lm new at programming l got a solar tracking code from chatGpt but its saying the ldr1 is not declared in this scope
It is very difficult to debug code that we cannot see.
Please post the test code.
Please read the forum guidelines to see how to properly post code and some information on making a good post.
Use the IDE autoformat tool (ctrl-t or Tools, Auto format) before posting code in a code block.
Please post a circuit diagram. Written descriptions are always more ambiguous than a drawing. Hand drawn, photographed and posted is fine. Include all pin names/numbers, components, their part numbers and/or values and power supplies.
What does ChatGPT tell you if you give it this feedback?
(I assume it gets to see the code?)
My standard advice:
Keep asking the robot until he/she/it gives you the correct result you expect.
One answer could probably be 42.
Maybe also the OP have not shared the code just the components is been shared
Discard ChatGPT software - use it for non-technical purposes.
Try this sun-tracking project. It has drawings, component layout and software.
How big will the solar cell cluster be? I found that driving solar cells in the elevation mode was a big waste of parts. I found that after a year or so when driving the solar cell clusters in the azimuth worked for a while. For various reasons the motors failed and had to be replaced. Operationally it was cheaper to get a larger solar cell array.
The lower the latitude, the lower the effect. Prismatic crystals will eliminate the need for cell movement.
Here is my code that I used to test the dual axis solar tracking with an ESP32.
2/2/2020
// https://docs.espressif.com/projects/esp-idf/en/latest/api-reference/system/esp_timer.html
///esp_timer_get_time(void) //gets time in uSeconds like Arduino Micros. see above link
//////// http://www.iotsharing.com/2017/09/how-to-use-arduino-esp32-can-interface.html
#include "sdkconfig.h"
#include "esp_system.h" //This inclusion configures the peripherals in the ESP system.
#include "freertos/FreeRTOS.h"
#include "freertos/task.h"
#include "freertos/timers.h"
#include "freertos/event_groups.h"
// #include "esp32/ulp.h"
// #include "driver/rtc_io.h"
#include <SimpleKalmanFilter.h>
#include <driver/adc.h>
#include "esp_sleep.h"
#include "driver/mcpwm.h"
const int TaskCore1 = 1;
const int TaskCore0 = 0;
const int TaskStack20K = 20000;
const int Priority3 = 3;
const int Priority4 = 4;
const int SerialDataBits = 115200;
volatile bool EnableTracking = true;
Serial.begin( 115200 );
// https://dl.espressif.com/doc/esp-idf/latest/api-reference/peripherals/adc.html
// set up A:D channels
log_i( "Setup A:D" );
adc_power_on( );
vTaskDelay( 1 );
adc1_config_width(ADC_WIDTH_12Bit);
// ADC1 channel 0 is GPIO36 (ESP32), GPIO1 (ESP32-S2)
adc1_config_channel_atten(ADC1_CHANNEL_0 , ADC_ATTEN_DB_11); // azimuth 0
// // ADC1_CHANNEL_3 ADC1 channel 3 is GPIO39 (ESP32)
adc1_config_channel_atten(ADC1_CHANNEL_3, ADC_ATTEN_DB_11); // azimuth 1
// // ADC1 channel 5 is GPIO33
adc1_config_channel_atten(ADC1_CHANNEL_5, ADC_ATTEN_DB_11); // altitude 1
// // ADC1 channel 6 is GPIO34
adc1_config_channel_atten(ADC1_CHANNEL_6, ADC_ATTEN_DB_11); // altitude 0
// // adc for light dark detection, ADC1 channel 7 is GPIO35 (ESP32)
adc1_config_channel_atten(ADC1_CHANNEL_7, ADC_ATTEN_DB_11);
// adc for solar cell voltage detection, ADC1 channel 4 is GPIO33 (ESP32)
adc1_config_channel_atten(ADC1_CHANNEL_4, ADC_ATTEN_DB_11);
log_i( "A:D setup complete" );
// control for relay to supply power to the servos
pinMode( 5, OUTPUT );
vTaskDelay(1);
log_i( "setup MCPWM" );
mcpwm_gpio_init(MCPWM_UNIT_0, MCPWM1A, GPIO_NUM_4 ); // Azimuth
mcpwm_gpio_init(MCPWM_UNIT_0, MCPWM0A, GPIO_NUM_12 ); // Altitude servo
mcpwm_config_t pwm_config = {};
pwm_config.frequency = 50; //frequency = 50Hz, i.e. for every servo motor time period should be 20ms
pwm_config.cmpr_a = 0; //duty cycle of PWMxA = 0
pwm_config.cmpr_b = 0; //duty cycle of PWMxb = 0
pwm_config.counter_mode = MCPWM_UP_COUNTER;
pwm_config.duty_mode = MCPWM_DUTY_MODE_0;
log_i( "MCPWM complete" );
mcpwm_init(MCPWM_UNIT_0, MCPWM_TIMER_0, &pwm_config); //Configure PWM0A timer 0 with above settings
mcpwm_init(MCPWM_UNIT_0, MCPWM_TIMER_1, &pwm_config); //Configure PWM0A timer 1 with above settings
fMoveAltitude( 1525 );
fMoveAzimuth( 1500 );
xTaskCreatePinnedToCore( TrackSun, "TrackSun", TaskStack20K, NULL, Priority3, NULL, TaskCore1 ); // assigned to core
xTaskCreatePinnedToCore( fDaylight, "fDaylight", TaskStack20K, NULL, Priority3, NULL, TaskCore0 ); // assigned to core
//// // esp_sleep_enable_timer_wakeup( (60000000 * 2) ); // set timer to wake up once a minute 60000000uS * 2
void fDaylight( void * pvParameters )
int lightLevel = 0;
log_i( "Start up fDaylight" );
while (1)
// sufficent voltage at the solar cells to do the thing?
