duda lcd smartie
hola a todos, he intentado usar mi pantalla 4x20 con el arduino mega y el programa lcd smartie para monitorizar las temperaturas y uso del pc y no hay manera de conseguir que muestre datos la pantalla se queda mostrando: LCD SMARTIE on arduino
y de hay no paso, creo que el sketch del lcd smartie no es correcto ya que se han caido todos los servidores y sitios donde habia el sketch original estoy usando este y nose si es correcto aver si alguien tuviese un sketch del lcd smartie que funcione y puede subirlo aqui.
// include the library code:
#include <LiquidCrystal.h>
// these constants won't change.  But you can change the size of
// your LCD using them:
const int numRows = 4;
const int numCols = 20;
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 10, 5, 4, 3, 2);
// RS, RW, Enable, 4,5,6,7 (Refer to the back of your LCD for details)
  // set up the LCD's number of rows and columns:
  lcd.begin(numRows, numCols);
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("**LCD  SMARTIE**");
  lcd.setCursor(0,1);
  lcd.print("on Arduino");
byte serial_getch(){
  int incoming;
  while (Serial.available()==0){}
	// read the incoming byte:
  incoming = Serial.read();
  return (byte) (incoming &0xff);
void loop(){
  byte rxbyte;
  byte temp;
  rxbyte = serial_getch();
  if (rxbyte == 254) //Matrix Orbital uses 254 prefix for commands
    switch (serial_getch())
    case 66: //backlight on (at previously set brightness)
      // not implemented
    case 70: //backlight off
      // not implemented
    case 71:  //set cursor position
      temp = (serial_getch() - 1);  //get column byte
      switch (serial_getch())  //get row byte
        //line 1 is already set up
      case 2:
        temp += 0x40;
      case 3:
        temp += 0x14;
      case 4:
        temp += 0x54;
      default:
      lcd.command(0b10000000 + temp);
    case 72:  //cursor home (reset display position)
      lcd.command(2);
    case 74:  //show underline cursor
      lcd.command(0b00001110);
    case 75:  //underline cursor off
    case 84:  //block cursor off
      lcd.command(0b00001100);
    case 76:  //move cursor left
      lcd.command(16);
    case 77:  //move cursor right
      lcd.command(20);
    case 78:  //define custom char
      lcd.command(64 + (serial_getch() * 8));  //get+set char address
      for (temp = 7; temp != 0; temp--)
        lcd.print(serial_getch()); //get each pattern byte
    case 83:  //show blinking block cursor
      lcd.command(0b00001111);
    case 86:  //GPO OFF
      //implement later
    case 87:  //GPO ON
      /*temp = serial_getch();
       				if (temp == 1)
       					GPO1 = GPO_ON;
    case 88:  //clear display, cursor home
      lcd.command(1);
    case 152: //set and remember (doesn't save value, though)
    case 153: //set backlight brightness
      //not implemented
      //these commands ignored (no parameters)
    case 35: //read serial number
    case 36: //read version number
    case 55: //read module type
    case 59: //exit flow-control mode
    case 65: //auto transmit keypresses
    case 96: //auto-repeat mode off (keypad)
    case 67: //auto line-wrap on
    case 68: //auto line-wrap off
    case 81: //auto scroll on
    case 82: //auto scroll off
    case 104: //init horiz bar graph
    case 109: //init med size digits
    case 115: //init narrow vert bar graph
    case 118: //init wide vert bar graph
    default:
      //all other commands ignored and parameter byte discarded
      temp = serial_getch();  //dump the command code
    return;
  } //END OF COMMAND HANDLER
  //change accented char to plain, detect and change descenders
  //NB descenders only work on 5x10 displays. This lookup table works
  //  with my DEM-20845 (Display Elektronik GmbH) LCD using KS0066 chip.
