Hi. I need C code of dspic30f2010 based solar inverter. Solar input is 200 to 400 volt DC. Output is pure sine wave 220 volt AC. There's LCD for displaying over voltage, under voltage etc.
The question is....
Have you contacted IFNZU TECH ?
Do you have any reason to believe that it is open source?
EDIT
It seems they have a youtube channel:
Did you mean dsPIC30F2010?
Yes. Dspic30f2010. Regarding ifnzu tech, this is not his circuit. This circuit is available on internet and many people are selling complete project file with hex code. I think this circuit was published in some electronics magazine but I couldn't find. So I need either C code or hex code because sellers are asking high prices for project file.
Dump the hex from the chip using Avrdude....That is if it's possible.
EDIT: see post #8.
Here is a link that describes the process, read hex from chip.
So you have a board, but no code in the dsPIC?
Unlikely: it's a dsPIC - not an AVR
I thought so....But still is a kind of pointer to how it could be done.
EDIT: post #6 isn't guaranteed to work, As said in post #8.
Thanks. I will try it. I hope it will work.
It's not clear that @sn14j77 has a programmed chip to read from.
@sn14j77 - what, exactly, do you have?
Is the photo in your opening post yours, or just a stock photo off the interwebs?
Do you have the schematics?
I got the programmed dspic30f2010. But I'm sure that it is copy protected.
Why does it have their name in the PCB ?
The pin out actually looks a bit like a MEGA1284P
That was my thought exactly!
But now I wonder if the picture in the OP is actually just a stock image grabbed from a web page...? ![]()
A google image search finds a lot of generic boards looking very much like it...
Where is the void lcd init ();
Code does not look complete , this is also mentioned in the comments on that site.
Anybody selling a PIC micro controller with a HEX file will Code protect the device.
A post was split to a new topic: Solar inverter output voltage