log_i( "Solar Cell: %d", adc1_get_raw(ADC1_CHANNEL_4) );
if (adc1_get_raw(ADC1_CHANNEL_4) > 1600 )
lightLevel = adc1_get_raw(ADC1_CHANNEL_7);
if ( adc1_get_raw(ADC1_CHANNEL_7) >= 300 )
log_i( "Light Level: %d", lightLevel );
digitalWrite( 5, LOW ); // power to relay module/servos
vTaskDelay( 1 );
// if light level to low park boom
fMoveAltitude( 1475 );
fMoveAzimuth( 1900 );
// put esp32 into deep sleep
digitalWrite( 5, HIGH ); // deenergize servo motors
EnableTracking = false;
esp_sleep_enable_timer_wakeup( (60000000 * 5) ); // set timer to wake up once a minute 60000000uS
esp_deep_sleep_start();
vTaskDelay( 1000 );
} // while(1)
} // void fDaylight( void * pvParameters )
@brief Use this function to calcute pulse width for per degree rotation
@param degree_of_rotation the angle in degree to which servo has to rotate
@return
- calculated pulse width
//static uint32_t servo_per_degree_init(uint32_t degree_of_rotation)
// const int SERVO_MIN_PULSEWIDTH = 500; //Minimum pulse width in microsecond
//const int SERVO_MAX_PULSEWIDTH 2500 //Maximum pulse width in microsecond
//const int SERVO_MAX_DEGREE 180 //Maximum angle in degree upto which servo can rotate
// uint32_t cal_pulsewidth = 0;
// cal_pulsewidth = (SERVO_MIN_PULSEWIDTH + (((SERVO_MAX_PULSEWIDTH - SERVO_MIN_PULSEWIDTH) * (degree_of_rotation)) / (SERVO_MAX_DEGREE)));
// return cal_pulsewidth;
void mcpwm_gpio_initialize(void)
// void TrackSun( int Altitude, int Azimuth )
void TrackSun( void * pvParameters )
log_i( "Startup TrackSun" );
int64_t EndTime = esp_timer_get_time();
int64_t StartTime = esp_timer_get_time(); //gets time in uSeconds like Arduino Micros
int Altitude = 1500;
int Azimuth = 900;
int maxAltitudeRange = 2144;
int minAltitudeRange = 900;
int maxAzimuthRange = 2144;
int minAzimuthRange = 900;
float AltitudeThreashold = 10.0f;
float AzimuthThreashold = 10.0f;
float kalmanThreshold = 80.0f;
SimpleKalmanFilter kfAltitude0( AltitudeThreshold, kalmanThreshold, .01 ); // kalman filter Altitude 0
SimpleKalmanFilter kfAltitude1( AltitudeThreshold, kalmanThreshold, .01 ); // kalman filter Altitude 1
SimpleKalmanFilter kfAzimuth0( AzimuthThreshold, kalmanThreshold, .01 ); // kalman filter Azimuth 0
SimpleKalmanFilter kfAzimuth1( AzimuthThreshold, kalmanThreshold, .01 ); // kalman filter Azimuth 1
float filteredAltitude_0 = 0.0f;
float filteredAltitude_1 = 0.0f;
float filteredAzimuth_0 = 0.0f;
float filteredAzimuth_1 = 0.0f;
uint64_t AzimuthEndTime = esp_timer_get_time();
uint64_t AzimuthStartTime = esp_timer_get_time(); //gets time in uSeconds like Arduino Micros,but rolls over after 207 years
uint64_t AltitudeEndTime = esp_timer_get_time();
uint64_t AltitudeStartTime = esp_timer_get_time(); //gets time in uSeconds like Arduino Micros,
int StartupCount = 0;
int TorqueAmmount = 5;
while (1)
if ( EnableTracking )
//Altitude
AltitudeEndTime = esp_timer_get_time() - AltitudeStartTime; // produce elapsed time for the simpleKalmanFilter
