Help for homework
Can you help with an example Arduino code where you can adjust the motor speed with a potentiometer using Arduino Uno and L298N motor driver board?
You need to have a go at this yourself as it’s homework , otherwise it’s cheating !
If stuck people will help you with your code .
There are examples for analog read in the IDE and the motor boards have examples in their respective libraries .
then let me ask :slight_smile: is this code correct?
const int ENA = 10;
const int IN1 = 9;
const int IN2 = 8;
const int potentiometerPin = A0;
  pinMode(ENA, OUTPUT);
  pinMode(IN1, OUTPUT);
  pinMode(IN2, OUTPUT);
  int potValue = analogRead(potentiometerPin);
  int motorSpeed = map(potValue, 0, 1023, 0, 255);
  Serial.print("Motor Speed: ");
  Serial.println(motorSpeed);
  analogWrite(ENA, motorSpeed);
  if (potValue > 512) {
    digitalWrite(IN1, HIGH);
    digitalWrite(IN2, LOW);
    digitalWrite(IN1, LOW);
    digitalWrite(IN2, HIGH);
  delay(100);  // Adjust the delay as per your requirement
When you tried the code, did it fail?
I have no means to test it, I just need to write code. Is useful?
then it doesn't matter if it correct or not
but i will score according to the code working
so you need to test it.
Please understand that it is YOUR homework
Yes, the code is useful.
const byte
ENA = 10,
IN1 = 9,
IN2 = 8,
void setup ()
  pinMode ( ENA, OUTPUT );
  pinMode ( IN1, OUTPUT );
  pinMode ( IN2, OUTPUT );
  Serial.begin ( 115200 );
void loop ()
  int motorSpeed = map ( analogRead ( potentiometerPin ), 0, 1023, -255, 255 );
  Serial.print ( "Motor Speed: " );
  Serial.print ( motorSpeed );
  analogWrite ( ENA, abs ( motorSpeed ) );
  if ( motorSpeed > 0 )
    digitalWrite ( IN1, HIGH );
    digitalWrite ( IN2, LOW );
    Serial.println ( " CW" );
    digitalWrite ( IN1, LOW );
    digitalWrite ( IN2, HIGH );
    Serial.println ( " CCW" );
  delay ( 100 ); // Adjust the delay as per your requirement
What if it is zero?