  switch (rxbyte)
    //chars that have direct equivalent in LCD charmap
    /*		case 0x67: //g
     			rxbyte = 0xE7;
     		case 0x6A: //j
     			rxbyte = 0xEA;
     		case 0x70: //p
     			rxbyte = 0xF0;
     		case 0x71: //q
     			rxbyte = 0xF1;
     		case 0x79: //y
     			rxbyte = 0xF9;
     */  case 0xE4: //ASCII "a" umlaut
    rxbyte = 0xE1;
  case 0xF1: //ASCII "n" tilde
    rxbyte = 0xEE;
  case 0xF6: //ASCII "o" umlaut
    rxbyte = 0xEF; //was wrong in v0.86
  case 0xFC: //ASCII "u" umlaut
    rxbyte = 0xF5;
    //accented -> plain equivalent
    //and misc symbol translation
  case 0xA3: //sterling (pounds)
    rxbyte = 0xED;
    /*		case 0xB0: //degrees symbol
     			rxbyte = 0xDF;
     */  case 0xB5: //mu
    rxbyte = 0xE4;
  case 0xC0: //"A" variants
  case 0xC1:
  case 0xC2:
  case 0xC3:
  case 0xC4:
  case 0xC5:
    rxbyte = 0x41;
  case 0xC8: //"E" variants
  case 0xC9:
  case 0xCA:
  case 0xCB:
    rxbyte = 0x45;
  case 0xCC: //"I" variants
  case 0xCD:
  case 0xCE:
  case 0xCF:
    rxbyte = 0x49;
  case 0xD1: //"N" tilde -> plain "N"
    rxbyte = 0x43;
  case 0xD2: //"O" variants
  case 0xD3:
  case 0xD4:
  case 0xD5:
  case 0xD6:
  case 0xD8:
    rxbyte = 0x4F;
  case 0xD9: //"U" variants
  case 0xDA:
  case 0xDB:
  case 0xDC:
    rxbyte = 0x55;
  case 0xDD: //"Y" acute -> "Y"
    rxbyte = 0x59;
    /*		case 0xDF: //beta  //mucks up LCDSmartie's degree symbol??
     			rxbyte = 0xE2;
     */  case 0xE0: //"a" variants except umlaut
  case 0xE1:
  case 0xE2:
  case 0xE3:
  case 0xE5:
    rxbyte = 0x61;
  case 0xE7: //"c" cedilla -> "c"
    rxbyte = 0x63;
  case 0xE8: //"e" variants
  case 0xE9:
  case 0xEA:
  case 0xEB:
    rxbyte = 0x65;
  case 0xEC: //"i" variants
  case 0xED:
  case 0xEE:
  case 0xEF:
    rxbyte = 0x69;
  case 0xF2: //"o" variants except umlaut
  case 0xF3:
  case 0xF4:
  case 0xF5:
  case 0xF8:
    rxbyte = 0x6F;
  case 0xF7: //division symbol
    rxbyte = 0xFD;
  case 0xF9: //"u" variants except umlaut
  case 0xFA:
  case 0xFB:
    rxbyte = 0x75;
  default:
  lcd.print(rxbyte);  //otherwise a plain char so we print it to lcd
  return;
uso la configuracion 4x20 lineas aunque no me funciona tampoco con 2x16
en el programa de lcd smartie tengo seleccionado el plugin matrix.dll y 9600baud tal como creo que debo hacer pero la pantalla siempre se queda mostrando lcd smartie sin mostrar nada mas.
en la conexion al arduino tengo:
vss a GND
vdd a 5V
v0 a un potenciometro para controlar el contraste
rs a DIGITAL 12
rw a DIGITAL 11
enable a DIGITAL 10
d4 a DIGITAL 5
d5 a DIGITAL 4
d6 a DIGITAL 3
d7 a DIGITAL 2
Anodo a 5V
Katodo a GND
aver si alguien me puede ayudar ya que toda la informacion sobre conexiones y sketchs del lcd smartie ha ido desapareciendo y no encuentro ya nada fiable que funcione.
Gracias
