Dual axis sensor
I have a Dual axis sensor that generates a PWM signal of 100Hz and at 0.0Deg the duty is +50% -50% and at 3Deg the duty reads +52% and -48% then when I tilt it the opposite way -2.6Deg the duty reads +48% -52%. I've attached some pics to show the readings
I'm using the Pulse in and at zero it displays 4962 and at 3Deg= 5179 and -2.6=4768,
The part I'm struggling with is how to convert the PWM_value into displaying it like the inclinometer does as anybody got any ideas or advise the best method
code below
#include <Wire.h>
LiquidCrystal_I2C lcd(0x027, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address
byte PWM_PIN = 3;   //PWM input from daul axis sensor
long currentMillis = 0; //used to count the mills
long previousMillis = 0; // previuosmills
long interval = 500; // interval time for display stops the flickering
int pwm_value;  // holds the pwm value
int level; // not used yet
float digital_level; show's the slow value
pinMode(PWM_PIN, INPUT);
lcd.begin (20, 4); // for 20 X 4 LCD module
lcd.setBacklight(HIGH);
lcd.clear();
pwm_value = pulseIn(PWM_PIN, HIGH);
digital_level  = pwm_value;
lcd.setCursor(0, 0);
lcd.print(pwm_value);
lcd.print("  ");
currentMillis = millis();
if (currentMillis - previousMillis > interval)
lcd.setCursor(0, 1);
lcd.print(digital_level);
lcd.print("  ");
moderator: fixed title
Here is the 3Deg pics
Please forget this post, I did some fudge maths to get it to display the correct value which is does but the sensor only goes to 30Degress then max's out. I need one that will go full 90 degrees which I shall look into.
Mod's could you please lock this or delete it, Sorry for the inconvenience.
Steve
