Dual Direction motor (minimal inputs)
Hi
Im new to C+ and Arduino stuff and I'm trying to give the Arduino a single analog signal and have it dictate direction and speed to a motor driver.
I figured out the direction but the problem is the speed, I wanted to split the analog signal into a high and low (as if using a joystick) and have the the extreme ends of the signal be higher speed but I cant figure out how to add it without getting errors.
i cant attach the program because im new.....
below are some of the things i have tried
//example 1
  analogWrite(enablePin, pwmValue);
  // Map the potentiometer value to a PWM duty cycle (0-255)
  if (potValue > 600) {
    map(potValue, 600, 1023, 0, 255);
  if (potValue < 400) {
    map(potValue, 400, 0, 0, 255);
//example 2
  int pwmValue = map((potValue, 1023, 600, 0, 255)||(potValue,0, 500, 0, 255));
any advice would be appreciated.
Hi, @jstabyle
Welcome to the forum.
You should be able to copy it with code tags like you have already done with your examples.
Post your complete code?
Post a schematic of your project?
What model Arduino are you using?
Thanks.. Tom.... :smiley: :+1: :coffee: :australia:
// Define pins for the L298N motor driver
const int enablePin = 3;  // Enable pin for PWM speed control
const int input1Pin = 2;  // IN1 pin for direction control
const int input2Pin = 4;  // IN2 pin for direction control
// Potentiometer pin
const int potPin = A0;
  // Initialize serial communication for debugging
  // Set pin modes
  pinMode(enablePin, OUTPUT);
  pinMode(input1Pin, OUTPUT);
  pinMode(input2Pin, OUTPUT);
  // Read the potentiometer value
  int potValue = analogRead(potPin);
  // Control the motor speed using PWM
  Serial.println(pwmValue);
  // Control the motor direction
  if (potValue > 600) {  // Motor moves forward if PWM is greater than 0
    digitalWrite(input1Pin, HIGH);
    digitalWrite(input2Pin, LOW);
  if (potValue < 450) {  // Motor moves backward if PWM is greater than 0
    digitalWrite(input1Pin, LOW);
  if (potValue > 450 && potValue < 550) {  // Stop the motor
    digitalWrite(input2Pin, HIGH);
  // Optional: Add a delay
  delay(100);
This line is code
calculates a value between 0 and 255 and then discards the result. What's the point of that?
Did you mean to write
    pwmValue = map(potValue, 600, 1023, 0, 255);
I missed a spot in all my chopping and shuffling
    pwmValue= map(potValue, 600, 1023, 0, 255);
    pwmValue= map(potValue, 400, 0, 0, 255);
So I started with
int pwmValue= map(potValue, 0, 1023, 0, 255)
I had to re-add the "int" line as 0 to start and mess with the punctuation a bit.
int pwmValue = 0;
  // Set pin modes
  delay(100);
thanks for the quick answer I guess I just needed a nudge.
I would handle the speed & direction control like this
const byte PIN_ANALOG = A0;
const int min_speed = 10;
const int max_speed = 1000;
const int dead_band = 20;
const float alpha = 0.05f;
float filtered_analog;
int speed;
int direction;
  Serial.begin (115200);
void get_speed (int adc_raw)
  filtered_analog = (alpha * adc_raw) + (1-alpha) * filtered_analog;
  int abs_analog = abs(filtered_analog - 512);
  direction = (filtered_analog > 512) ? 1 : -1;
  if (abs_analog < dead_band)
    speed = 0;
    speed = map (abs_analog, dead_band, 512, min_speed, max_speed);
  Serial.print (filtered_analog);
  Serial.print (',');
  Serial.print (direction);
  Serial.print (',');
  Serial.print (speed);
  get_speed ( analogRead (PIN_ANALOG) );
It looks like strange things would happen around 575 or 425 -- pwmValue would be negative, and the motors would be on.
I'd put the outputs at the end, and use a mode variable to separate the different modes of operation.
Completely untested:
int pwmValue = 0;
  // Set pin modes
  int dirMode = 0;
    dirMode = 1;
    dirMode = -1;
  if (dirMode == 1) {  // Motor moves forward if PWM is greater than 0
  if (dirMode == -1) {  // Motor moves backward if PWM is greater than 0
  if (dirMode ==0) {  // Stop the motor
    pwmValue = 0;
  delay(100);