kfAltitude0.setProcessNoise( float(AltitudeEndTime) / 1000000.0f );
kfAltitude1.setProcessNoise( float(AltitudeEndTime) / 1000000.0f );
// Serial.println( AltitudeEndTime,6 );
filteredAltitude_0 = kfAltitude0.updateEstimate( (float)adc1_get_raw(ADC1_CHANNEL_6) );
filteredAltitude_1 = kfAltitude1.updateEstimate( (float)adc1_get_raw(ADC1_CHANNEL_5) );
// Serial.print( filteredAltitude_0 );
// Serial.print( ", " );
// Serial.print( filteredAltitude_1 );
// Serial.println();
if ( (filteredAltitude_0 > filteredAltitude_1) && (abs(filteredAltitude_0 - filteredAltitude_1) > AltitudeThreshold))
Altitude -= TorqueAmmount;
// log_i( "> Alt %d", Altitude );
if ( Altitude < minAltitudeRange )
Altitude = 900;
fMoveAltitude( Altitude );
if ( (filteredAltitude_0 < filteredAltitude_1) && (abs(filteredAltitude_0 - filteredAltitude_1) > AltitudeThreshold) )
Altitude += TorqueAmmount;
if ( Altitude >= maxAltitudeRange )
Altitude = 900;
// log_i( "< Alt %d", Altitude );
//// AZIMUTH
AzimuthEndTime = esp_timer_get_time() - AzimuthStartTime; // produce elasped time for the simpleKalmanFilter
// Serial.print( (float)adc1_get_raw(ADC1_CHANNEL_3) );
// Serial.print( "," );
// Serial.print( (float)adc1_get_raw(ADC1_CHANNEL_0) );
kfAzimuth0.setProcessNoise( float(AzimuthEndTime) / 1000000.0f ); //convert time of process to uS, update SimpleKalmanFilter q
kfAzimuth1.setProcessNoise( float(AzimuthEndTime) / 1000000.0f ); //convert time of process to uS, update SimpleKalmanFilter q
filteredAzimuth_0 = kfAzimuth0.updateEstimate( (float)adc1_get_raw(ADC1_CHANNEL_3) );
filteredAzimuth_1 = kfAzimuth1.updateEstimate( (float)adc1_get_raw(ADC1_CHANNEL_0) );
// Serial.print( filteredAzimuth_0 );
// Serial.print( filteredAzimuth_1 );
if ( (filteredAzimuth_0 > filteredAzimuth_1) && (abs(filteredAzimuth_0 - filteredAzimuth_1)) > AzimuthThreashold )
Azimuth += TorqueAmmount;
if ( Azimuth >= maxAzimuthRange )
Azimuth = 900;
// log_i( "> Az %d", Azimuth );
fMoveAzimuth( Azimuth );
if ( (filteredAzimuth_0 < filteredAzimuth_1) && (abs(filteredAzimuth_1 - filteredAzimuth_0)) > AzimuthThreashold )
// log_i( "< Az %d", Azimuth );
Azimuth -= TorqueAmmount; // make new position to torque to
if ( (Azimuth >= maxAzimuthRange) || (Azimuth <= minAzimuthRange) )
Azimuth = 900;
} //azmiuth end
if ( StartupCount < 500 )
++StartupCount;
TorqueAmmount = 1;
// esp_sleep_enable_timer_wakeup( (60000000 / 30) ); // set timer to wake up
// esp_sleep_enable_timer_wakeup( (60000000 / 20) ); // set timer to wake up
// esp_light_sleep_start();
vTaskDelay( 65 );
} // while(1)
} //void TrackSun()
void fMoveAltitude( int MoveTo )
mcpwm_set_duty_in_us(MCPWM_UNIT_0, MCPWM_TIMER_0, MCPWM_OPR_A, MoveTo);
vTaskDelay( 12 );
void fMoveAzimuth( int MoveTo )
mcpwm_set_duty_in_us(MCPWM_UNIT_0, MCPWM_TIMER_1, MCPWM_OPR_A, MoveTo);
vTaskDelay( 12 );
void loop() {}
Your topic was moved to its current location as it is more suitable.
Could you also take a few moments to Learn How To Use The Forum.
Thank you
