino UART lines for communication.
I have been using the sparkfun arduino example which sends out the time and date via "ReadTimeDate()" the problem with that is that the touch screens onboard processor will only understand single data stream e.g int Hour = 12 instead of "ReadTimeDate()" which is as shown below.
temp.concat(TimeDate[4]);
temp.concat("/") ;
temp.concat(TimeDate[5]);
temp.concat("/") ;
temp.concat(TimeDate[6]);
temp.concat(" ") ;
temp.concat(TimeDate[2]);
temp.concat(":") ;
temp.concat(TimeDate[1]);
temp.concat(":") ;
temp.concat(TimeDate[0]);
How would I go around splitting "ReadTimeDate()" into seperate int's i.e Hour, Minutes, Seconds, Day, Month, Year, so i can sent it to the touch screen.I have added the sparkfun example code below.
#include <SPI.h>
const int cs=10; //chip select
RTC_init();
//day(1-31), month(1-12), year(0-99), hour(0-23), minute(0-59), second(0-59)
SetTimeDate(11,12,13,14,15,16);
Serial.println(ReadTimeDate());
int RTC_init(){
pinMode(cs,OUTPUT); // chip select
// start the SPI library:
SPI.begin();
SPI.setBitOrder(MSBFIRST);
SPI.setDataMode(SPI_MODE3); // both mode 1 & 3 should work
//set control register
digitalWrite(cs, LOW);
SPI.transfer(0x8E);
SPI.transfer(0x60); //60= disable Osciallator and Battery SQ wave @1hz, temp compensation, Alarms disabled
digitalWrite(cs, HIGH);
delay(10);
int SetTimeDate(int d, int mo, int y, int h, int mi, int s){
int TimeDate [7]={s,mi,h,0,d,mo,y};
for(int i=0; i<=6;i++){
if(i==3)
i++;
int b= TimeDate[i]/10;
int a= TimeDate[i]-b*10;
if(i==2){
if (b==2)
b=B00000010;
else if (b==1)
b=B00000001;
TimeDate[i]= a+(b<<4);
SPI.transfer(i+0x80);
SPI.transfer(TimeDate[i]);
String ReadTimeDate(){
String temp;
int TimeDate [7]; //second,minute,hour,null,day,month,year
if(i==3)
i++;
SPI.transfer(i+0x00);
unsigned int n = SPI.transfer(0x00);
int a=n & B00001111;
if(i==2){
int b=(n & B00110000)>>4; //24 hour mode
if(b==B00000010)
b=20;
else if(b==B00000001)
b=10;
TimeDate[i]=a+b;
else if(i==4){
TimeDate[i]=a+b*10;
else if(i==5){
int b=(n & B00010000)>>4;
TimeDate[i]=a+b*10;
else if(i==6){
int b=(n & B11110000)>>4;
TimeDate[i]=a+b*10;
else{
int b=(n & B01110000)>>4;
TimeDate[i]=a+b*10;
temp.concat("/") ;
temp.concat("/") ;
temp.concat(" ") ;
temp.concat(":") ;
temp.concat(":") ;
return(temp);
Thank you for your time.
